Question about KitchenAid Washing Machines
Washing machine model KAWS850LQ1 fills, washes, spins, fills for the rinse cycle, then stops after about 30 seconds into the agitation cycle. If left alone, it will start agitating again for another 30 seconds then stops again. There is a continuous humming sound meaning it hasn't lost power.
SOURCE: Ge prodigy wpse4270aoww won't rinse or spin
if basket wont spin, remove front hatch by inserting spackel knife to trip spring latch on both sides,then check the belt for wear & tear.factory length is 29.5 " time will stretch them out, resulting in broken belt.check behind control panel hatch for diagram of machine for exact location of belt also can be downloaded online.
I hope this helps.ie overloading machine will shorten belt life.
Posted on Mar 07, 2008
IB4G2008
  • 3587 Answers
SOURCE: Washer doesn't agitate
sounds like your washer went mellow on you(doesn't get agitated, right)?
ok. enough humor.
sounds like there's a problem with the motor/belt/control board in that order
Posted on Mar 13, 2008
  • 20 Answers
SOURCE: machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Posted on Jan 19, 2009
kram26
  • 544 Answers
SOURCE: washer will not agitate or spin
HI,
you can view this site to have some ideas about your agitator problem.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes
any further question let me know.
thanks,
Posted on Mar 29, 2009
honeymokey
  • 3113 Answers
SOURCE: washer does not agitate
Push down on lid to activate door switch.
Posted on May 25, 2009
Kenmore Washer Doesn't Agitate
Don't be too sure the drive coupler hasn't failed or is failing
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
Whirlpool washer model lsr8233eqo
So when the cycle first starts, it will fill and agitate and spin. But then on the rinse cycle it stops?
Feb 03, 2013 | Whirlpool Washing Machines
Frigidaire FWT647GHSO when it gets to rinse first rinse cycle, it doesn't stop filling with water. It won't agitate or spin. It works well in the wash cycle, agitates and spins and advances
probably you've got something blocking the water pump from doing its job properly so check that the water pump is free running emptying all the water if not then there is a blockage in the pump normally ist a button, paper clip or other debris out of a trouser pocket eric
Dec 25, 2017 | Frigidaire Washing Machines
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
Will not spin on any rinse cycle
Hi, This washer does not have a belt. While the washer is agitating, if you lift the lid will it stop? Some models will agitate but not spin if the lid is up. It sounds to me like the lid switch might be going bad.
If you will get me a model #, I can look this up for you and give you a better idea.
Vic
Jul 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine does not drain during rinse cycle?
Turn timer to rinse cycle. let fill up and agitate. when it stops agitating it should pause then start to pump water out. After about 2 minutes it should pause for 3-5 seconds then start again and spin. If it starts the first time and never stops it will just continue to pump but no spin. The 3-5 second pause allows the transmission to shift to spin. If it does not do this the problem is your timer. You may need to do this a few times to verify the problem.
If that is not the problem it is likely that you need a new clutch. You will need a technician to install a new clutch for you
May 17, 2009 | Whirlpool LSQ9600L Top Load Washer
Machine fills and agitates, but won't drain
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool AWO3761 stuck mid-cycle
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jul 06, 2008 | Whirlpool AWM6100 Front Load Washer
    Clothes washer
    well that's a tough one need to ask a few questions first whats the brand and model number second does it fill in the rinse cycle ok.If it fills in rinse try selecting wash with cold wash/ cold rinse selected and let me know how that works please hold my rating till we are finished
    Jan 11, 2008 | Washing Machines
    Washing Machines Logo
    Top KitchenAid Washing Machines Experts
    kj henriksen
    kj henriksen
    gbob59
    Mike
    Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
