Question about Arris SURFboard SBG900 (49402201900) Modem
I got locked out of the admin page after wpa apply
Hey I got this surboard SBG900, I enabled wpa (hit apply in the security settings) and then I got locked out of the admin page... any hints? is there a defaiult wpa password? Is there a way to reset it? 3
  • Anonymous Jul 22, 2008
    como montar una clave al modem wpa
    New Friend:
Going through the same thing now... Did you ever find a solution? Any help/tips would be much appreciated. Thanks!
Posted on Aug 04, 2013
You need to be connected to the modem via Eathernet cable. The WPA can not be set up using the wireless.
Posted on Aug 11, 2008
Going through the same thing.....you must be hard connected (i.e. not wireless) to the cable modem.
Posted on Jul 05, 2008
How do i turn wifi off surboard sbg6580
log in to the modem as if you were going to change the wireless password (browse to default gateway and enter username and password) then turn off SSID broadcast (usually by un-checking a box)
try these
SBG900 Default IP:
192.168.0.1
SBG900 Default Password:
motorola
SBG900 Default Username:
admin
Nov 19, 2013 | Arris SURFboard SBG900 Wireless Router...
Tip
How to Configure your Linksys router with wireless security
Launch your Internet Explorer, Netscape or your Mozilla.
On the Address, Search or URL, type: http://192.168.1.1, then hit Enter/Return. A login screen will appear. Type admin for the password and leave the username blank or empty then hit “OK”.
Note: If it doesn’t take admin as the password you might have changed it when you have ran the RUN ME FIRST CD that came with the router so try other passwords.
If you cannot remember the password, I regret to tell you but, you have to reset the router and, reconfigure it again. Next time, remember the password to avoid unnecessary reset and reconfiguration.
To reset the router to factory default
1] Press and hold the reset button for 30 sec., after that
2] Unplug the power keep holding down the reset button for another 30 sec.
3] Then, plug back the power keep holding down the reset button for 30sec., after that
4] Release the reset button.
Note: Configuring WEP in the router varies depending on the model number and firmware version of your Linksys Router.
Cisco Interface (If your Setup page has a Cisco Logo)
Go to Wireless Tab > Wireless Security > Click the drop down arrow then select WEP:
Regular Linksys Router Interface (If your Setup page has a no Cisco Logo)
Under Setup > Click WEP Key Settings or Edit WEP Key Settings
Using passphrase 64bit
Encryption LEVEL 64bit > type a passphrase > click Generate > copy key1 on a piece of paper (10hex character). Then hit Apply or Save Settings.
For manual key entry of 64bit encryption:
Encryption LEVEL: 64bit > Under Key 1 type a 10 digit character from A-F and 0-9.
(e.g.: A0B3F58C9E, 0123456789, ABCDEFABCD). Then hit Apply or Save Settings.
Using passphrase 128bit
Encryption LEVEL128bit > type a passphrase > click Generate > copy key1 on a piece of paper (26hex character). Then hit Apply or Save Settings.
For manual key entry of 128bit encryption:
Encryption LEVEL: 128bit > Under Key 1 type a 26 digit character from A-F and 0-9.
(e.g.:0123456789ABCDEF9874561230, 012345678901234567890123456, ABCDEFABCDABCDEFABCDABCDEF).
If you want better security for Vista computers, you may want to select WPA personal (WPA-PSK) under security > set the Algorithm to TKIP and type your personal security code (any code you want, any characters)
on Jan 06, 2010 | Computers & Internet
Trying to apply network key
You need your PC connected to the Router via cable, then open Internet Explorer.
In the Address bar type 192.160.100.1 and press enter, for login enter admin and for password enter motorola, now you should see a Motorola window with all the settings.
On the left side select Wireless, a different window will appear.
In the Security Mode field, select WPA and click Apply.
Skip the portion about WEP and go below.
Under WPA CONFIGURATION, for WPA Encryption choose TKIP and for WPA Authentication choose Local (WPA-PSK)
Under Local there is WPA Passphrase, here enter your desired password; try not to forget the password in the future or you have to repeat the steps above, also try to use a combination of letter and numbers.
Click on save changes and you have finish, now you can close explorer.
Please let me know if you need additional help.
regards
Mar 19, 2011 | Arris SURFboard SBG900 (49402201900) Modem
How do I block other users from using my Modem
you need to lock the wifi use your house or cell phone number as a WEP key
Mar 02, 2011 | Arris SURFboard SBG900 Wireless Router...
Set up wireless security
1 On a computer wired to the SBG900 USB or Ethernet port, open your web
browser (for example, Microsoft Internet Explorer)
2 Type http//:192.168.100.1 and press ENTER to display the login window:
3 In the User ID field, type admin (case sensitive) and press TAB.
4 In the Password field, type motorola (case sensitive) and click Log In to
display the SBG900 Setup Program main window:
As soon as your network is operational, run the SBG900 Setup Program to:
"Wireless Network Setup"
For a LAN with one or more wireless clients, enable wireless security on the SBG900.
After enabling wireless security on the SBG900, as required on each wireless client:
> If you disabled ESSID broadcasting on the SBG900, set the client Network
Name (ESSID) identical to the ESSID on the SBG900.
> If you enabled WEP on the SBG900, set the client WEP key identical to the
WEP key on the SBG900.
> If you enabled Allow Only Listed Stations Access, be sure the MAC
address for each client is correctly listed on the SBG900.
Dec 22, 2010 | Arris SURFboard SBG900 Wireless Router...
I cant enable the password
Hi Friend,
In order to enable wireless security password, please follow the steps:
1.Type 192.168.1.1 in the address bar of the web browser and hit enter
2.Enter the username and password. If you have not set the router password then leave the username blank and type admin in password and hit enter.
3.Click the tab Wirelss in the setup page and fill the sections
Wireless Network Mode:Mixed
Wireless Network Name:As per your choice
Wireless Channel-6-2.437GHz
Wireless SSID-Enabled and click Save Settings
4.Click Wireless Security and fill the sections as mentoned
Security Mode-WPA Personal
PA Algorith- TKIP
WPA Shared Key-Enter 10 digit password(e.g-your 10 digit telephone number) and click Save Settings
You have now set a password to your wireless network and is secured. Enjoy
Regards
Chiranjeet
Sep 16, 2010 | Linksys Wireless-G WRT54G Router
How do i put a password on my wireless motorola router?
Use the Wireless > SECURITY — basic Page to encrypt your transmitted data. Choose one of:
If all of your wireless clients support WPA encryption, we recommend using WPA instead of WEP because WPA:
• Provides much stronger encryption and is more secure
• Provides authentication to ensure that authorized users only can log in to your WLAN
• Is much easier to configure
• Uses a standard algorithm on all compliant products to generate a key from a textual passphrase
• Will be incorporated into the new IEEE 802.11i wireless networking standard
For new wireless LANs, we recommend purchasing client adapters that support WPA, such as the Motorola
Wireless Notebook Adapter WN825G, Wireless PCI Adapter WPCI810G, and Wireless USB Adapter WU830G.
For more information about the benefits of WPA, see the Wi-Fi Protected Access Web page:
http://www.wifialliance.org/OpenSection/protected_access.asp.
Configure on the SBG900 Required On Each Wireless Client
If all of your wireless clients support Wi-Fi
Protected Access (WPA), we recommend
Configuring WPA on the SBG900
If you use a local pre-shared key (WPA-PSK) passphrase, you
must configure the identical passphrase to the SBG900 on each
wireless client. Home and small-office settings typically use a
local passphrase.
Configuring a RADIUS server requires specialized knowledge
that is beyond the scope of this guide. For more information,
contact your network administrator.
Otherwise, perform Configuring WEP on the
SBG900
You must configure the identical WEP key to the SBG900 on each
wireless client.
Feb 15, 2010 | Arris SURFboard SBG900 Wireless Router...
My wireless connection is unsecured I'm using a Netgear router,what do I do to secure my line?
1. Goto your web browser
2. Type 192.168.0.1 or 192.168.1.1 (depending on which Netgear router, just try both).
3. Type "admin" for username and "admin" for password.
4. Click on "Wireless settings" on the left frame of the router setup page.
5. Security options are on the main frame of the page now (under security options). Click on WEP and enter a WEP ID (make it unique).
6. Click on "Apply" and repair your wireless connection. It should prompt you for a WEP key.
Hope this helps,
Bill
Sep 05, 2009 | NetGear WGR614 Wireless Router
How do I make a secure wireless network
If you don't have the manual, you can download it here.
Look at the chapter "Setting Up Your Wireless LAN" (page 64).
Then follow the guide for "Configuring WPA on the SBG900" (page 66).
Try to avoid WEP, since it is easily hackable and only gives the sense of false security. As encryption, choose WPA AES, because it is more secure than TKIP. WPA Authentication should be "local", since you don't want to run a dedicated server.
Some older laptops cannot deal with WPA-AES. In that case you have to fall back to WEP, but try WPA first.
Furthermore you should change the ESSID from "Motorola" to something more specific for you, so other clients don't connect accidentally to your network (page 71).
If you want to enable MAC filtering is up to you and only makes sense if you never have friends or colleagues coming over with a laptop. I would leave it off and enable it at a later point, after you see that everything is running fine.
Don't forget to set up your computers as well! You have to provide the passphrase for them, otherwise they can't connect (see page 75). The way I do it is to create a strong (!) passphrase like "V0y6Mmb90y...", copy it into a text document (use notepad), and save it on a USB stick. form there you can copy it to the field, when Windows (or Mac) asks for the network key.
No typos = no headaches.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Jul 11, 2009 | Arris SURFboard SBG900 802.11g/b...
I have a Surfboard SBG900 router and cannot connect to VPN
The issue you have is not due to enabling WPA. It is due to enabling Firewall protection. Either turnoff firewall or use custom option to enable required ports.
Nov 26, 2008 | Arris SURFboard SBG900 Wireless Router...
Arris SURFboard SBG900 (49402201900) Modem Logo
1,189 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Jerry
Jerry
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
