Question about Dishwashers
I have a dishwasher Electrolux esf model visio 6146. It merged the lamp that illuminates the machine when we open the door. How do you change that light bulb? Thanks.
4 Suggested Answers
localwonder
  • 6784 Answers
SOURCE: Dishwasher full of water
Check all areas stated below to address this issue.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer/Control
Replace if defective (note: uncommon problem).
Posted on Jun 18, 2009
SOURCE: dishwash machine electrolux esf 6121
Easy fix, had same problem on our. behind the red lights there is the electrc stuff, when you open/close the machine the solderings crack. remove screws until you can get off the panel, then there is some small hooks that hold the board, loosen all contacts and take out the board, check the solderings around the relais and re-solder them, i resoldered all spots on our board.
Posted on Jul 24, 2010
  • 174 Answers
SOURCE: Dishwasher ELECTROLUX ESF 6121 WHEN STARTING
this fault can be the heater which has an electrical earth fault. You need an insulation tester to test it. The heater is accessed from the right hand side and is a cartridge type insert in the flow to the top spray water supply.
Posted on Nov 06, 2010
Electrolux ESF 65010. How can I erase failure code if the problem is solved and start test program?
Here's the manual link
WWW.manualslib.com/manual/602210/Aed-Electrolux-Esf65010htlm?page4#manual
Apr 10, 2017 | Electrolux Dishwashers
Hi, My Electrolux dishwasher ESF 45030 has got locked and the control panel is not working anymore, could you please help me to fix it?
All of the manuals I can find are in a language other than english.
Not much help here.
if there is a child lock under a button or two hold it/ them down for 3 seconds or until you get the controls to light up.
Apr 18, 2014 | Electrolux Dishwashers
HNL 6146 door won't open
Has it emptied all water out ??
Jun 18, 2013 | Hoover Washing Machines
Dishwasher ELECTROLUX ESF 6121 WHEN STARTING propels the water, and then stop and blink SIJALICE WASHING AND PROGRAM. PROVERENO solenoid which operates. WHAT IS THE PROBLEM. Thank you, Darko
Nov 06, 2010 | Electrolux Dishwashers
Electrolux ESF 662 no water is taken into the machine
Mine did the same thing. Turned out it was leaning back a bit, so I leveled it and now it seems to be working fine.
Mar 08, 2010 | Electrolux 23 in. ESI602 Free-standing...
Dishwasher not draining, drying cycle error Electrolux ESF 4120
You didn't say what model you have, most dishwashers have a float switch inside to prevent over filling and subsequent flooding. If this switch is stuck, the dishwasher won't start.
Open the door and look inside the unit. The float should look a little like a mushroom cap. Make sure it travels up and down smoothly. It's usually on the right side closer to the front of the machine.
Jul 25, 2009 | Dishwashers
Dishwash machine electrolux esf 6121
Mar 01, 2009 | Dishwashers
Dishwasher wash options
www.frigidaire.com look up your model for a download of the manual
May 10, 2008 | Dishwashers
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
