Question about Farmall IH Tractor 460, 560, 660, 2606 ITIH25
I have a question concerning the power steering on a Farmall 560 Tractor - - The tractor turns hard both to the left and the right - it is very jerky in its movement - there is NO unusual sounds associated with this. Anyone have any ideas on what could cause this issue? Pump pressures are correct, so that's not where the problem lies - - Any assistance would be appreciated - - -
    Top Expert:
  • Farmall Master
  • 52,032 Answers
Seizing king pins thrust bearings
Posted on Aug 13, 2017
4 Suggested Answers
robotek
  • 1512 Answers
SOURCE: how to time my farmall tractor
Hi David
What model Farmall you got there
regards
robotek
Posted on Nov 06, 2008
  • 14 Answers
SOURCE: I have a Farmall 560 tractor and I want to convert
if its a gas: get ahold of the govenor and harness that power by puttin a lever of some sort and pull that going down the track. if its a diesel then i do want to warn ahead of time that it my result in blowing head gaskets. but check the manual and crank the pump up as far as you want it, ( if you want it stock). but if you want to have it a hot farm mod ( at least im sure of it) put a electric fuel pump before the filters, it just puts more fuel to the pump itself
Posted on Aug 17, 2010
  • 14 Answers
SOURCE: Hello, I have Farmall tractor F-12 with a serial
1936
Wiring diagram 560 farmall 560 tractor
try searching for a tractor forum like OLDIRON
Jan 05, 2016 | Farmall IH Tractor 460, 560, 660, 2606...
Dash layout on farmall 560
The operators manual shows a cigarette lighter in that location. It would be just to the right of the starter button. I have an IH 560 diesel, so that's where the glow plug button is located.
Jul 29, 2012 | Farmall IH Tractor 460, 560, 660, 2606...
Where are hydraulic fluid drain plugs located on farmall 560
1 plug under pto 1smaller plug under tractor on front of transmission 1plugunder clutch housing total of3
Jan 25, 2011 | Farmall IH Tractor 460, 560, 660, 2606...
Where do you add hydro fluid in a 560 and does it run the power steering also
ther will be acover on rear deck plate next to shifter this is the fill hole check plug will be onleft side of rear end housing under clutch rod [pipe plug] fill until fluid drips out check plug
Jan 09, 2011 | Farmall IH Tractor 460, 560, 660, 2606...
NEED TO KNOW HOW TO TIGHTING STEERING ON 140 tractor
if all tie rods are tight the steering box has a philips screw with a jam nut loose nut turn screw in until it stops, back out a little tighten jam nut. that takes slack out of worm gear. hope this helps
Aug 01, 2010 | Farmall International Tractor 140 Radiator
Farmall IH  Tractor 460, 560, 660, 2606 ITIH25 Logo
118 people viewed this question
Top Farmall Toys Experts
Wayne Fellows
Wayne Fellows
Phil Walker
Phil Walker
Jerry Radcliffe
Are you a Farmall Toy Expert? Answer questions, earn points and help others
