Question about Bissell 3920 Bagless Upright Vacuum
Rollers won't turn when on carpet, ok if I lift the vacuum above the carpet.
  • lsferris Nov 06, 2010
    It's the brush rollers that stop when on the carpet.
    President:
  • 2,777 Answers
That is very strange. So when you lift it up above the carpet the feet / wheels turn freely, but when it is on the carpet it won't move at all? Not even when you push it, the rollers won't turn, but when you lift it up it does? That doesn't make much of any sense...
Let me know though, please confirm.
Also, this is a Bissell 3920, correct?
Thanks, please reply and let me know here.. just reply to my answer and I'll be right back with you.
Tim
Posted on Nov 06, 2010
  • Tim Grayson
    Tim Grayson Nov 06, 2010
    Ohhh I see what you mean.. Ok that either means the belt on the rollers has worn out or the motor that turns the brushes has failed. Do you think you would be able to do this repair yourself... it is not easy by any means. I would recommend you take it to a local vacuum shop and have them repair the belt / motor on the brushes. They do just wear out after a time...
    Let me know what you think
    Thanks,
    Tim
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
My dyson vaccum feels heavy and slow when pushing it. Please advise. Thanks
First make sure that brush roll is moving not broken belt....if all ok then try setting height for thick pile carpet lift head a bit this will ease off on a thinner carpet and in turn make it easy to push,
Jul 04, 2011 | Dyson Vacuums
Brush is not engaging when vacuuming. If lifted
therre are usually aprings that hold the brush in position or a spacer thaqt turns when you adjust the height. turn the vacuum over and remove the plate covering verything. make sure your unplugged first. it usually takes about 5-6 phillips head screws. look for loose ,broken or missing parts. make the the roller is taken out and is carefully cleaned of all hair etc esp that just at the edge of the roller where it meets the monting devices. the hair and debris often gets stuck there and once removed works much better. also make sure the belt is not stretched and is slipping on the brush. if it is replace it. good luck.carefully reassemle the parts you removed being very aware of what postiotn everything was in when you took it apart. make sure everything has proper clearance and then test your vacuum. if you find broken or missing parts replace them first ofcoarse.
May 14, 2010 | Hoover Tempo Widepath Upright Vacuum -...
Every thing looks good but rollers wont go while on carpet
That means that the belt is stretched. The belt may look fine and be intact but it still can be stretched and if it is it won't turn the brush while on the carpet. You can get replacement belts here:
Replacement Vacuum Belts
Feb 15, 2010 | Vacuums
Brush wont go round but the belt is ok
The belt may look okay but it can still be stretched. If it is stretched it won't turn the brush against the resistance of the carpet. Here is a link to the belts you need and to the manual which has instructions:
Bissell Lift-Off Revolution Belt & Manual
Nov 23, 2009 | Bissell Lift-Off(R) Revolution(R) Turbo...
The rollers on my hoover widepath won't turn
On this model the brushes will not turn on unless the handle is tilted back and the switch is set to carpet. if you are already doing this, then one of the likely causes would be the gear motor assembly. If that sounds expensive it is costs around $65.00. for the part only
Jan 16, 2009 | Hoover U8145-900 Savvy Bagless Upright...
Rotating brushes will not turn
If belts are ok then possibly needs new front brush motor replaced.
Nov 05, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Rollers are to low and tearing up carpet.
unfortunatly you cant adjust the height on that type of machine, and new carpet no matter how good or expensive can shed for up to a year, the best thing would be to buy a cheap carpet rake ( not a garden rake ) that would get up all that fluff.
Sep 11, 2008 | Hoover S3639 WindTunnel Bagged Canister...
Carpet function rollers don't turn
Most likely a broken belt. If the brush roll is turning freely, then check the belt.
Mar 02, 2008 | Kenmore 25812 / 25813 Progressive Bagged...
Bissell 3920 Bagless Upright Vacuum Logo
213 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
