Savin copier E70 code blinking. Can't copy - Office Equipment & Supplies
  • 1 more comment
  • gal2204me Nov 06, 2010
    Sorry! It is a Savin 9113Z
    You saved this church secretary!!
    Thank you so much, worked like a charm!!
    I will definitely use this service again if needed.
    (had to step out or it would have been fixed sooner!)
    Yes it fixed my copier, very thankful
  • 10,515 Answers
Kindly mention the model number?
Thanks!!
Posted on Nov 06, 2010
  • taran_2005
    taran_2005 Nov 06, 2010
    Thanks for your response!!
    This is an error message for empty waste toner.
    Entering the program mode:
    1) enter 71 by using the numeral keys
    2) hold the clear stop key until dot (.) appears in the top left corner of the copy counter and then release it.
    3) press the clear stop key again and then press the lighter key . number (5) will blink in the copy counter to show that u are in the service mode.
    E 70 RESET:
    type 83 press the auto image density key then press 1
    then press the auto image density key again .
    To leave the service mode open and close the front cover or turn the main switch off and on.
    If the problem still persists, you need to call a tech on site.
    Let me know,if needed further assistance.
    Hope i helped you.
    Thanks for using ' Fixya ' and have a nice day!!
  • taran_2005
    Glad that it worked.
    Do not forget to accept the solution so that i could get the compensation for the time i spent.Hope to hear from you soon.
    Thanks and Regards
    taran_2005
I have a savin 9060 and it is telling me I have an error 92 can u help me??
What do error codes 91 and 92 in the error log mean?
91: The job was reset by the device.
92: The job was manually reset by a user.
Dec 18, 2014 | Savin 9060 Copier With Feed, Finisher,...
User codes.
that's due to having too many users..you'll need to delete some folks to make this work...maxing out the user codes will freeze the unit..
Apr 25, 2008 | Savin 9935DP Laser Printer
Savin c3224
This typically happens when trying to copy currency & certain other sensitive docs on all color Ricoh devices. This includes Savin, Lanier & Gestetner. It may work if you reduce the image enough.
Feb 20, 2014 | Ricoh Office Equipment & Supplies
My Savin SDC 103 has an SC-172 call service error. The copier was given to me, it only has 7800 copies on it. The error showed up after they moved it.
That code is related to the scanner unit.
Probably after they move the machine the lamp went out of position.
I advise you to see the all scanner; Lamp, Mirrors, White plate...
May 23, 2011 | Savin Office Equipment & Supplies
Copystar cs1510 showing error e70 please help
The E70 its a troubleshooting original placement and memory errors:
1. Remove originals and replace them in the original table when the "E70" or "E71" errors display.
2. Remove originals placed on the original tray and allow the copy job from the plate to complete when the "E72" error displays.
3. Remove originals remaining in the original table when the "E90" error displays, indicating that the memory is full. Press the button with a "%" sign on it, labeled recall, to print the copies of the originals that have already been scanned. When printing completes, place the remaining originals back into the original tray and press "Start" to continue copying.
Hope helps.
Apr 18, 2011 | Copystar CS-1510 Copier
My ricoh FT4418 wont copy at all error code E70. what does that mean?
It means the toner overflow sensor was tripped: http://www.copier-help.com/copier-help/ecs/ricoh/ecrft4418.html
Mar 14, 2011 | Ricoh FT5832 Copier
SAvin error code Sc542 need to reset
press clear mode once- its a yellow button
pres 107 clear/stop and hold for a while untill you see the screen changes to copy sp mode. this is the machines service program mode.
press copy sp on screen and off and on the machine.
it should reset the code. if not email me on ronils_singh@yahoo.com.au. i am a Ricoh techinician
Sep 30, 2010 | Savin 8035e Copier
Savin 2545 communicating light blinks but nothing prints
YOU NEED YOUR FIRMWARE UPGRADED BUT ONLY A SERVICE TECH CAN GET IT AND DO IT.1 HOUR OF TIME SHOULD BE PLENTY AND THAT SHOULD INCLUDE A CLEANUP PROBABLY ABOUT 150 TO 200 DOLLARS
May 18, 2010 | Savin 2545DP Black and White Copier
69 people viewed this question
k24674
jasbo
jasbo
