Question about McCulloch 4 Ton Electric Log Splitter # FB4052
I have a 4052 mcCulloch 4 ton log splitter. What kind of oil does it take for the hydraulics
    Genius:
  • 1,015 Answers
Not having a mcCULLOCH manual I dont know what they reccomend,but on mine I just use HI grade industrial/commercial hydraulic fluid. I have been using this for 15 years and have had no trouble. I change oil and filter every year. Thank you.
Posted on Nov 06, 2010
Need a switch , kedu electric 564
The McCulloch part number for the switch box is 7200-405266, it can be ordered online or from your local small engine repair shop.
Jul 11, 2014 | McCulloch 4 Ton Electric Log Splitter #...
Adding hydrolic oil to yardworks 4-ton wood spliter
Replace the Hydraulic oil in the log splitter after
every 150 hours of use. Take following steps to
replace it.
  1. Make sure all moving parts stops and the log splitter is unplugged.
  2. Unscrew Oil Drain Bolt with Dipstick to remove it.
  3. Turn the log splitter on the Support Leg side over an 4 liters capacity container to drain the hydraulic oil off.
  4. Turn the log splitter on the the motor side.
  5. Refill fresh hydraulic oil at the volume as per the hydraulic oil capacity of a particular model indicated in above specifications table.
  6. Clean the surface of Dipstick on the Oil Drain Bolt and put it back into the oil tank while keep the log splitter vertically.
  7. Make sure the level of the refilled oil is just between 2 grooves around the Dipstick.
  8. Clean the Oil Drain Bolt before thread them back. Make sure they are tightened to avoid leakage before place the log splitter horizontally.
Periodically check oil level to ensure it is between
2 grooves around the Dipstick. Upon Lower oil
level, oil refilling is required.
Source:
http://www.qci.net/files/5_Ton_Log_Splitter_-_USE_THIS_MANUAL.pdf
Sep 22, 2013 | Hardware & Accessories
Where do i check the hydrolic fluid
the piston contains your hydraulic fluid. By following any hose coming out of the piston you should be able to chase down the reservoir.
Jan 04, 2012 | McCulloch 4 Ton Electric Log Splitter #...
5 ton electric woodsplittr wont return to start
look for a limit switch that might have debri in it not allowing it to read properly.
Mar 15, 2011 | McCulloch 4 Ton Electric Log Splitter #...
Splitter (2 years old) motor won't shut off.
First of all, I hate to, but have to ask, have you verified oil level is up to proper level? Have you checked power at directional solenoid when handle is moved to different directions, as well as released? Obviously when handle is in stop position, there shouldn't be power to motor in either direction. I can't see exact model, or design obviously,but that would be a good place to start.
Jan 31, 2010 | McCulloch 4 Ton Electric Log Splitter #...
McCulloch 4 Ton Electric Log Splitter # FB4052 Logo
308 people viewed this question
Top McCulloch Tools & Hardware - Others Experts
ArcFlash
Level 1 Expert
Tom Chichester
joseph m fucci
joseph m fucci
Level 1 Expert
Are you a McCulloch Tool and Hardware - Other Expert? Answer questions, earn points and help others
