Question about Music
Roland xp50 low volume - Music
  • Music Master
  • 5,603 Answers
Is volume at headphone normal? Does volume control vary the volume even though it might be low?
Has any internaal settings been changed before this happened? Has an accident happened involving the output cables?
Posted on Nov 06, 2010
In my gr 33 the volume is very low. mistakenly i did a factory reset after that the volume is becomes very very low. Any solution for this problem?
There is probably both a global volume and individual program violume as well. One or both may have reset to a lower level and need to be turned up. It's also possible that the general output has a setting for line level or instrument level, which may be software controlled. Take a look through your manual to find these settings and adjust to suit.If all else fails, contact Roland Customer Service at this link for help.
Roland Company Contact Us Contact Us
Sep 15, 2016 | Roland Gr33 Guitar Synthesizer
My Roland FP8 plays very quietly through its own speakers, through an external amp & speaker and through the earphones. There is a hissing/crackling/static sound too from the speakers. Anyone
A number if things can be wrong with it, from the audil preamp to the the audio amplifier. Even as simple as a bad volume control. Does the actual noise change patterns when you move the volume?
Jan 03, 2015 | Roland Music
Sir i am from india i am purchasing roland bk5 since 1 year volume control of my keyboard does not work ...where should i buy that volume control plz help mee sir...
Might be best to contact the local service agent in India for Roland equipment.
Rivera Digitec (India) Pvt Ltd,
411 Nirman Kendra Mahalaxmi Flats Compound
(off Dr. Edwin Moses Road)
Mumbai 400011 Ph 022 24939051
If you do not have a user manual for this you can get it from
http://lib.roland.co.jp/support/en/manuals/res/62265052/BK-5_e4.pdf
Aug 06, 2014 | Roland Elektronische Musikinstrumente...
Very low volume on all drums.
I don't think there is anything wrong, it has a very low line level output intentionally. This is to minimize distortion to an amp or mixer. Mine is the same and also a different brand. It is actually made so you could play it through a stereo without damaging it.
Mar 06, 2013 | Alesis DM6 Electronic Drum Set
Hey I recently purchased a Roland TD-4 and i have no idea how to hook up an amplifier to it. My friend gave me a little amp, and i've tried many ports and cannot get it to play outloud. I'd like it...
First plug a set of headphones into the Left audio out and see if you get any sound from there... NOTE: it will only be in the left headset and this is normal. Turn up volume control... note the level will be low as this is a line output, not headset. This is a test to see if there is audio.
Sep 02, 2011 | Roland A: TD-4 Electronic Drum Set Pads,...
Hello Guys my Roland XP50 on power up show the line that the User memory is damaged . When played it is out of tune and off scale . how can this be rectified?
Press Disc Utility > Choose Option 4. SOUND > Press Enter > Choose Option 5. PRESET > Press Enter > Switch off Write Protect if its on & its Done : )
COMPLETE
Jun 20, 2011 | Music
I have a very loud hiss/buzz sound coming from my Roland. It goes away if I lower the high volume knob. This just starred to happen recently. I tried changing connections from ch1-4 but no fix.
If this ties to a keyboard, make sure the keyboard and this are BOTH plugged into the same receptacle. You should send a higher level from the keyboard (turn volume up to around 70% or so) and use less volume at the input gain of this amp. Use more at master volume if the amp has one if needed. If the hiss is there with NO input cables plugged in and input gains at 50%, that is objectionable, the amp probably needs servicing. Unused channel gains should be clear down.
Apr 11, 2011 | Roland Elektronische Musikinstrumente...
Roland juno d not pikkingup volume but very low sound comimg out on speakers.
Check if headphone output is normal... sometimes the headphone jack switch fails and doesn't send to speakers when headphones are unplugged.
Oct 20, 2010 | Roland Juno-D
Roland xp 50. everything works find except sound
Yes, he is full of it. For parts try Digikey.com, Mouser.com, and AntiqueElectronicSupply.
Jun 25, 2009 | Music
My roland xp-50 keyboard is dead.
Ok guys. Just got mine XP50 fixed with the "No Display" problem. The LCD screen was blank without text and only shown orange color. The problem is one of the capacitors on the main board was dead. I have replaced all 3 caps on the main board and the problem is solved and if you are a little handy on soldering, you can do it yourself. The 3 caps you should replace are:
- C901 (I used 16V 330MicroF)
- C65 (I used 5V 4.7 MicroF)
- C 902 (I used 16V 330 MicroF)
Apr 07, 2009 | Music
Music Logo
268 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
