Question about Cameras
I have just purchased the samsung memory cam smx-c20 and the power will not turn on. The memory card and battery are correctly installed. I plugged the camcorder in to charge it over night. When the camcorder is plugged into the wall the power works but as soon as I unplug the camcorder the power turns off and will not turn back on until I plug it in again. Please help me. Lana
  • lanablake8 Nov 06, 2010
    Thank you soo much.....
    My camcorder now works.....
    you have saved me all the time of having to go to the store and exchange the camera for a new one.....
    your AWESOME!!!!!
    Lana
  • 4,889 Answers
You have got a camcorder with faulty batteries Lana. Thats why its turning off immediately as soon as you unplug. DId you buy it new or used? Camcorders do not use the usual batteries they use Li/Ni cells that are pretty expensive. If its new you may wanna call samsung and request for replacement batteries.
Posted on Nov 06, 2010
  • 977 Answers
Hi Lana!
It sounds to me like the battery is not well seated in it's place, or that it's defective!
As it's a new purchased camera, if the battery is indeed seated well - send it back to have it replaced...
Hope I helped...
Best regards,
Pelu.
Canon PowerShot A3100 IS won't turn on
Make sure the battery is installed correctly.Try opening, then closing the cover to the memory card and battery compartment while holding pressure against it until you hear it click closed. Then try to power it up. The camera will not power up if the cover is not properly closed.
Aug 22, 2012 | Canon PowerShot A3100 IS Digital Camera
What card in samsung smx-f40bn/xaa
FROM THE OWNERS MANUAL: Using a memory card (not supplied)
• This camcorder has a card slot for access to SD and SDHC (Secure Digital High Capacity).
• You can use SD and SDHC cards on your camcorder.
- Some cards are not compatible depending on a memory card manufacturer and memory
card type.
May 19, 2012 | Sony DCR-SX40 Camcorder
My Samsung model SMX-C10RN have a message "CARD LOCKED" What to do? Please
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Aug 23, 2011 | Samsung Flashcam Camcorder Bundle Smx-f33
My camera will not turn at all. I have brand new batteries and changed them with other new batteries (just in case). Before the camera did not turn on at all it showed on the screen "problem with...
Remove the batteries. Remove the memory card.
Install batteries only, paying close attention to inserting correctly. (Possible one was put in wrong.)
Does it start?
Yes - Power off. Insert memory card. Power on. Does it work? Memory card may be defective. Try formatting it.
If cam does not power on, return it under warrenty for replacement or refund. Or warrenty repair..
Feb 06, 2011 | Polaroid i1036 Digital Camera
Shutter stays open. says turn off and on when
cameras : My Camera Freezes When I Turn It On Or Take A Picture
P, td, li {font-family: arial, u; font-size:9pt; margin-top:0px;margin-bottom:0px; word-spacing:1px;} If you camera freezes when you power it on or when you try to take a picture, you may have a defective memory card. To test your camera and the memory card, follow these steps:
  1. Power off your camera.
  2. Remove the battery from your camera. If you have a memory card inside the camera, remove that as well.
  3. Clean out any dust or debris inside the battery compartment, and then re-insert the battery into your camera.
  4. Power your camera on without the memory card installed.
  5. Take a picture.
    • If your camera takes a picture, re-install the memory card, and then go to Step 6.
    • If it does not take a picture, your camera requires service. To set up service, click the Create Online Service Request button below.
  1. Format the memory card in the camera, and then take another picture.
  2. Important: Formatting erases all pictures and other data from the card. If you have pictures on the memory card you want to keep, download those pictures to your computer before you format the memory card.
    • If your camera does not take a picture with the formatted memory card installed, replace the memory card.
    • If the issue still persists after you’ve installed a new memory card, your camera requires service. To set up service, click the Create Online Service Request button below
Jul 25, 2010 | Samsung L77 Digital Camera
I need a discriptive owners manual for Samsung Flash Memory SD Camcorder model # SMX-F43BN NTSC or SMX-F43BN/XAC all i got in the box as a manual is booklet with pictures . Thanks
You can download the complete instruction manual in PDF format by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
May 23, 2010 | Samsung SMXF40 Camcorder
I need to know if I can take my memory card to walmart and get on disk, can I free up the memory on the card or do i need to buy another card?
yes you can but you can do it your self whit the aprr
appropriated software for your cam to up load your photo to your pc then put on disk and clear memory card by formating it
hope that help
Mar 03, 2010 | Samsung Flashcam Camcorder Bundle Smx-f33
Moultrie I40 getting error code 480 and wont go into auto mode
ERROR CODE 000480 ?
If this is correct,it relates to: Camera Mod test failed;(4); and under Memory Test, 8= Comms Error.New batteries(good ones) may fix it...
It' not communicating with memory card..ck it's inserted good..press down until it stays down(press again and it will pop up.
Follow instructions on deleting internal memory before installing SDcard.
Also, make sure cam supports kind of card you're using..at 4gb and larger, they become confusing;i.e., 4/8/16mb...older cams won't support some of these. Also there are HC(high capacity); HD(high definition)don't work in these cams..
I posted this for a fix a few days ago, and it turned out to be brand new bad batteries.
Dec 23, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Camera wont turn on
  1. Step one: Reset the camera
    1. If you have an optional memory card installed, remove it. (Although removing an optional memory card is not necessary for performing the reset, it eliminates the memory card as a possible cause of the problem.)
    2. Remove all power sources (batteries and AC power) from the camera for at least 5 seconds.
    3. Reinsert the batteries and close the Battery/Memory card door and/or reconnect the HP AC power adapter to the camera.
    4. After verifying that the camera works without an optional memory card, reinsert the card, if you have one.
    Try to turn the camera on. If it now works properly, the camera experienced a temporary electrical problem and should now work properly.
    • If the issue is resolved , you do not need to continue with the rest of the instructions in this document.
    • If the is not resolved , continue with the next step.
    Step two: Check for damage or corrosion on the batteries
    1. Open the Battery/Memory card door on the camera.
    2. Remove the batteries.
    3. If the batteries are damaged or show corrosion, replace the batteries.
    Step three: Recharge the batteries
    1. Recharge the batteries or replace the batteries if they are damaged or will not charge.
    2. Try turning the camera on after the batteries are fully charged or have been replaced.
    Step four: Ensure the batteries are installed correctly
    1. Re-insert the batteries correctly into the camera by referring to the image on the Battery/Memory card door for proper battery placement.
    2. Try turning the camera on.
    Step five: Turn on the camera without the memory card
    2. Remove the batteries and optional memory card from the camera.
    3. Wait 15 seconds.
    4. Re-insert the batteries into the camera, but not the memory card.
    5. Try turning the camera on.
      • If the issue is resolved , format the memory card in the camera and then you do not need to continue with the rest of the instructions in this document.
      WARNING: Formatting the memory card in the camera will erase any images stored on the memory card. To avoid losing the images on the memory card, first save the images to a computer or another disk.
    Step six: Connect the camera to the optional AC power supply
    1. Connect the camera to the optional AC power supply. Ensure that the AC power supply is connected to a working power outlet.
    Step seven: Service the camera If the camera still will not turn on, service the camera. Cause The following conditions can cause the camera to not turn on:
    • Improperly formatted memory card - memory cards should be formatted in the camera they are going to be used in
    • Corrupt images on the memory card
    • More than 300 pictures on a memory card
    • Damaged batteries
    • Dead batteries
    • Incorrectly installed batteries
    • Damaged camera
Jul 19, 2009 | Leica C-Lux 1 Digital Camera
Samsung s1030 will not retract lense and bleeps 3 times then no response - batteries are fully charged
Try hard reset . Remove the batteries and insert new batteries . Sometimes this may work
Another chance is that lens is struck
* Carefully inspect around it for dirt or debris
* If you see any dirt or debris around the lens, use canned air to gently blow it away
* After removing dirt and debris, turn the camera on and off
This should work.
Try this alternate solution (got information from HP )
  • Turn off the camera, if possible.
  • If an SD memory card is installed, remove the card.
  • Remove power from the camera as described below:
  1. If you are using only batteries for power, open the battery/memory card door and remove both batteries.
  2. If you are using only the AC power adapter, disconnect it from the camera.
  3. If you are using both batteries and the AC power adapter, remove both batteries and the power adapter.
  • Wait for 15 seconds. Then reinsert the batteries and close the battery/memory card door or reconnect the AC power adapter to the camera. If you are using both batteries and AC power, try each method separately.
  • Turn the camera on and off. If the lens does not retract correctly or the camera does not turn on,
You need to take to service center .
Thanks for using FIxya
SAM ANDERSON
Dec 09, 2008 | Samsung Cameras
Cameras Logo
Top Cameras Experts
Damen Wong
Damen Wong
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
