Question about Pioneer Audio Players & Recorders
Pioneer vsx-d412-s multi-channel reciever very very low sound in 4 speakers one has good sound sub has good sound worked lastnight this today no one has messed with the system
4 Suggested Answers
SOURCE: Connecting a sub-woofer to Pioneer VSX-453 surround reciever
connect to same terminals as front speakers, this will also cause reduced volume from front speakers. (as per owners manual)
Posted on Nov 19, 2007
  • 120 Answers
SOURCE: sub woofer pioneer VSX-D412 5.1
you have a bad cable
Posted on Jan 17, 2009
  • 21 Answers
SOURCE: AUDIO VIDEO MULTI CHANNEL RECEIVER VSX-818V NOT
Check fuse or power supply
Posted on Oct 27, 2009
How do i connect a sub wooferto my reciever
I own 2 of these Pioneer VSX-D903S units.
The only way to hook a powered subwoofer up to a VSX-D903S is if your subwoofer is equipped with amplified/speaker level terminals on the back, in addition to the line-level input. If you only have a line-level input, do not attempt to hook it up to this receiver.
If you're lucky, and have speaker-level inputs on your powered subwoofer, you would use the amplified terminals (connect to B-channel on the receiver). DO NOT connect anything to the line-level connection.
Alternatively, you could build two unpowered subwoofers, then set the receiver's Impedance switch to LOW, then connect one enclosure to each of the "B-channel" outputs. Connect your regular left and right speakers to their corresponding "A-channel" outputs. [Impedance range: 4 Ohm minimum, 16 Ohm Maximum]
Jul 20, 2012 | Pioneer VSX-D903S Receiver
Standy light on but wont power up
You could have a blown channel. This will keep your receiver from turning on. It is a protect feature to keep you from damaging more components
May 02, 2012 | Pioneer VSX-D412 Receiver
I have a Pioneer VSX-D412 reciever, and connot get my b channel to work. Only my A channel works, and I'd like to get both or all 5.1 working. And no I don't have the manual for the system.
In case you didn't see this on the other post, it is not the function of unpaid Fixya Experts to do the web searches for or read the manuals to those who can do it themselves. Most questions submitted to us would find answers immediately if they were typed directly into a search engine.
If you don't have the manual I recommend you get it. There may be other questions. A search for "Pioneer VSX-D412 manual" finds it.
What sources fail. How is it with test tones? have you isolated (swapped) the speakers?
Here is the service manual if you should ever need it. http://www.kallhovde.com/pioneer/tricomp/Audio/VSX/VSX-D412_RRV2727.pdf
Aug 04, 2011 | Pioneer VSX-D412 Receiver
Power sub woofer is not working on my pioneer vsx-81txv everything is working all the speakers except the power sub connection at the back all i can hear is the hissing sound when i try to connect the sub...
Hissing? How loud? A sub isn't even capable of making high frequency sounds at normal volumes.
The Pioneer manual would tell you how to enable and test the subwoofer output.
Page 17 and the MACCV procedures on Page 33 (auto) or 43 (manual)
Jun 13, 2011 | Pioneer VSX-81TXV Receiver
How to hookup micro phone to Audio/video multi channel reciever model# VSX-D411
It doesn't support direct connection of a microphone.
Register and download the manual for free at hifiengine.com
Search for "Pioneer VSX-D412"
Mar 06, 2011 | Pioneer VSX-D412 Receiver
I have a pioneer elite vsx-03txh reciever and all my speaker indicators light up except for the subwoofer but my sub still works and all my other speaker channels light up for 5.1, 6.1 and 7.1 but not the...
And the problem is? Your receiver setup determines what gets sent to the sub from ANY source.
The indicators are to inform you of how many channels are encoded into the digital source. If a source-dependent LFE channel is encoded, it should light up. Check the source's setup to make sure it knows you have a sub and is configured for a discrete LFE channel.
Feb 12, 2010 | Pioneer Elite VSX-03TXH Receiver
Sub woofer
The subwoofer is totally independent from your Pioneer VSX-D412. You can check if it works like you did with a finger on the hot point of the RCA cable (not very good test, as you will hear noise and can't say if that means it works OK) or better connect a known receiver to the speaker connections in the sub and test to see if it’s working properly.
Regarding the receiver, you may not have enabled the VSX to output to the sub. Read the manual on how to check for that. Only Dolby Digital 5.1 signals will allow the sub out, in a receiver of this level. It normally will not let you use the sub in stereo mode. Some more complex units will allow you that, but I believe not this model.
Good luck
Nov 01, 2008 | Pioneer VSX-D412 Receiver
I got the same issue. But, I go ahead hooked it up two banana plugs on teh VCR outlet. It works fine on my Cerwin Vega Sub.
Nov 08, 2007 | Pioneer VSX-453 Receiver
269 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
