Question about Olympus SP-350 Digital Camera
Camera gets vertical lines in the viewer, then freezes
This happened to me when I first used it, so I thought it might be a bad card or battery, so I changed both. However, the problem has re-occurred. I put in a fresh CRV-3 battery, then tried with fresh AA's and used two different xD cards. Still have the problem. Please help because I need to get the pictures off the card and don't want to have to buy a card-reader and it happens when trying to download.
  • 1 more comment
  • bonzo23 Jun 16, 2008
    The lines appear on the screen spontaneously. When the lines appear, all camera function stops.
    I will double-check, but I don't thinkit is the case that the grid lines are enabled. The lines are only vertical lines. The lines are not solid, but look more like the pixels in the column are being scrambled. It starts with one line, then others continue to show up in no particular order until the display also freezes. Once one of the lines shows up none of the camera functions work and the only way to restart the camera is to remove the battery.
  • Tim Babcock
    Tim Babcock May 11, 2010
    When you take a picture, do the lines appear on the screen?
  • 2,794 Answers
If your going through that kind of trouble you should take into a camera store and have them take a look at it.
Posted on Jun 16, 2008
    Guru:
  • 1,894 Answers
I think the grid lines have been enabled.
and so disable it to having the problem solved
Geforce 9500 gt / Windows 7 Home, 64bit / 3D Games freeze computer
I would try other Nvidia drivers, maybe revert to an earlier driver. Don't get Nvidia drivers from MS Update, go to the Nvidia site to find drivers and suggestions.
Oct 02, 2017 | Computers & Internet
My Fuji Finepix s5600 camera started displaying "card error" when I tried to take a pictures. I entered the Fine Pix Viewer, clicked on the DCIM folder, and then when I clicked on the 100_Fuji...
Try to use you camera to format the card maybe it will be get better, else you can use a card reader to read the card and see if it's all right, or you can try to use the card with other cameras and see if it's OK. It seems your card you have used well for some time, so it won't be the wrong card type. Else you have to check if the card is one of the types which your camera support
Aug 31, 2011 | Fuji FinePix S5200 / S5600 Digital Camera
Need to replace the video card on dell dimension 8300 computer. Monitor has vertical lines on it. Changed the monitor - same thing happens. If you hit the top of the tower, it will stop with the lines...
seems like you might need to replace the video card. If you have any spare compatible card that you can use i would test it with that. If not you can find one for about $50-$199 depending on specifications at most retail stores or online.
hope this helps.
Jun 08, 2010 | Dell Computers & Internet
I have vertical lines on screen I have changed the whole screen assembley but lines are still thers , exactly in same place
Hey There,
The reason this happens is because the graphics card is either loose burned out or jsut needs to be cleaned... to clean it use a pencil rubber in the gold tips that connect it, blow on the card to remove any dust build ups and reconnect the graphics card when done (make sure its clipped in properly).... different brands of computers will do different things such as the different coloured lines and screens flashing red. My dell latitude 630 had green and blue verticle lines. Just follow what i said and it should be fine
Hope this will help you in Resolving the issue with the vertical Lines on the screen.
Cheers!!!!!
Vivek
Feb 14, 2010 | HP Compaq nx6325 Notebook
Screen stays black
dear it has nothing to do with on and off its simply a setting problem
May 05, 2009 | Kodak EasyShare Z1275 Digital Camera
Game screen freezes and there are white vertical lines on the tv
i dnt know about the vertical line but i had the same problemand i solved this by taking it to my nearest computer shop its as simple as that
Apr 14, 2009 | Microsoft Xbox 360 Console
Camera Keeps freezing/turning off
Sounds like the camera is writing to the CF card. If this is after taking several shots, even worse in continuous mode. That's why it won't shut off or anything, it has to finish that before it will shut down. If you have access to one try a different card. Remember to reformat it in this camera. Page 38 of your manual. If that works for you take the card into a camera shop and ask them if they will do a low format a newer camera like a XSi, then reformat it in your camera again before you use it.
Oct 26, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Screen crashes
seems like a problem with the graphics card or the memory in ur system. try cleaning and reseating the graphics cad and the ram.
Dec 10, 2007 | Nvidia IBM Quadro4 980 XGL, AGP Video...
Card Error Message keeps coming up
Please repost with the kind of card you are using to help me help you.
Aug 02, 2007 | Fuji FinePix A205 Digital Camera
Olympus SP-350 Digital Camera Logo
70 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
