Question about Dishwashers
Dishwasher WHIRPOOL WP 79 LYMPIA F4 and beep signal appears few minutes after start the program.
  • 10,515 Answers
F4 is typically related to a drainage problem.
If the water is not draining from your dishwasher, verify the following:
Verify that there is not a clog in the drain hose or air gap. This is typically the reason that a dishwasher won't drain and the clog is usually where the drain hose attaches to the garbage disposal or sink drain pipe. Remove the hose and clear any clogs, then reinstall.
Verify that the pumps drain impeller is working. You can reach the impeller from inside the dishwasher after removing the lower rack, spray arm, and arm support. This typically involves removing a few screws. Once upper parts are removed, inspect the drain impeller, which pushes the water toward the drain port, for any cracks or missing blades. If the impeller is defective, the water will not drain properly and you would need to replace it. Inspect the sump area for any debris or broken glass that could be blocking any ports.
Verify that the drain valve is working; many are controlled with an electric solenoid that opens the valve, sending the water to the drain. There is a chance that the solenoid or the diverting lever could be stuck which would prevent the water to drain. If so, try to free up the solenoid and lubricate the lever. Otherwise the solenoid or pump assembly may have to be replaced.
Verify that the motor is turning/ working and verify that there is power to the motor. If the motor hums but doesn't turn, it may need to be replaced. Motors can get stuck if not used regularly. If the motor is defective, the water will not drain and you would need to replace it.
There are ways to test the pump and motor with a multimeter. If you are not comfortable with doing this, you may want to have a plumber test it for you.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 06, 2010
  • Anton Borg Olivier Apr 10, 2012
    Water enters but drains out before sprinklers start
Does anyone know what the F4 fault is on my kitchen aid dishwasher? I can reset it and then start over or select another program, although after approx 1 minute the F4 error code comes up and I cannot see...
Check the drain hose. When you turn on a dishwasher, the first thing that it does is check the pump. If there is a drain issue then it stops.
Mar 02, 2014 | Dishwashers
Constant beep, stops and switch to rinse program
Can be related to a fault in the program controller unit as none of the preset programs are working bbut the fault appears universal in all the programs.
The best you can do is to remove the panel and reset, check on the inlet valve and the sparying arms and pump. check for clogging in the drain or the pump which seems to set off the alarm.
Nov 12, 2011 | Dishwashers
My dishwasher whirlpool wp 79 lympia keeps on beeping due to a drainage block. But now I can't stop it beeping or to reset the dishwasher in order to start the program from scratch
Unplugthe power cord to your dishwasher. You can do this by manually removing thedishwasher from the wall and unplugging it, or you can flip the power switch toyour kitchen at the circuit breaker (although you will need light to drain thedishwasher hose). 2 Put on your gloves,and, using your screwdriver, unscrew the screws from the kick plate of yourdishwasher. The kick plate is the panel just below the door of your dishwasher.3 Place your bucket on the floor in front of the dishwasher. 4 Unhook the drainhose by pinching the ends of the clamp and sliding it down the hose. Remove theother end from the pump. There will be two hoses in your dishwasher. The drain hoseis the one that leads from the pump to the underneath of your kitchen sink. 5 Pointthe hose into your bucket to drain any debris. Twist and scrunch the hose tohelp remove the waste. 6 Test the hose by running water through it, and thenreattach your hose in the same manner in which you detached it from yourdishwasher.
May 11, 2011 | Dishwashers
Beeping sound when cycle is finished just started after 8 years. how do I turn it off?
Welcome to FixYa.
I think can answer your question..."beeping sound when cycle is finished just started after 8 years. how do I turn it off?"
Follow these steps...
**How to Operate the Cycle Completion Signal**
1. Open door, hold down program button (see
Beeper Table below) and simultaneously turn the unit "ON".
MODEL Program BUTTON
SHU 9950 Delay Start Hours
**SHU 9910-9920 Delicate/Econo** should be yours
SHU 8800/8810 Quick Wash
SHV 6800 Delay Start Hours
SHV 4800 Delicate/Econo
SHV 4300 Delicate/Econo
2. Release program button.
a. For SHV 6803 and SHU9950 models:
The display will blink with a code of "0", "1" or
"2". You are in program mode.
? If the display blinks with a "0", you will hear
no signal (indicates OFF).
? If the display blinks with a "1", you will hear a
LOW volume signal.
? If the display blinks with a "2", you will hear a
HIGHER volume signal.
b. For all other models with the beeper
function:
? If the machine beeps, then the Cycle
Completion Signal has been enabled.
? When you push the button again and it does
not beep, it means that the Cycle Completion
Signal has been disabled.
3. To change the program, press the program
button until the desired setting is selected.
4. Turn the Dishwasher off to take it out of
program mode.
* At the end of a wash cycle, the beeper will sound
off two times, and again every 15 minutes until the
dishwasher is turned off.
Hope this answers your question and provides you with what you needed.
Thank you for choosing FixYa and good luck.
Please take a moment to rate the solution provided and a short testimony if you feel it's warranted, but also let me know if you require further assistance.
Regards,
Macmarkus :)
Nov 06, 2010 | Bosch SHU9915UC Dishwasher
How do I turn off the annoying beeping alert after the cycle is complete?
Hello Joanna,
Welcome to FixYa.
I think I can answer your question..."How do I turn off the annoying beeping alert after the cycle is complete? "
Follow these steps for the SHV6800 will be the same...
**SHV 6800 Delay Start Hours**...should be applicable to yours, let me know if not.
LOW volume signal.
function:
program mode.
Regards,
Macmarkus :)
Oct 18, 2010 | Bosch 24 in. SHU66C05 Stainless Steel...
How do you disable the cycle completion signal/beep on the Bosch SHU9915UC dishwasher?
Welcome to FixYa.
I think can answer your question..."How do you disable the cycle completion signal/beep on the Bosch SHU9915UC dishwasher?"
• If the display blinks with a "0", you will hear
• If the display blinks with a "1", you will hear a
LOW volume signal.
• If the display blinks with a "2", you will hear a
function:
• If the machine beeps, then the Cycle
• When you push the button again and it does
program mode.
Regards,
Macmarkus :)
Oct 07, 2010 | Bosch SHU9915UC Dishwasher
Hi,\r\n
yes you need to reset dishwasher to time fill.turn off the power button wait 10 sec,push and hold the programme and start buttons then turn power back on.hold buttons down until display lights up then release them.press programe button until 4 shows in display,then press start.test dishwasher. F4 is an inlet fault.
Jun 07, 2010 | Asko 24 in. D3350 Dishwasher
I have an error code f4 on my whirlpool adp 8966 dishwasher can you tell me what it means please
F4 indicates draining failure.Your washer drain pump starts and after 4 minutes the OWI(optical water indicator) detects that mashine is 'not empty'
Posible mailfunction reasons:
The drain pump must be defective/blocked
The siphon would have got closed
The control board would have got damaged
OWI defective
Apr 04, 2010 | Whirlpool 24 in. ADP6940 Dishwasher
Dishwashers Logo
913 people viewed this question
Top Dishwashers Experts
Owen Barnes
