Tuner not selecting stations reliably, and makes "crackling" through speakers.
  • 1 more comment
  • Robert Wilson Nov 06, 2010
    Model No. of unit is WPSS1A.
    Don't know how old unit is. Just purchased on Ebay! May not have been used for some time. Looks to be little used, and generally in good condition. Perhaps could purchase another cheap one for spares, and hope the Tuner is good?!
    Thanks for reply. Not what I wanted to hear, but probably correct! Will use C.D. Player, if Tuner doesn't improve. Thanks.
    President:
  • 2,777 Answers
I need to know what make / model of device you are working with here that is causing this issue. I will be glad to help you but have no idea where to start here with information about what it is that is not working.
Please just reply to my answer here and I can help you.
Thanks,
Tim
Posted on Nov 06, 2010
  • Tim Grayson
    Tim Grayson Nov 06, 2010
    Ah ok this is one of these Jeep radios then, correct? It sounds like the tuner in the radio has failed - I have seen it a good number of times in these radios. How old is this unit? Finding parts to repair one of these radios is extremely difficult to do. If you have tried moving the radio around to see if you can improve reception and nothing makes it better then unfortunately that would confirm the tuner itself has gone bad.
    Thanks so much, let me know what you think here and what you find...
    Tim
  • Tim Grayson
    You definitely could... if you just purchased this on ebay you can actually return it for a full refund though as long as it was less than 30 (I think it may even be 45 days now) days ago...
    That is what I'd recommend you do if possible and get another one, or personally I recommend you avoid these Jeep radios altogether as they are known to use some of the more "inferior" parts out there and generally have more problems than other radios.
    Tim
My Marantz SR6200 is not playing loud and it only plays in analog and when it does and I select tuner cd or Dvd will play, there is also a little crackling on the front right speaker. please if anyone...
Hi, maybe you have speakers misconnected or speakers wiring with short circuit (joined bare cables), please check them because if this continues for a long time, your device could get damaged.
Oct 20, 2013 | Marantz SR-6200 Receiver
"no signal" on display, just static
Check the input selections, and make sure that the selection is right. Try connected to external antenna, select the input to TV, and make an auto-tune function, and see whether all the stations can be received or not. If not, the tuner of the TV has to be suspected.
Apr 26, 2012 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Crackling and saturation in frequency of surround speakers
I have the same tuner with the same problem. I have 2 pairs of Bose Acoustimas speakers and a pair of their sub woofers. I found it was the vibration from the subwoofers were causing so much vibration even using monster wire the crackling was caused by wire vibration at the speaker or subwoofer. if you are using twisted wire with a banana plug on the end or straight twisted wire into the speakers the constant vibrartion eats into the wire. Just pull the wires out re twist or tin (solder) the tips or move to a different location on the banana plug and really twist it will getting a bite into the wire. If you are using straight banana plugs use a screwdriver in the 4 slots to make them fatterso they stay tight. if they are RCA jacks pinch down the 4 outside tabs so they grip harder. Viva La France.
Feb 12, 2012 | Onkyo TX-SR503 Receiver
My Denon Audio precision am fm DRa 435R Reciever will not stay on station very long. After about 30 or sometimes 45 minutes it get off station. I have it set to a local FM Station, 97.9 and it plays good...
OK,this is a fairly common problem with digital tuners, I get them from time to time in my shop, you see, what is happening is the voltage that's used to tune the set, usual;y stays rock solid, your device however is drifting off station due to this voltage changing, usually it is in the powers supply or the actual tuner itself. It can be bad capacitors, bad IC's, bad transistors, bad tuner module. Sometimes it maybe a "Dry Joint" too.
The only fix is either a replacement PSU or Tuner or indeed maybe both? One simply cannot tell exactly without examining the unit.
You need to take this unit into a Denon repair center and ask for a "Quote" as to costings etc. Once appraised of that one can proceed from there?
Contact a Denon head or local office and ask them there, for a referral to an authorised service center.
Jul 18, 2011 | Audio Players & Recorders
Crackling sound in speaker
These speakers have a history of being blown if played too loud. Apparently the higher quality CX version are reliable. If the lows are what is crackling, the voice coils are probably cooked causing it to drag the pole pieces.
Apr 28, 2011 | M-Audio Studiophile BX5A Deluxe
Am/fm tuner is not working, there is no sound
Press teh AB speaker switch to see if it is working now, assuming you do have a station selected on your tuner.
Mar 06, 2009 | Yamaha RX-V663 Receiver
Speaker not working
the crackle sound is the elctric current from your ignition switch flowing into your speaker wires, if the ignition(key) already is on you dont hear it you say, so it must be that the ignitionwire at some point makes connection with your speakercable.
Feb 28, 2009 | 2003 Honda GL 1800 Gold Wing
It beeps when changing tuner
does it only do it on the subs/speakers or does it do it on all the speakers? If it does it on all speakers it's the stereo you have it's made like that and is suppose to beep when changing the tuner.
Oct 10, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Snap, crackle sound from Sanyo TV
It sounds to me as if possibly ya Main IC Amp Chip & OR the Output Capacitors are failing... Sometimes it is a sign of a power supply on it's way out... Either way it's time for a repair shop quote. Either that or it may be the speakers crossovers... to check this, if you can, try another set of speaker... see if problem is still there. If it IS, then it IS most probably as I said above.. If NOT then it may be one or both of the "Crossover Network" in each speaker...
Sep 01, 2007 | Sanyo AVM-3659S 36" TV
Crackling Sound From Subwoofer
Check any wiring coming or going to the subwoofer. It sounds like it could be a loose connection.  Is there a LFE or bass boost knob on your subwoofer? Does turning that up/down cause the crackling (if it exists). If so, you could use some tuner cleaner to clean the contacts on the potentiometer knob.
If the crackling is on the subwoofer only, it might be damaged from bottoming out.  See if you can remove the baffle or grille covering the woofer and inspect for visual problems. You can also try to lighly push in and out on the subwoofer to hear if it makes any scraping sounds. If so, it is definitely damaged and the driver will have to be replaced.
Mike
Jan 21, 2007 | Altec Lansing 221 Computer Speakers
73 people viewed this question
 Grubhead
Grubhead
