I bought a GE WBVH5300KOWW front load washer from Home Depot 7 months ago. Today it stopped working and is giving error code E30. It starts ok but it shuts off before the tub starts to fill with water. In service mode it performs all the tests ok except that it makes a tapping noise at a few points during the overflow test. GE sutomer service says it's out of warranty and the repair is going to cosst a lot of money that I don't have. Hope you can help. Thanks in advance for your help.
SOURCE: GE WBVH6240
All,
There are three screws under the plate beneath the door. Remove these three screws and remove panel. Immediately you will see a removeable plug about 2 1/2" in diameter made of white plastic. This is where your problem lies (or at least one of them). CAUTION - before you remove this plug, put a bucket under it because water will come out. After you unscrew the plug completely, pull it out toward you. You will no doubt find many items that washed out of your cloths. I found legos and coins tangles up with strigs and lint. The entire area was completely plugged. The coins were probably the source af the stains we had on our cloths as they were all black from the water and soap.
The pump on mine burned out and I am trying to replace it. Then I will sell this junker.
I hope this helps some of you. Please advise.
Posted on Aug 11, 2008
SOURCE: GE Front Load Washer
Removing the lower front panel (3 screws nearest floor), and opening the round, white water pump filter cap (be ready to catch about 2 gallons of water!) is the best place to start. All you need is a Phillips head screwdriver and a large, flat pan (deep turkey tray works well)!
YOU WILL NOT BELIEVE what I found in my filter housing this morning (see photo below)!
The washer is working fine now, although I may go back and remove the entire water pump so it can be dismantled, thoroughly cleaned, and reinstalled.
Posted on Sep 22, 2008
  • 135 Answers
SOURCE: error code e30 see user guide .comes on and stops washing do not have user guide
E30 is a motor problem which is most likely brushes need replacing.
Hope this helps & Thanks for using Fixya.
Posted on Jan 18, 2009
  • 41 Answers
SOURCE: Kenmore 417. 4405200 Front Load Washer error code E43
It's a bad wax motor inside the door latch. The diagnostics are buggy and do not test it properly. It should measure about 1.5K ohms, and when 120 VAC is applied to it, it should extend in about a minute. Part number 12002535 is $10 to $15.
Posted on May 14, 2009
  • 212 Answers
SOURCE: Code F43 on frigidaire front load washer.
motor control possibly bad
Posted on Jun 20, 2009
Frigidaire affinity washing machine E30 error message
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
Nov 12, 2013 | Frigidaire Affinity ATF7000E Front Load...
Clothes smell after drying
I don't think the problem lies with the dryer, I would suspect the washer has mold, this is especially true on front load washer, they make products designed just for this problem, check with a large retailer, not sure who makes the mold and mildew remover, I think Home Depot or Lowes may have the product or know about it..
Jan 29, 2012 | GE Profile DPXH46EA Electric Dryer
I have error E48 on my GE front load washer
you can down load a file to show you how to put your washer into a srevice test mode
at appliance aid .com in the washer repair aid section line 7 you will see "GE LITTEL SWAN FRONT LOAD WASHER" click on that and you will see two down loads one of them will give you
directions and a list of the codes.
Mar 30, 2011 | GE WSXH208A Front Load Washer
My hotpoint washer/dryer keeps coming up with code e30 see user guid and stops washing,what does that mean
Error code E30 indicates motor tachometer failure.
There is a loss of signal during tumble or spin.
Check your user guide.
Dec 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
HE2 front loadable washer doesn't move fm wash to rinse to drain
Sounds like the door lock. It will not advance to spin if it thinks the door is open. There is a instruction sheet inside the unit behind the lower panel. That will give the error codes for the flashing lights.
Sep 04, 2009 | Kenmore Elite 45986 Front Load Washer
E30 error code
Error E30 is a motor drive problem. Would check motor brushes as most likely fault.
Dec 16, 2008 | Hotpoint Ultima WD72 Front Load...
Zanussi zwf1631w jetwash front loading washing m/c
had to call an enginer out, the problem was down to a faulty motor rota, to identify if e30 is this fault, rotate the drum (so the motor rotates) and try to start the m/c. if it runs ok you know to change the rota. hope this may help someone
Sep 12, 2008 | Zanussi ZWF1440 Front Load Washer
Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Extra Heavy Duty Calypso Top Load Washing Machine
I had this problem and did not have the time to fix it myself so I called Sears. The "tech" looked at his laptop, called his "supervisor" a couple of times and told my wife that both control boards needed replaced at a cost of over $500. The manuals, with testing procedures for the inclined, are on the inside, front cover.
The CE error is a communications failure and on mine it required replacement of the AVS board. I bought the part at a local supply house and replaced it myself for about $175.
Jan 23, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
195 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
