I dont know hoe to operate Videocon digi nemo fully automatic washing machine.
2 Suggested Answers
e-Guru
  • 3917 Answers
SOURCE: My Videocon Fully automatic top
Hi
E9 means the water level sensor is defective or the pipe connected to it is faulty.Generally error E9 means a problem with your water pressure sensor. do you have water in the tub? Check the sensor by pulling the hose attached to the bottom part of the tub and blow on it and test the terminals of the sensor if it will close or open.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Aug 02, 2011
Digi marine videocon water not draining pl help
You need to run spin program again, it may need doing several times. Usual cause is over fill machine with washing.
Mar 04, 2016 | Washing Machines
Machine stopped in mid cycle with the drain/unlocking light on. No error codes. Machine goes directly to the drain/unlocking position after start. Will not fill, spin, operate. Any ideas?
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 01, 2013 | Whirlpool WFC7500VW Washer
My videocon fully automatic washing machine (45FDx) is 7 years old. It is continuously showing E2 error. I have called the company technician but not of much use. Can u help pleae?
This can be due to a error in the control panel, You can switch off, remove the front panel and check for moisture on the panel, if so use a dryer to ward off the moisture. Also check the connections on the board. If the fault reoccurs then you might need to replace the panel board.Make sure the door switch, inlet valve and drains are clean.
Feb 12, 2013 | Washing Machines
Videocon washing machine model V NA-811 fully automatic body is rusted i would like to have a new body . where can i get it please inform me
Hi I have a Videocon V NA 811, don't know where to put the detergent and what is that small compartment with a net for
Nov 20, 2011 | Washing Machines
My Videocon Fully automatic top load washing machine (Digi Dolphin Dlx 7 kg) gives E9 error and stop functioning
Hi
Aug 02, 2011 | Washing Machines
I own a lg fully automatic washing machine front loader (model:WD-8074FHB)i dont have an owners manual. My question: There are 3 sections. 1st section is for washing detergent. Which of the other 2 are...
Hi Anna, As you face the machine the left section of the draw is for the main load washing powder, the middle section is for fabric softener and the right section is for the pre wash powde.
Hope this helped :-)
May 21, 2010 | Washing Machines
Open Questions:
Washing Machines Logo
52 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
paul
paul
