Question about Rinnai Heating & Cooling
Heater won't start error code 11
The haetar has been reliable for the last 5 years but has developed a fault where it won't idle properly when the room temperature equals thermostat setting and shuts down displaying error code 12. Up until today it could be t re started by setting a higher temperature.
The fault today is that it will not start at all and displays error code 11
  • msb63 Jul 10, 2008
    heater wont start. Hear clicking sound but does not ignite then displays error code 11
I had the same problem and the heater started working after I cleaned both filters, the bigger one that can easily be taken off and the smaller one that needs to be screwed off.
Posted on Jul 15, 2008
Fault code 11 flashing started when the meter was replaced outside don't have a manual to tell what it is
Apparently, when they installed the new gas meter, they didn't purge all the air out of the gas line to your heater. So gas is not getting to the heater. Fault Code 11 is an Ignition Failure.
To help you even more, I am providing a link to your Owners Manual that you can download and print for future reference. http://www.rinnai.us/documentation/downloads/ES38_1004RFA_Manual.pd
Hope this helped to solve your problem. Please be kind enough to let me know.
Mar 10, 2011 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai inbuilt lpg gas fireplace IB35ETR wont ignite. Has good spark but heater does not ignite. LPG is full to large tanks. Other gas appliances are working fine.
You don't mention any error codes displayed. If this is the case I would start with a new main PCB. It should try and light for approx. 10 seconds and then go to lockout with an error code 11 if it was a gas supply issue. This is all controlled by the PCB hence my opinion on a PCB fault.
Sep 16, 2010 | Heating & Cooling
My rinnai comes up with a code 11 when i try to start it. if i try it about ten times the main valve opens and runs fine. but untill that point it doesnt start. any ideas?
Mysolution relates only if you are on LPG/bottleg gas. I have had many problems with the gas regultor actually on the initial supply line near the bottles sticking. Error code 11 is usually simply a gas supply issue and not a fault with the heater itself. Just rule out that before you start messing with the heater itself. Causes inside the heater would be either gas valve (unlikely) or PCB. Both are not normally intermittent. Try running something else on gas if you have anything and then turn on the heater.
Sep 15, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai 1004 F Error Code 11
Code 11 is that the unit is trying to light but does not sense a flame after 5 seconds. Usually means you have run out of gas if you are bottled gas. Check your bottles are turned on if you are on LPG, you might need to change over manually. Have you anything else on gas?
Jul 01, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Heater goes out after 20min error code 12 appears
Definately a gas supply problem. If it was an overheat you would get a different code. Error code 12 meant a flame was there but then went out. The code 11 meant tried to light but no flame sensed. Error code 12 on heaters and Infinites is nearly always a fault on the gas regulator at the bottles. Sure I recognise your company name from up in Queensland. As you might know we hae had problems with an oily residue in some regulators for ages. I am recommending going away from two stage regs and spliting them up with a seperate first stage and then a second stage. Bit more expensive by zero call backs.
May 24, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
I used my heater last winter with no problems and
The red light is an indicator...it is usually flashing a certain number of times...there is a sticker on the furnace or in the fan compartment or in your Users Manual that will describe the fault code associated with the red light....more info is needed.,...what code is it showing???
Oct 20, 2009 | Heating & Cooling
Code 11 on Rinnai Avenger 25 gas heater
11 means no gas / failed to ignite - check the bayonet is fully plugged in properly, they can be hard to plug/unlpug - otherwise you wilol have to take it in for service.
Aug 19, 2009 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
Marvin 5460
Returned to home depot. Fan was broken.
Feb 08, 2008 | Marvin Quartz Radiant Heater
Error code 12
Error code 12 is a genaric "Flame Failure" code. I suspect that the flame is not hitting the flame sensor or that the sensor is bad. You will need to get to the sensor located on the far left hand side of the unit. If you have the owners manual, it's part #123. Remove it and clean it off. Make sure it is placed back in the heater properly aligned and all the way in. Then try and light it. If it does not stay lit, it may need to be replaced but check out the burner tray for debris not allowing the flame to travel all the way to the sensor. You will have to remove many parts to get to the burner assembly.
Jan 05, 2008 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
Heating & Cooling Logo
476 people viewed this question
Top Rinnai Heating & Cooling Experts
paulcarew
blender719
Level 1 Expert
Kenneth Wilson
Kenneth Wilson
Level 1 Expert
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
