Question about ViewSonic VX922 19" Monitor Flat Panel
Vx922 worked with xp not now without so messing around, fine with vista
I am dual booting this pc. 1 xp pro hard drive, one vista ultimate drive. I have not had problems with this config for quite some time,..until now. With xp pro after monitor goes inactive or after a reboot/restart my vx 922 monitor is inactive. I found that booting my vista drive to desktop then restarting to my xp drive would boot to active monitor in xp. At this point, it seems that is degrading. My percentage of active monitor in xp per boot sequence is decreasing. ::((((((((( I hope viewsonic has a solution. It seems like a driver issue but I'm current on each drive/os.........
  • 1 more comment
  • e portele Jun 15, 2008
    No. The vx922 is a 19" lcd monitor for a pc.
  • Anonymous Aug 26, 2008
    I have a similar problem. Basically my monitor does not work until it has been on for a while and has warmed up, then it works fine once i reboot it a couple of times.
  • Anonymous Mar 28, 2014
    My monitor will work for a period of time and then go black. It is not associated with inactivity. If I unplug and then plug back in the monitor will turn back on.
  • 106 Answers
Is this a laptop by any chance?
Posted on Jun 15, 2008
Needs driver for vista or win 7 Sony VRD-VC10 DVD±RW Dual Layer Burner
Sony does not support this burner for any operating system for Win2k and XP. The VRD-VC30 is supported in Win7 but no earlier models (from the Microsoft Compatibility Center). The Vista Compatibility Center lists the VRD-VC20 as unknown for Vista support.
There are work-arounds. Install XP as a virtual computer or in a dual boot configuration on your system and install the hardware on the "XP box". If you have Win7 Pro or Ultimate, you can download and install the XP mode for a free virtual computer. (This requires you to download two programs from Microsoft and install them (Virtual PC and the XP mode itself). Otherwise, you will need a valid XP license to install in the virtual computer software. The dual boot may work better for you since virtual computers can't share files from the main computer directly. They need to be transfered to external media or a different partition or disc that unmounted from the real computer and mounted on the virtual computer.
I hope this helps.
Jun 25, 2010 | Sony VRD-VC10 DVD±RW Dual Layer...
Trying too dual boot xp pro on toshiba tecra m5. conflict image of original xp pro, in slim select bay hdd. Need help with settings so as the same op system can be used on both drives.Any help would be...
in order to dual boot something.... you need to partition the hard disk... if there's only 1... you need a program that will create another partition from drive C...
for example the size of your Hard disk(drive C) is 160gb
you need a program that will split 160gb into 2 it should come out and you will have now two drives (C & D) with a size of 80gb each...(It depends on how large you want the other drives to have)...
the program is called Partition Magic 8.0 if you want that program.. i can send it to you... just contact me in my yahoo messenger... derick_10_02@yahoo.com
now it's time to install the Windows XP in each drive then you'll have a dual boot... or you can install Windows Vista on the other drive... so therefore you'll have Windows Xp and Windows Vista in one PC...
hope it will help you... tnx
Jun 07, 2009 | Computers & Internet
I'm using win2k pro sp5 can i do a vista upgrade?
How to dual boot Vista and XP (with Vista installed first) -- the step-by-step guide with screenshots
UPDATED | Got a Vista PC and want to install XP so you can dual-boot between them? Here's how to do it, in an easy, step-by-step format. Page 1 - Intro
Scenario: You want to install Vista on your PC alongside your XP installation, on the same drive. You have installed Vista already. (If you have XP installed first, check out our earlier tutorial on how to dual boot Vista and XP with XP installed first.)
Tutorial Summary: We need to shrink the Vista partition on the hard disk and create enough space for an installation of XP. This can be done in three ways - using the GPartEd Live CD, the DISKPART utility on the Vista DVD or the Vista Disk Management GUI - and we'll cover all three. We'll then install XP and install EasyBCD to reinstate the Vista bootloader which will be overwritten during the XP installation, and then use EasyBCD to configure Vista's bootloader to boot the XP partition.
Updated September 2008: This is an updated tutorial, based on our first Windows Vista/XP dual-booting workshop. The main differences are that we are now using Windows Vista SP1 and Windows XP SP3. EasyBCD has also been updated and this makes some of the steps in our first tutorial redundant - the whole process is now easier.
This tutorial has been tested on a VMWare 6 Workstation.
VISIT THIS FOR THE COMPLETE TUTORIAL :
http://apcmag.com/how_to_dual_boot_vista_and_xp_with_vista_installed_first__the_stepbystep_guide.htm
Mar 16, 2009 | Microsoft Windows Vista Ultimate Edition
Invalid partition
im sorry you are having this problem, i too have done the same thing once on my hard drive, here is what you have to do, now that you have xp installed on the hard drive you now have to reinstall vista to a new folder and once its installed it will then allow you to dual boot vista/xp, this is exactly what i did so im on xp right now with a clean install of vista just hangin around
Dec 12, 2008 | Sony VAIO PCV-RS520 PC Desktop
Dual booting
vista doesnt alloow users to intall operating systems prior to it. thats the problem.
but theres a software named 'Vista boot pro' it can help u booting it.
Nov 01, 2008 | Microsoft Windows Vista Ultimate Edition
WI-FI not working
If your computer came with Vista there are no drivers for your wireless card. You can partition your hard drive into 2 logical drives and load Vista on one and XP on the other in a dual boot configuration. Then you will need to purchase an external USB wireless thumb adapter for accessing your wireless networks when you are using the XP operating system. When you boot in Vista your computers wifi will work fine. The hardware manufacturers are being forced by Microsoft not to release drivers for XP for new equipment under threat to pull licensing for Vista. This is the only way to get around it, unless you are capable of writing your own .inf driver files for the hardware. If you need my help feel free to contact me and I will help you further. This is Microsoft's way of strong arming everyone to migrate to Vista. I run dual boot configurations on all my equipment because some of my expensive tech software only runs in the XP environment. Vista is a powerful operating system if you have the equipment designed for it. It's a shame the removed so much of the backward compatability though. My e-mail address is geokohler@gmail.com if you need more help send me your number and I will call you for free to discuss your options in more detail. Please take the time to rate this fixya and I will provide you with free support whenever you need it directly.
George
Aug 19, 2008 | Acer InviLink 802.11b (91.49C10.002)...
Without warning or prfevious problem computer wont boot with any picture. I have been building gaming sytems for at least 10years and have trouble shooted without remobing from case. Sytems AMD Dualcore...
Went further in troubleshooting by removing the components one by one. Turned out that the soundblaster fx card needed to be reinstalled after a normal boot sequence was completed.
Remembering that Creative and vista have had problems in the past it was the first component removed and wala.
Jul 14, 2008 | Computers & Internet
Not possible xp installation
How to Downgrade Vista to XP Downgrading from Windows Vista to Windows XP is almost like installing Windows XP for the first time. You should take all the normal precautions like backing up all your important files and record important passwords in a different place, preferably on a CD. When you downgrade from Windows Vista to XP, note that Windows Vista will be completely removed from your system.
(Note: There is a way to have both Vista and XP in a dual boot configuration, but that's an option for more advanced users. See Dual Booting Vista and XP for more info on that.)
Before you begin the XP installation, make sure that the necessary XP hardware drivers are available, or included on the XP disk provided by your PC vendor. If in doubt, check the vendor's website or poke around with your favorite search engine to see if others have attempted the XP install on the same hardware. You may be able to install XP without all the needed drivers, but some hardware may not work afterwards.
Also, make sure that you have a genuine Windows XP CD before you begin the downgrade. Be sure to read the section earlier in this article to see if you qualify for a low/no cost XP recovery disk from your PC vendor. If not, perhaps you have an XP disc that came with another computer. If you've upgraded an existing computer from XP to Vista, the best choice would be the XP install/recovery disc that came with that computer. One some PC's the vendor doesn't ship a CD, but the recovery CD can be created from disk images on the hard drive. If all else fails, you can always buy a copy of Windows XP on Ebay. Just be sure it's a legal, licensed copy.
Follow these steps to install Windows XP on your Vista machine:
  • Insert your Windows XP install/recovery CD and restart your computer.
  • Install Windows XP normally, providing either the product key that came with the disk, or the one you got from Microsoft customer support. If the installer warns you that another copy of Windows is already installed, don't worry. Remember, this install will wipe out your existing Vista installation.
  • Activate your copy of Windows XP when it prompts you to do so. If you run into the "already activated" problem, you can use the option to activate by phone.
  • If you own Vista Business or Vista Ultimate, explain to the rep that you want to use your Downgrade Rights to install XP Pro.
  • If you own Vista Home Basic/Premium, or you are installing XP Home Edition, don't mention ANYTHING about Vista. Just give the rep your XP product key (not the Vista key), explain that you are installing XP on a new hard drive, and tell them you need to activate.
Mar 30, 2008 | Computers & Internet
Dual boot/hard drive seetings
Install first the media center on the primary harddrive with master jumpered.. when everything is working fine... then proceed to
the next harddrive. Set its jumper to slave not cable select and install xp pro, it ask you for an option to have dual boot then select the location of windows to be installed...
Hoping this helps... Fixya!!!
Feb 02, 2008 | Maxtor Hard Drive
Install window xp over vista ultimate
CHECK WITH YOUR SYSTEM MANUFACTURER WHETHER OR NOT YOUR WARRANTY IS VOIDED IF YOU INSTALL AND DUAL BOOT WITH WINDOWS XP. MANY OF THE NEWER SYSTEMS ARE DESIGNED AND CONFIGURED TO ONLY RUN WINDOWS VISTA. HARDWARE ON YOUR SYSTEM MAY NOT BE DESIGNED TO RUN WINDOWS XP.
Here is how:
http://www.pronetworks.org/forum/about88231.html
Jan 01, 2008 | Microsoft Windows XP Professional With...
ViewSonic VX922 19" Monitor Flat Panel Logo
145 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
