Question about Zephyr GLIDE Elica Collection Wall Hood
HOW TO INSTALL A ELICA GLIDE 90 BUILTIN COOKER HOOD. Is there a manual which would help with for example ducting.The previous hood was 100cm wide and was fitted was built into cupboards
No ducting pipe inside the cooker hood chimney what do i need to duct outside
Depends...does the vent access attic?...if so...attach vent material from hood and penitrate roof with roof kit....at lowes
Dec 09, 2011 | Kitchen Ranges
I need to run my 7" venting 20 feet with 1- 45 and 1 - 90 elbows. Will this be acceptable or is the run to long?
Yes that will be acceptable. You just can not have 4 at 90 elbows or anything that will make 4 - 90 elbows.
May 31, 2010 | Zephyr Elica Om EOM-M80A Kitchen Hood
Problem with cooker hood
Filters clean? Fan running? No clogs in the exhaust?
On the one hand, you want the disagreeable stuff out of the kitchen - on the other hand, you want to keep your heated or cooled home air to stay inside.
Mar 09, 2010 | Rangemaster Kitchen Hood
Elica oven hood fan not working
fan & light on elica extractor fan not working over cooker
Feb 25, 2009 | Kitchen Ranges
CDA CPX9 COOKER HOOD - how to remove chimney/disconnect power
remove filters, inside there will be mounting screws, support the unit prior to removing screws. there might be ducting inside clamped on, and a power plug(hopefully) to disconnect.
Jan 26, 2009 | CDA Kitchen Ranges
Cooker hood smeg opera 100cm what height should it be? and do i have to keep the chimney part on it?
Please check with your local building code for this information. Most inspectors will gladly answer your questions if you call them. You may be able to find the codes on local government web site too.
Check the manufactures recommendations as well. They should be in the box that the unit came in.
Jun 17, 2008 | Heating & Cooling
Halogen Lights Failing
I had the same experiences with my lights. I placed a 50v bulb and it blew the fuses. The fusees located on the right side of the bottom duct cover. use 5a 125 v fuse GE part # wb27x10542 but you can find a cheaper fuse at Radio Shack. Good luck
Mar 28, 2007 | GE Monogram ZV1050SFSS 42" Island Chimney...
Kitchen Ranges Logo
139 people viewed this question
Top Zephyr Kitchen Ranges Experts
Treefrog15
Treefrog15
The Vanguardian
The Vanguardian
Dale Copeland
Dale Copeland
Are you a Zephyr Kitchen Range Expert? Answer questions, earn points and help others
