Question about Ruud UBHC Air Conditioner
Ruud achiever heat pump
Brand new heat pump just installed all wiring is correct high voltage and low voltage but while its in cooling mode the back up heat is running. Why is the back up heat coil coming on while the heat pump is in cooling mode?
  • 1 more comment
  • quickair Jun 15, 2008
    Yea i wired it myself the b terminal is a direct wire from the stat and to the heat pump y to y r to r g to g purple is aux heat that links from the heat pump to white on air handler. While in cooling mode I tested the heat pump I had 24v at the r terminal 24v at the y terminal and no power to the b terminal but still the back up heat is running while the stat is calling for cooling. the suction line is sweating the status light on the heat pump is reading normal operation.
  • Anonymous Mar 28, 2009
    My Ruud heat pump fan is not running, air temp is 30F and it is snowing, compressor is running. Is this ok and normal or should the fan run anytime the system is operating.
  • Anonymous May 15, 2009
    Hello
    I got new Ruud heat pump installed and run good on a/c when system stop after cycle unit outside make some noise for 10 sec Is that normal ?
    Scholar:
  • 104 Answers
If back-up heat comes on when a/c is turned on and then the back up heat turns off shortly after the a/c turns off, then the low voltage wiring is NOT correct. Your "R" terminal is basically your "hot" and your "C" terminal is basically your "neutral" to simplify explanation. The Furnace supplies the "R" power to the thermostat and then depending on what wire the thermostat sends the power back on determines what the system does. The thermostat terminals are as follows "G" is fan, "W" or "aux" is elect heat, "Y" tells the outdoor unit to run, "O" or "B" tells the outdoor unit whether it is heating or cooling, and "E" is emergency heat. "G" should connect from the t-stat directly to the furnace and go no further. "W" or "aux" AND "E" should both connect to your "W" or "W1" terminal in the furnace, there should also be a "W" connection to the heat pump ( this allows the H/P to turn on the elect heat when the unit defrosts) "Y" and "O" or "B" may or may not connect to a terminal in the furnace, usually they just pass through the furnace from the t-stat to the H/P and get wire nutted in the furnace. Now, here is the key. As I mentioned previously "O" or "B", a system will only use one or the other. The entire industry (except for Rheem and Ruud) uses the "O" terminial which has 24v on it when you are cooling and no power when you are heating. Rheem and Ruud use the "B" terminal which is just backwards, 24v in heating and no power in cooling. this could also be your problem if the t-stat thinks it is telling the H/P to cool but the H/P is actuall interpreting the signal to heat. Check your amp draw on the furnace, if you have anything drawing 15 amps+ then it is most likely the actual elect heat running, if not then check the "B" terminal. Most universal t-stats come set from the factory to use the "O" terminal which is more common. Usually this can be changed in the installer setup menu on the stat or sometimes the stat will have separate "O" and "B" terminals
Posted on Jun 15, 2008
  • Chris Lyon
    Chris Lyon Jun 15, 2008
    Okay, then the next thing is do you have 24v at w in the furnace if not, then check the sequencer that controls the elements, use an amp clamp to find out which elements are on and the check that sequencer. If you have power at w, look for any factory jumpers in the furnace, if no power and the sequencer is still feeding the elements, then the sequencer is bad
Check all of the factory wiring and compare to diagram. they do mess up at the factory
Posted on Jan 08, 2010
Heat pump goes str8 to heating strips compressor does not run in heat mode pump was manufactured in 03 installed in 07 and has sat dormant till now could it be wired wrong it is a ruud split unit with...
I think that you have the right idea. The wiring is probably wrong. If you can trace the low voltage wires to the air handler. make sure that the Y1 wire on the t-stat is going to Y1 on the hair handler and then to the condenser. The Y2 wire should be going to Y2 on the air handler and probably does not continue out to the condenser. The Y2 should be going to the contacor that brings on your backup heat. It seems like Y1 and Y2 are reversed somewhere.
Nov 14, 2009 | Heating & Cooling
Brand new unit will not run
You have a bad control board from the onset. This happens sometimes, I have had issues like this before.
Apr 11, 2009 | Ruud Handler Air Conditioner
Ruud heating/ac unit blowing only cold air in heating mode
Do you have gas or electric heat. If you have gas then you do not have a heat pump. You should in most cases have a red,yellow, white, and green wires coming to the thermostat. R should go to rc/rh G should go to green Y should go to Y and w should go to W. Also the switches on back should be switched to non heat pump and gas rather than electric. Hope this helps.
Feb 15, 2009 | Ruud UBHC Air Conditioner
Looking to hook up a humidifier. What 12 volt leadsdo I use off the transformer in the ruud 90 achiever so the humidifier lets water run when the ruud unit turns on
usually you would jump it off the white low voltage wire. check t-stat and see what wire is hooked up for heating. also us the blue or common wire.
Please!! rate this it is important to fixya.
Jan 15, 2009 | Heating & Cooling
Ruud heat pump
Did you just install this heat pump? If so it sounds like you replace a regular a/c with a heat pump, which will require more wires for the reversing valve. First check to make sure you have 24v going to the condenser. Make sure you have a heat pump t-stat. You should have a orange t-stat wire for your reversing valve. At the t-stat you will have terminals R, Y, G, O, X or C or B, W1, and W2. R is half of your 24v circuit and is a red wire, Y is for cooling mode, G is the Fan green wire, O is for the reversing valve, orange wire, X or C or B is the other half of control circuit blue wire, W1 and W2 is the heat strips in the furnace tan and black wires. These are standard color code but remember electricity does not know colors and an installer may have used different colors. If all of this is correct possibly bad contactor.
Oct 30, 2008 | Ruud UAMB Air Conditioner
Ruud Heat Pump
Check to see if there's low voltage reaching the contactor's coil. If there is. and it doesn't close (pull in), then it's defective and should be replaced. Cut the power and check ohms to be certain.
Aug 09, 2008 | Ruud UAMB Air Conditioner
the reversing valve needs power to switch to heat. more then likly the o wire is connected when it shouldnt be
Jun 15, 2008 | Ruud UBHC Air Conditioner
Ruud heat pump high pressure cut off problem
That's going to be in your installer configuration. Check and make sure the G terminal has a wire connected to it at the tstat , and that connection it tight. In the configuration menu, make sure it is set for a heat pump, elected heat. It seems to me that the tstat doesn't know its connected to a heat pump. Should be able to locate aodel # for tstat on the back of it. And ask Mr. Google for a manual, if you don't have 1. Hope this helps!
Mar 18, 2017 | Heating & Cooling
RUUD Central Air/Heat Pump
Start with the simplest first it,s not fun but it's necessary EVERY TIME. Clean your evaporator and condenser coil, change your air filter. Getting to the evap. coil is often a real headache and a result doesn't get done often. When its clogged as you probably know the refrigerant can't absorb heat at the coil so it tries to absorb heat on the way to the compressor freezing the hot gas line the safety circuits that protect the heat pump compressor from getting liquid refrigerant back to the compressor almost immediately will take the compressor of line (looking somewhat like a defrost cycle). I hope this helps it's a tough repair GL!
Apr 10, 2007 | Ruud UBHC Air Conditioner
Ruud UBHC Air Conditioner Logo
1,518 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
