Question about Microsoft Xbox 360 Controller
Even when my batteries are fully charged my controller disconnects why is that
Did you use normal batterys cause thats what happened to me
Posted on Nov 07, 2010
Ford Escape 2003 new starter and battery turn over but still drags
Check all terminal connections. I would return the battery and have them check it, even if it is new. I have had this happen to me with a new battery. Next I would have the starter checked. Fully charge the battery with an external charger. Leave it disconnected over night. Reconnect the battery and try to start the vehicle. If it is slow to turn, the battery could have a bad cell in it. Fully charge it before you return it to the store to be checked.
Dec 10, 2016 | 2003 Ford Escape
The battery in the heli dies within minutes of use even after fully charged
Sounds like you need a new and fresh battery.
try www.batterybuyer.com I use them a lot.
Dec 28, 2015 | Toys
Battery won't fully charge.
Does the battery % stop at 85% or does it get to 100% and reduce to 85% when disconnected?
I've read several articles about battery charging and several have stated that when the phone hits 100% on the charger it will slowly decline even though it is left connected. Basically, it hits 100% and acts like it's disconnected (even though connected). When disconnected the battery percentage will drop. I'm not sure if this is what you are experiencing or if it's a problem with the device.
To start, I would suggest backing up all data on the phone and sync with Google. Perform a factory reset and log back into the device. This may solve the problem. If not, then I'd suggest going back to your service provider
Aug 27, 2013 | LG Motion 4G MetroPCS
I changed the battery in my 2005 F150 super crew today. Now when i let off of the accelerator it chokes down and shuts off. Not sure what the problem could be. it happened riding down the road and idling...
Hello, This happens alot. To fix this, you need to fully charge the new battery before you install it. Although you have a 12Volt system, the battery needs to be at 13.2 to 13.6Volts for a full charge.
You will find that the battery can quit charging even at 70MPH. The reason for this problem appears to be a combination of two features on Ford vehicles. The Battery minder is an automatic cutoff Feature for when headlights or another drain exists in the system. The Battery minder makes a mistake and reads the charging of the low battery as a drain and disconnects the charging system. The other Feature is the Anti-Theft control, which can reduce Starter voltage and interfere with other electronics to make sure your truck does not go far if stolen.
Even if you jump start a Ford with a low battery, it can automatically disconnect the charging circuit within 2 or 3 minutes of removal of the jumper cables, unless the residual Voltage reads a full charge.
I hope my solution is very helpful to you. If you have a Voltmeter on your dash, glance at it once in awhile until this problem disappears.
Jun 10, 2011 | Ford F-150 Cars & Trucks
Playstation 3...Battery in controller is low, plug in controller
The dead give away for a dying controller is the red light on the numbers will flash.
When you plug your controller in and hit your PS button, at the top you'll see a controller symbol and a battery icon. If the battery bars are moving then it's charging. When it's fully charged it will display 3 bars solid even when plugged in.
I've been wrong before; but I'm 99% sure you cannot turn off the system and have the controller charge. As far as I know the system must be on while charging the controller. From my experience it takes about an hour or 2 to get it fully charged.
Good luck and if i've helped you please give me 4 thumbs up!
Respectfully,
Don
Feb 07, 2010 | Sony PlayStation® 3 (80GB) Console
My mp3 player says it's fully charged when I connect it but when I disconnect it and try to turn it on it says ''battery dead''.
your battery is most definitely faulty. The reason why you can charge it is your device uses the AC Charge while charging th battery. even when it says "Charge Complete", it is still charging the battery. Have the device sent for warranty repair.
Aug 27, 2009 | Samsung YP-K3 MP3 Player
Will not turn on
take the battery out for a few mins, press and hold power button, re-insert battery, worked for me????
Oct 07, 2008 | Jazz DV-179 Digital Camera
Phone does not charge
When my phone is connected to the charger, it says fully charged. But as soon as I disconnect the charger, the battery shows empty. When I connect the phone to the charger, it starts charging but after 10 seconds it says fully charged.
Aug 08, 2008 | Sony Ericsson K600i Cellular Phone
Wont turn on
Possible failed battery showing fully charged but actually not -or even charger.No reset] Disconnect from the wall socket- re connect and tell us if the battery is now charging. If show full- replace battery. Also tell Sony customer support
Jul 31, 2007 | Sony Cyber-shot DSC-T10 Digital Camera
Microsoft Xbox 360 Controller Logo
43 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
