Question about Polaroid FLM-4234BH 42 in. LCD HDTV
No power to the tv, at all. power cord good, fuse good
  • 144 Answers
If no light on at all, and fuse in plug ok, then sounds like power supply failure. There will be a fuse inside but if its gone then could be due to capacitor failure , common in modern tvs. Not a job Iwould recomnend unless experienced.
Pete
Posted on Nov 06, 2010
Will not turn on, no blinking lights, power coming from cord is good
Sounds like the power supply board is dead. Probably has a blown power line fuse on the board. A power surge will sometimes blow the fuse and protect the board from damage. Replacing the fuse will restore the TV if this is the case. Most times though, the supply has a blown part that causes the fuse to blow and your only option then is to replace the board.
Mar 23, 2014 | Panasonic Tc-42px24 42 in. Plasma TV
Spectroniq tv doesn't turn on, lights off.
The fuse is inside--power cord should go almost direct to it--beyond that if fuse good is power supply for the set.
Nov 06, 2012 | Televison & Video
Where is My Philips 32pfl3505d f7 LCD TV fuses
I assume you are referring to the ac fuse, it is located on the power supply board. Just follow the ac power cord and it should lead you to it. If your set doesn't have a built in power cord, the fuse will be next to the power cord connector.
Sep 01, 2012 | Philips 32PFL3505D 32 in LCD TV
Hitachi LCD TV looks like no power but power cord checks good
Hello
Eventhough the fuses and power cord os good, and there is no power light on the panel board, means the power board do not get power to it. Check an other power outlet point first. If it does not help you, soethnig wring with the power regulator baord. Normally, these board are irreparable, and replacement should be done as card basis. OK.
Feb 07, 2012 | Televison & Video
Where are the fuses in my tv
The fuse of your tv is located in the power supply if you remove the back cover of your tv you just follow the ac cord this ac cord is attach to the power supply and you will see the fuse there, this is the picture of a fuse.
hope this may help good day and best regards.
Sep 16, 2011 | Toshiba Televison & Video
MY SHERWOOD FLATSCREEN T.V IS NOT COMING ON. IT IS A 22 INCH, MODEL # LTA22K04, IT IS NOT RECEIVING POWE, GENERALY WHEN IT IS PLUG IN A RED LIGHT AT BOTTOM LEFT CORNER SHOWS AND WHEN IT IS TURNED ON THE...
I would try the power cord first. You can use a cord that works with a computer desk top. It's the same. If the new cord does not fix the set then you are likely to have a blown fuse. You can trace the fuse to the power supply via the power cord. The power supply is inside the set taking the back off. If the fuse is good you will have a bad power supply. Do a google, ebay or shopjimmy.com search with your model number to get price and availibility. Be sure to match up the numbers of your board with the new one.
Jun 28, 2011 | Sherwood LTA22K04 LCD TV
Where do u find the fuse in the mitsubishi ws-55513 55in. by the power cord???
Follow the power cord into the back of this TV. You should find a small glass fuse near by. If the fuse is still good, chances are real good that this TV can still be saved. The biggest problem with this TV is the convergence board, which has many, many, many bad grounds that need resoldered. No parts are needed as yet, just some good old fashion rework on the convergence board! Thanks for asking and show a few hands of support!
Feb 21, 2011 | Mitsubishi WS-55513 55" Rear Projection...
The tv will not power on. Outlet is good. cord is good. Checked for electric on cord using meter.
Does the standby light come on at all or is it completely black?
Check to see if there is a fuse holder right where the power cord enters the back of the tv.
Good luck and keep us updated on your troubleshooting progress.
Jan 21, 2011 | Philips 19PFL3403D/27 19 in. LCD TV
SAMSUNG LN52B610 TV TURNED OFF BY ITSELF. CANT TURN TV ON. NO RED LIGHT ON TV FOR POWER. OUTLET WAS CHECKED AND HAS POWER. CORD IS IN GOOD CONDITION. PLUGS FIR SNUG IN...
Hello.
If you have multimeter available you can actually check if voltage present at the end of your power cord first.
If it's OK than you have to remove back cover from your TV and locate power supply board. It's very easy - it should be next to the power cord receptacle. First look for capacitors that have bulged tops instead of flat ones. If you locate any - replace them and check if it's going to take care of problem.
Right next to receptacle connection is fuse located and you have to check if it's open. Replace it if needed. If new fuse got blown right away - you have short in power supply board. If fuse is OK - connect power cord and using multimeter try to figure out if 5V is supplied from Power supply board to the main board (the one that have all inputs attached to it). If 5V is present but power LED in front of the TV is still dead - you could have problem with main board.
Best regards.
Russ.
Aug 17, 2010 | Samsung LN52B610 52 in LCD TV
Element FLX 3211B has no power after 14 months of use. TV will not power on. Checked th fuse near the power cord and the fuse is good. There is no power going to the TV. Tested the power cord and it is...
Took it to a TV repair shop and they did the following:
1. Rebuilt Power Supply
2. Replaced Diode
3. Replacd Transitor
Total cost was ~$100. Tv works fine now.
Mar 13, 2009 | Element Electronics FLX-3211B 32 in. LCD...
Polaroid FLM-4234BH 42 in. LCD HDTV Logo
210 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
