Question about Vacuums
Needle plate for singer mon ami (FX1737) - Vacuums
2 Suggested Answers
wentlanv
  • 710 Answers
SOURCE: i have Singer Confidence model
You may have bent the needle when the material jammed. Have you tried a new needle?
If a new needle doesn't take care of the problem, your needle frame may need adjusting.
This website is a good resource for sewing machine problems: http://sewvacdoctor.com/
If I need an answer, I go there.
I hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Posted on May 12, 2011
Mu Singer Futura II model 920 hand wheel seized up-it will not turn. any ideas?
Turning towards you? that is correct. It could be something else that is wrong, like needle hitting the plate, thread jammed etc...and you think it is the handwheel when the handwheel is just not turning reflecting something else. What I always do is take everything out and off...bobbin, bobbin case, feed dog plate, etc...and even remove the needle. Take your brush and get every last bit of lint out of the areas it might be. Something is hung up. When you put your needle back in, make sure it is up all the way, and use a new one. Maybe this will help, but if not, call Singer or take it somewhere as it might be a simple fix.
Feb 13, 2015 | SewShop.com Singer Model 920 Futura II...
HOW TO INSTALL NEEDLE PLATE ON SINGER 30518 SEWING MACHINE?
Hey, i just took the needle plate out to clean and i cant put it back. same model 30518, somebody can help? :(
Oct 27, 2014 | SewShop.com Singer Model 30518 Instruction...
My machine froze/seized up while I was sewing. Does it need a new motor?
Not necessarily unless you have burnt it out trying to make it go.
Its most likely clogged with cotton fibres underneath the needle plate and the bobbin. Give it a good clean out.
Oct 17, 2014 | Singer 7256 Fashion Mate Sewing Machine
Timing after installing new belt
There are about 3 MAIN delicate issues here, could be needle bar, top shaft or bottle shaft, to understand timing first knowing that needle hook is passing the cusp of the needle on its way up....
Feb 25, 2014 | SewShop.com Singer Model 758 Touch & Sew...
I have a singer 600E touch and sew. I accidently took out the bobbin case and can't seem to get it back in. Can you please tell me how? Thanks
Open the slide plate, and remove the needle plate.The needle plate should be raised by a lever on the right hand side of the bed.Move it to the left, then raise the needle or take it out.It is also easier if you remove the sewing foot.Once you have the slide plate moved towards you you will see a black piece of metal in the front right corner of the bobbin area.Lift it up and slide it to the right.Position the bobbincase with the metal flap that locks the bobbin in towards you so when you lift it up it is on the end closest to you.Make sure the bobbin case is in the groove of the hook(the round thing that spins when you turn the handwheel)once you have the bobbin case in position you bring the black metal pieceover to the left and it will drop down to secure the bobbincase.Turn the hand wheel towards you the bobbincase should stay in place and the hook should turn around it.If it turns smoothly replace the needle plate,close the slide plate,screw the foot back on and replace the needle.You are done. www.sewvac.com
Feb 01, 2011 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
