Question about Acer Aspire 4730-4947 Notebook
How to connect to lcd tv. i am using xp. - Acer Aspire 4730-4947 Notebook
  • 43 Answers
See you will have a vga port or hdmi port on your note book you have to connect the same cable on the lcd and then you want to have the view the computer on the lcd you have to press and hold Fn KEY AND PRESS on F8 once holding on to Fn and give a delay if the view doesnot comes and then try the same again
Posted on Nov 06, 2010
Haier L24B1180 24
Most new can now a days. In any case, took a quick look at your specs and simply connect to PC. Then choose input from TV. Like VGA, HDMI, depending on cable paring you choose for your PC video card. VGA is usually the easiest.
Aug 29, 2012 | Haier L24B1180 24 inches 1080p LCD 24 LCD...
How to connect an acer 3680 with windows xp to lcd tv
hi khan, its very easy to do this process , you can connect vga card just see this video
immortal4u_0.jpgGood luck ! if you think your problem solved don't forget to rate
Jan 01, 2011 | Acer Aspire 3680 Laptop
How to up the tv to a windows xp to make it a moniter
First make the connection from the Computer to the TV
go to this link for a diagram
http://downloadcenter.samsung.com/content/UM/201002/20100211121042093/BN68-01429A-02L02-0311.pdf
go to page 14 (connecting a PC)
Then in windows XP you have to go to the control panel and make sure the resolution is correct with your TV
Dec 02, 2010 | Samsung LN52A650A LCD TV
No Signal report by TV when connected to PC
Try changing resolution and refresh rates.  I have seen the same thing on Macs, and found that the TVs expect a 60Hz refresh rate and at least the Mac likes to use a 75Hz refresh rate.  When the two mismatched the TV would not accept a signal.  The easiest way to make the change is to use some sort of remote desktop login like LogMeIn.com or GoToMyPC.com.
Apr 03, 2009 | Westinghouse TX-47F430S 47 in. LCD TV
Weak or no Signal issue when connected to my TV.
Yes weak signal. Also closing the laptop lid puts the computer in sleep mode.
Jul 07, 2017 | Digital Lifestyle FA1B32Z 32 in. LCD...
W2606c lcd tv
Nothing appears on my LCD TV display
1 Ensure the LCD TV display is turned on.
2 Verify that all the cables are properly connected to the LCD TV
display, including the power cable.
3 Check to see if there is a blue or amber light on the lower,
right-hand corner of the LCD TV display. A blue light indicates
the LCD TV display is on. An amber light means the LCD TV
display is in power save mode.
4 Ensure the proper source is selected in the Input Select menu.
See "Input Select Menu" on page 24 for more information.
5 Reconnect any devices that are currently connected to the LCD
TV display. If you are using multiple devices, connect and test
one device at a time.
6 Connect another device that you know is working properly.
7 Reset the original factory defaults. Press Menu on the remote
control, select Setup, and then select Factory Reset.
Problem Possible Solution No sound
1 Ensure mute is not turned on. Pressing the Mute button on
the remote control turns the mute function on and off.
2 If only certain LCD TV channels do not have sound, then you
need to correct the Input Select menu in the TV Menu (see
"Input Select Menu" on page 24).
3 Verify that the audio cables are firmly connected to both the
audio input connectors on your LCD TV display and audio
output connectors on your devices. Ensure that the cable colors
match the connectors colors.
4 Also, ensure that the audio cables are connected to the same
row as the video cables. See "About Your LCD TV Display" on
page 5 for the location of the connectors.
5 Reconnect the device using the same type of connector. For
example, if you are using the composite connector on the
bottom, try connecting the device to the composite connector
on the side of the LCD TV display. See "About Your LCD TV
Display" on page 5 for the location of the connectors.
After you connect the device, change the input source in the TV
Menu. See "Input Select Menu" on page 24 for more
information.
6 Connect the device using a different connector. For example,
if you are experiencing the problem using a composite
connector, try using the component connector.
NOTE: To connect to a different connector, you need the
appropriate cables for that connector. See your device
documentation for a list of supported connections.
information.
7 Test the device on a different TV.
Jan 05, 2009 | Dell Televison & Video
Dell Inspiron 1300 can't connect external monitor
I was having the same problrm for my dell inspiron 1300. It is not FN + f5. It is fn +f8. Notice the Crt/LCD...
Jan 04, 2009 | Dell Inspiron 1300 Notebook
Flat screen zenith Z20LCD1 use as a moniter HOW? Thanks
this is from the manual:
When the input source is PC (Only for Z15LCD1)...
PC S ettup ((Z151L5CLC1RD1
onlly))
Connections
1. Set the monitor output resolution on the PC before connecting to the TV.
2. Connect the TV to the PC with the PC cable.
3. Connect the PC audio output to the TV's PC S OUND input.
Viewing Setup
1. Turn on the PC.
2. Use the PC b utton on the remote control to select PC .
it appears only the 15" model may be used as pc monitor
Dec 06, 2008 | Zenith Z20LCD1 20 in. EDTV-Ready LCD...
Not supported mode lcd tv samsung lnt4061f
with the PC input or analog SVGA the only 16:9 resolution it supports is 1920x1080, which can be difficult for some older systems to handle. However, on HDMI it should support all the standard HD resolutions.
Dec 29, 2007 | Samsung LN-S2651D 26 in. LCD Television
Acer Aspire 4730-4947 Notebook Logo
43 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
