Question about KitchenAid KHWS01PMT Front Load Washer
F-11 In the begining I too had the DL-F code. Had the repairman out to fix it. (expesive too)!!!!! Now I have the F-11 code. The unit works fine untill about 1-2 mins from the end of the final spin cycle. I used to be able to get it going again by hitting the canceal button until it stops flashing, & it reads back to the last 1 or 2 mins left. From there I then push & hold the start button (about 5sec). Wait another 5sec, then I hear a click & it starts up right were it left (stopped) off. But, today (6-14-08) it will not even do that. It just will not click & start. Now it will just start beeping AGAIN, untill I hit the canceal button, like I was going to repeat the same steps AGAIN!!!!!!!!!
  • Anonymous Sep 07, 2008
    We have had the exact same problems, f-11 code, f-dl code have had repairman out 3 times and they replaced the door lock actuator, works for a week and then the same thing all over again
I'm having F11 problems in the first 1/2 hr during the regular cycle...it's been a great washer for years. any suggestions?
Posted on Oct 23, 2008
  • 487 Answers
FIRST COMMENT
F11 Serial communication error Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Possible Causes / Procedure
1. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and Central Control Unit (CCU).
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic test or any cycle.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
8. Check that the serial harness at the MCU is not mounted upside down. The wires should be to the left when facing the MCU connectors.
Replace failed component.
Posted on Jun 15, 2008
  • eric bosman
    eric bosman Jun 15, 2008
    The problem is that it can be a multitude of problems with Kitchenaid F11
    Is the opperation of the washer normal during the first say half an hour when you start opperating it?
    Look at this LINK for parts lists
    Please come back to me so we can figure this out
Genesis G0-380 will not keep drinks cold.
usually calling a repairman is the best solution they use freon as coolant and the unit has to be properly charged with it .
Jul 18, 2016 | Refrigerators
What might be causing the intermittent F-11 codes on a Kenmore Smartwash front loading washer?
f11 error is communication error.most likely bad solder joints in ccu or mcu.
May 08, 2017 | Kenmore Washing Machines
Washer goes through cycle, until around 11 minutes until finished it stops, and goes into dL. Will not finish load. What does this mean?
Hi.
the error F/dL means Door Lock Error
The error is prompted when the door cannot be unlocked.
Here possible causes.
Door Latch mechanism broken
Door Switch Assembly defective
Wire Harness from Central Control Unit to the Door Latch or Switch Assembly broken
Door Lock or Switch temporary failure (it can be reset disconnecting power)
You will probably need to replace the door lock assembly. Parts must be tested first.
Regards.
Ginko
Apr 28, 2011 | Kenmore HE2 Plus Front Load Washer
I've gotten the error code DL and then F, I tried sanding, unplugging but it still shows me the error. How can I fix it?
Initially unplug the washing machine.While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for five seconds.
Plug the unit back in, and run a rinse and spin cycle to test if the DL code is cleared.
If you still face the problem then follow the procedure:
Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Plug the washer back in and press [Power] to turn on the washer.
Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Press [Start/Pause] to begin a drain only cycle.
After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause].
This will remove excess soap suds and light residue from the drum.
Repeat this step until no visible suds are in the drum of the washer.
Hope this helps.
Shane
Mar 15, 2011 | Kenmore Elite 45986 Front Load Washer
F11 and/or dl code on a whirlpool duet front load washer
F11 is:
Serial Communication Error
Check for:
Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
Check the Drive system for any worn or failed components
Check MCU
Check CCU
Check Motor
Check Wire Harness
http://www.fixya.com/support/r666194-f11_error_whirpool_duet_kenmore_elite
Check the above link for a detailed article about the f11 error code.
Courtesy:JSrock
Apr 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
DL error or kenmore Oasis washer
Hi. this is a door lock mechanism failure code. these mechanisms will become unstable overtime. simply replacing this damaged door lock assembly will fix this issue.
If you are uncomfortable with disassembling thsi unit, i recommend calling a service tech for this procedure. he will simply replace the door lock mechanism(assembly)
Jul 27, 2009 | Kenmore Oasis HE 27082 Top Load Washer
F-11 and DL-F Codes...
We had the same problem for 2 or 3 years. I was not able to find an answer to your question either (let me diagnose it, so I can fix it once and for all). I ended up taking out the control unit in the top front of the machine to have it "rebuilt". It's not a small task, as there are 10 or 12 sets of wire connecting to the unit. I sent the unit away to a company in either North or South Carolina. They rebuilt it for about $90. The machine has been working like a swiss watch since. We went through this process in 2011.
Whirlpool or their supplier made a faulty component, and this company has made a business improving it.
Mar 20, 2017 | Whirlpool Duet GHW9150P Front Load Washer
How do i find what an error code means?
if that is a whirpool or kenmore remove bottom panel look for tech sheet in plactic bag codes are in it
Sep 02, 2008 | Washing Machines
I HAVE A FAULT CODE F 11 AND DL F
it looks as if your having a communication problem between your central control unit and your motor control unit.check wiring connection between these two components.if wiring is ok then you will have determine which of these components is malfunctioning.you can also remove kick plate and remove service manual located on either side at bottom.this should give you some help.
Jun 18, 2007 | KitchenAid KHWS01PMT Front Load Washer
KitchenAid KHWS01PMT Front Load Washer Logo
356 people viewed this question
Top KitchenAid Washing Machines Experts
kj henriksen
kj henriksen
gbob59
Mike
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
