Question about Vocopro CDG-8000 PRO
I have a Vocopro CDG-8000PRO karaoke CD player thats been used twice it has been sitting for a couple years keeped clean and dry for some reason the CD will only twitch on both players i took the top off and give each CD some help to start turning they both continued turning & both played great until i shut down the unit and left it over night now its doin the same thing ive cleaned the laser eye they did not appear dirty thied them again samething just twitched help them start they played one took a little more coaxing to get it to continue to play. Any idea what could be at issue i dont believe they went bad at same time with same problem and so little use?
  • hillsidefeed Nov 11, 2010
    The drive is not stuck or frozen it turns quit freely both of them in fact it seems yur experts need to do a little more research because there are 3 contacts that tell the system it the tray is open or closed and it was them contacts thats needed cleaned so i fixed both drives by cleaning the contacts with a peice of extra extra fine sand paper now they work like new.
    President:
  • 2,777 Answers
It does actually appear that both drives failed at the same time or that they both got dust and debris in the playing mechanism... if you have some canned air or a compressor give it a good "shot" with some high pressured air directly into the cd "drive" mechanism. The center part that actually turns to spin the cd.
Otherwise you will want to look into getting replacement drives for this player. It is actually quite likely that the lack of use is what did these drives in. They have little ball bearings inside that spin to spin the CD and sitting idle without use is actually worse in some cases then having regular use... does that make sense? Even though I'm sure it was "dry" I am sure there was some kind of humidity that is unavoidable.. that gets in the mechanism and jams it up a bit ... You can try a tiny bit of WD-40 or similar sprayed directly into that drive mechanism as well and it could very well free it up.
Thanks, let me know if you have any questions or concerns, just reply to my answer here and I will be right back with you.
Tim
Posted on Nov 06, 2010
  • Tim Grayson
    Tim Grayson Nov 11, 2010
    Sounds good, glad it's working
Read error
Your reader is probably going bad. You can try cleaning it with one of those home CD player cleaner kits and that might work for you.
Aug 23, 2014 | Akai Karaoke Akai KS808 CDG Karaoke System...
Tray's sticking on vocopro 8000 pro
Sounds like belts are slipping under tray. They can be cleaned or replaced or new ones of course.
Dec 23, 2007 | Vocopro CDG-8000 Professional Dual CD/CDG...
Vocopro 8900 noise but no music
No power to voco pro 8900 cd player
Aug 09, 2012 | Music
Only de right side of the cd player worrkin
because the problem is due to spark while switching cables of any kind the inside of your cd player damage and the solution is that ,take the player to any person in the market that can make it right.
Feb 06, 2011 | Vocopro CDG-8000 PRO
Will only play certain cd's. works great with the
try clean-it with cd drive cleaner kit. available on professional audio\video stores
Feb 21, 2010 | Vocopro CDG-8800 PRO
On my Yamaha CDC-625, I can push the open/close button or the playxchange button, but the changer door will not open. It sounds like a motor is trying to open it, but nothing. Pushing the button again...
The most common problem is a slipping belt.
You have to open-up the player to check it.
If you're not familiar with it, then please don't.
It's not such a big problem, look for a local repairshop.
HNY, Gerard
Jan 01, 2010 | Vocopro CDG-8000 Professional Dual CD/CDG...
I have a roadstar dvd/karaoke player it wont play the cdg discs on it ,it will only play the dvd karaoke discs,is that a fault with the machine .
Sounds like yure laser is faulty or neds a clean or youre discs need cleaning try a lens cleaner most electrical shops sell them and wash and dry one of youre discs that wont play
Nov 27, 2009 | Televison & Video
My receiver is reading NO DISC it is a vocopro karaoke player/receiver model # DKP-10G
First, the player does not support DVDs or MP3 discs.
Try two things:
#1:
Unplug from outlet and Turn ON player (while unplugged).
Plug back in and try to use the CD.
#2:
Obtain a CD laser lens cleaner from Radio Shack ($13). It is an audio CD with a row of brushes and does not use chemicals
Oct 16, 2009 | Vocopro DKP-10G
No Disc Error
there is no fix you bought someone else's junk
May 08, 2017 | The Singing Machine DVD/CDG Karaoke System...
Cd tray doors won't open
Check mechanics on CD door for dirt, or any loosen screws.
Oct 01, 2007 | Vocopro CDG-8000 Professional Dual CD/CDG...
Vocopro CDG-8000 PRO Logo
141 people viewed this question
Top Vocopro Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Vocopro Audio Player and Recorder Expert? Answer questions, earn points and help others
