Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
High trottle is not working it's full power - Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
  • 3 Answers
Griffofarm
  • Rank: Master
  • Rating: 79%, 49 Votes
They have two separate screws? one for fast, one for slow.for the slow setting, first start the saw then screw until motor runs smooth without chain moving....if to slow the motor will stop....for fast screw....rev motor flat out then adjust so it screams its head off so to speak....it will need all its power for cutting wood so don't think you are opening it up to much as its designed for it.
Posted on Nov 13, 2010
I have a 2005 gmc Yukon how do you adjust the idle
idle is not adjustable Idle is control by IAC valve
if idle is high with a scanner look to data if trottle angle is at 0%
if it is at 1 or 2% this why rpm is high means for pcm trottle plate is open too much. adjust with scanner relearn.
hope it helps
Oct 17, 2014 | 2005 GMC Yukon
Gives speed when half trottle but no speed when full trottle
You have a low idle adjustment and a high in your carbs I would just try spraying carb clean wile running if not the rebuild carbs
Jul 14, 2013 | Yamaha 12V Air Pump
Engine power increasing and decreasing on full trottle
cant work on these rate these for clean solution
Jan 16, 2013 | 2005 MBK Ovetto
The motor does not respond on full trottle, half and up it just like chokes itself
You need to adjust the high speed mixture on the carburetor. When you say it 'chokes itself' you imply it is too rich.
Jun 29, 2011 | 2011 Derbi GP1 50
What is h and l screws for we have been moving them around to try make the saw tick over as it keep cutting out
"H" is high speed and "L" is low speed. Turn both screws in full, then unscrew them one and a half turns each. Start the saw, you may have to adjust the trottle screw to keep it running.Then adjust the "L" screw a little, in or out, with the trottle screw until you are happy with it ticking over. then adjust the "H" screw to get it to run full. You need time and patience. Stephen.
Sep 24, 2010 | Husqvarna Chain Saw 20" Bar
Craftsman 2 liter chainsaw at full trottle does not have full power. can you tell me what the compression ratio should be?
you need to adjust the H screw on you carby, hold at full throttle, and turn screw til faster revs are obtained.
Apr 14, 2010 | Garden
Engine idle slightly high have replace idle senor,trottle body still slightly high not as much
check all of your vacuum lines including your power brake booster it sounds like you have a vacuum leak
Mar 20, 2010 | 1988 Chevrolet C1500
Why does mio not fully full trottle?
your problem is in the bikes brain it has a chip in side it that only allows it to go a certian amount of speed send it it to have it rebuilt but make sure battrey is unhooked when you go to remove brain
Nov 06, 2009 | 2008 Yamaha MT-01
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
77 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
