Question about Maytag Washing Machines
Tub leaking from center of tub under the aggitater
  • nelk Jan 13, 2009
    leaking at tub seal
  • 413 Answers
This type of leak indicates a failed tub seal and bearing. Replacing is time consuming, can be difficult and requires special tools to disassemble.
Posted on Jun 15, 2008
Aggitater is not moving
If you mean the top part of the agitator only then agitator dogs / dog ears would fix it.
Dec 08, 2012 | Kenmore Washing Machines
Water is leaking from the under side of my washing machine what could be the problem?
Check all hose connections, fill tub check for leak while full, then drain and check pump while draining. Also while tub is full use a flashlight and look where trans goes into tub if you see a leak in the center then it is your center seal.
Oct 03, 2010 | Hotpoint GE VWSR4150DWW WASHER
We have a Maytag top-loader model A482 which is probably 25 years old. I found water on the floor under the machine when the last load finished washing. What's the first place to look for the leak? I'm...
The most common thing that will cause a leak is the tub seal. If the tub seal is leaking water will be comming from the center of the tub where the transmission meets the tub. This page will show how to replace the seal. http://appliance-repair-it.com/Maytag-tub-seal.html
There is also an air-gap that will often leak. If this is the case the water will be comming from the left hand side at the top. The air-gap is in line with the water inlet. This page will tell more http://www.appliance-repair-it.com/Maytag-washer-leaking.html
If they are not the problem you will have to look for a leaking hose or something to that nature.
Sep 28, 2010 | Maytag Washing Machines
Leaking tub in front
If this is a Whirpool toploader and it is leaking from the front, this is commonly caused by a damaged drain pump. These pumps are sealed units and are not serviceable. So, if it IS leaking, the pump must be replaced. The following link explains how:
http://www.fixya.com/support/r397094-replacing_water_pump
Of course, the real determination will be exposing the internal components of the washer to get a better view. The link provided has all the steps required for removing the washer casing to expose the internal components. This will give you a better idea in determing where exactly the source of the leak may be coming from.
Run a small amount of water in the tub before you unplug the lid switch connector. The washer will not run with the lid switch disconnected, so you will need some water in the tub to see where your leak may be.
The drain pump is located in the front of the washer directly below the wash tub. Check the drain hose connections and the pump housing. As stated before, if the pump is leaking it must be replaced. Replacements can be purchased at any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
Check the wash tub for any cracks as well, followed by a check under the center potion of the tub. If the leak is along the wash tub any where, the tub may have to replaced. If the leak is coming from UNDER the tub, you may have a leaky tub seal. These repairs are not difficult, but are labor intensive. We'll cross that bridge if needed.
Read through the link and let me know if you have any questions. I hope this helps you.
Aug 12, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag A806 washing machine leaking from the center,under the tub
The tub seal is bad.
I had the same issue on another model.
You can attempt to repair this yourself. I suggest that you do a search on Youtube to see if this is a job you want to take on. It took me 2 hours to change mine. The seal kit and tools are sold online.
Good luck.
Sep 27, 2017 | Maytag Washing Machines
Leaking wash machine
Depending on where exactly the leak is coming from, it could be a drain hose, drain pump, or tub seal. If this is a top-loader, here's how you can tell:
1. If the leak is coming from the BACK area under the washer, this can be caused by a leaking fill hose, dispenser hose, drain hose, or fill valve.
2. If the leak is coming from UNDER the center area of the washer, this could be your tub seal, a crack in the tub, or an air dome hose leak. NOTE: If the air dome hose is leaking, the washer will fill continuously and not turn off.
3. If the leak appears to be coming from the FRONT under the washer, this could be your drain pump, or drain hoses.
Posting a model number, could assist with determining how your washer is configured. I suspect you may have a drain pump leaking as this is the most common cause, but I want to be sure.
Apr 27, 2009 | Washing Machines
My Whirlpool ultimate care is leaking under,I did check the hoses and they are okey. What could be the problem?.
Can you describe where the leak may becoming from? For example, near the front, from under the washer, or near the back.
If you notice a pool of water coming from under the washer near the FRONT, this is commonly caused by a leaking water pump. Since these pumps are sealed units and are considered non-serviceable, it must be replaced. They cannot be resealed or "fixed".
If the leak appears to be leaking from under the washer near the CENTER of the tub, either the tub seal is leaking or the air dome hose may have come loose. If the tub seal is leaking, it also must be replaced. If the air dome hose comes loose, however, the washer will never fill up all the way and will continuously run. This will cause a flood rather than a drip.
If the leak is coming from the REAR of the washer, this can be caused by cracked fill hoses, loose fill hose connections, a leaking drain hose, or a fill valve hose leaking.
Since you said you checked your hoses, I suspect a water pump, or something loose. Can you please confirm your symptoms and let me know?
Apr 24, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Water leaking from under washer
Hi
You'll need to open the machine and check for the leaks in the hose connected to the drain pump. Also check if the clamp connecting the drain filter and hose is tight. Also check these things for leaks---
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you'll need to replace it.
Please do rate this solution as FixYa if found useful and revert for further assistance.
Thanks
Rylee
Apr 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Leak under tub
you can try tightening all the bolts but if that don't cure it then the seal would have to be replaced.you have to take it all apart to get the tub out then take the 30 something screws out seperate the two 1/2's and replace the seal.this is kind of a tough job unless you have the room and patiance to do it.
Oct 06, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
GE top load washer leaks on floor
Check your hoses mostly the small hose going from the side of the tub to the water switch these come off a lot. you need to look and see if the seal is leaking from the center of the tub you do this by putting water in the tub and just looking around the bottom of the tub and transmission
Dec 29, 2007 | Washing Machines
Washing Machines Logo
104 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
