Question about MSI 945GCM5 Motherboard
I am having problem on my audio part, speakers are working correctly but there is no sound coming , i have checked my sound manager, as well as drivers but nothing is wrong.please help me.
    Genius:
  • 1,672 Answers
Please check *********** board's connections and SHORT CIRCUiT PiNS!
Check your board's manual for right short circuit pins installation!
Posted on Nov 06, 2010
My computer doesn't detect my speakers, I do have windows 8
Do you have the AC adapter plugged into a live outlet and have you turned on the speakers? Make sure that the speaker signal cable is plugged into the correct port on your computer (the lime green port on a desktop). Check that the correct audio driver is installed for your computer. (With Windows 8, use the Device Manager to check. From the Start Screen, type in Device Manager. Click on Settings and then select Device Manager. Alternatively, Windows key+C on the desktop. Select Settings and then Control Panel. You can find the Device Manager under System and Security or Hardware and Sound.) Scroll down to the Audio devices. Expand the section and look for a red triangle with an X or a yellow triangle with an exclamation point. Try updating the driver (check with the manufacturer of your computer for the latest driver). Even if you don't see the error triangle, try reinstalling the latest driver.
Next check if the speakers work on another computer. If they don't work, the audio cable may be damaged. Try a different set of computer speakers on your computer.
If other known good speakers do not work and the correct audio drivers have been installed, check the audio output devices. Go to the Control Panel > Hardware and Sound page (as described above). Choose Manage Audio Devices. Check if the HDMI port is set as the default audio device. Disable it for a bit (right click on the device) . Sometimes when a new video card is installed, the audio device defaults to this port. This messes up the drivers for the regular audio.) Reboot the computer and then try reinstalling the audio driver. Reboot again.
If it still fails, there is probably something wrong with the audio device hardware. If you are using an add-on sound card, try disabling it and using the motherboard audio device. (A number of add-on sound cards didn't work well with Win7 or Win8. The on-board audio drivers worked better.) If you are using the motherboard audio on a desktop, try an add-on sound card. (Check for Windows 8 compatibility (drivers) before selecting any card.)
I hope this helps.
May 29, 2013 | Kinyo PA-1158 2.0 Amplified Speaker System
Fixya.com
If your computer came with a motherboard disk the drivers could be on it
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark or a red X Right click to reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
hope this helps you
Nov 22, 2011 | Computers & Internet
Hi, only 2 speakers work and the sub woofer also
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 21, 2011 | Logitech Z-680 Computer Speakers
Where is mute button on model 5189 keyboard. sound does not come on. speakers wires seem to be installed correctly. Trouble shooting guide said mute button may have activated.
also
hope this helps
Apr 24, 2011 | Audio Players & Recorders
The speakers I have worked just fine, then one day they just stopped working. Now my computer doesn't even detect them. They are plugged in correct and I haven't switched anything.
also
hope this helps
Apr 22, 2011 | Polk Audio AMR90 Computer Speakers
I have an acer aspire z3101-e3812 i see the speakers working but there is no sound coming out of my pc...plz help,,because it is new and its not working...
also
hope this helps
Apr 19, 2011 | Acer (54.AA806.001) Sound Card
Hi My speakers are acting up. Sometimes sound comes out sometimes it doesnt. Sometimes only sound comes out of the sub but theres no sound coming from the speakers. So i hear only bass. When i try...
if you are having problems with your sound
also
hope this helps
Apr 03, 2011 | Altec Lansing MX5021 Computer Speakers
There is no sound coming out of my speakers but everything is plugged in correctly
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make sure you have selected the right speakers or
control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 18, 2010 | M-Audio Computers & Internet
In my Destop system Audio Sound is not coming
Check the device manager for any conflicts with the drivers. There would be "Other drivers" listed if there was any drivers that were not installed correctly. If there is any listed try right clicking on them and selecting to reinstall drivers.
To get to the device manager:
Right click on my computer or Computer > select properties > then click on hardware tab on top then device manager or click on device manager link.
Computer Repair - Support
www.jdtechsource.com
Oct 29, 2010 | Computers & Internet
They aren't working. No sound is coming out, and I have triple checked all cables. What is wrong?
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Oct 26, 2010 | JBL CREATURE II Computer Speakers
MSI 945GCM5 Motherboard Logo
293 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
