Question about Broan-NuTone N-8663RP Combination Light Fan Exhaust Fan
My fan is not working how do I replace the unit or the fan?
  • 44 Answers
What I usually do is go buy another whole unit and swap out the motor and bracket . I hope this helps.
Posted on Nov 07, 2010
Should I replace the fan or the entire unit?
i would try fan. 18 seer unit should last awhile longer.
Jul 30, 2014 | Kenmore Icp Comfortmaker C4a836gkd 3 Ton...
AC unit comes on, but fan doesn't work. It works with furnace.
check for loose wiring to Tstat, or the new stat has failed.
if the stat has a fan on switch and when on the fan works then replace the stat
Apr 10, 2013 | Heating & Cooling
2004 grand marquis fan quit working..replaced fan but still wont work
is this the blower motor fan for you heating and A/C or the cooling fan cooling fans have a relay blower fans are fused but controlled from switches inside as well as fuses
Aug 27, 2012 | 2004 Mercury Grand Marquis
Goodman outdoor a/c unit top fan stopped working while the family was away from home and now the compressor will not turn on. Only thing happening when a/c turned on inside is the indoor unit kicks on and...
the fan would need to be changed also it may have over heated the pump. if it has been left for a long time in this way it could of done more damage. you could be luck and that the fan might be telling the unit control its not moving so it will not turn on. but to find this out you will need to replace the fan if the fan has 3 or more wire it would have this feature.
Jun 27, 2017 | Heating & Cooling
Fan Unit Replacement for SA-HT65?
replacement fans are on ebay, you need to measure the fan, how many wires. etc or do a search of the fan number that is on the fan itself. as long as the fan is the same size from fixing hole top left to fixing hole bottom right and the right voltage and wiring it will work as a cooler fan in the device.
Jun 30, 2017 | Audio Players & Recorders
THE FAN IN THE OUTSIDE UNIT IS NOT WORKING. INSIDE UNIT RUNS BUT NO COOL AIR IS COMING OUT OF VENTS. IS THERE A REST BUTTON OLN THE OUTSIDE UNIT?
either the fan has went out or the capisitor for the fan is bad and needs to be replaced.if you have run the outside unit very long without the fan turning you might be replacing the compressor as well as the fan or capisitor.if the fan isnt pulling air through the cond coil outside,the compressor gets very hot very fast,and it locks down(burns up). get it looked at asap before it cost more because of other broken parts caused by the fan not working.
Sep 24, 2010 | Bryant Heating & Cooling
Unit turns on but fan does not work. When we turn unit on, it makes a low "whirring" sound, but no air comes out of unit.
Try turning fan by hand. If it turns easy, replace fan capacitor.
If hard to turn, replace motor.
Jul 11, 2010 | Frigidaire FAH125P2T Air Conditioner
The fan near the condenser unit on a 632/s does not run
the fan does not use a breaker . and if it's hot and not running. then replace it as it has failed . easy job and very common in all brands .. **** ..
Jan 18, 2010 | Sub-Zero 632 / S
Outside unit kicks on but inside fan sometime works and sometimes won't and i have replaced thermostat to get to work i have to turn the fan to on and back to auto several times and finally the fan inside...
Goodman air handlers (inside unit) fan have a delay timer that turn on the fan ,sometimes up to 3 minutes after the outside unit is on,this makes the a/c more efficiency.
Sep 19, 2009 | Goodman CKL36AR36 Air Conditioner
Broan-NuTone N-8663RP Combination Light Fan Exhaust Fan Logo
163 people viewed this question
Top Broan-NuTone Dryers Experts
Steve Allison
Steve Allison
wavesfix
Level 1 Expert
mike simpson
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
