Question about Brother P-Touch PT-1830 Label Printer
Need to print label that has a font that fills up entire tape size 1/2" tape.
    Problem Solver:
  • 15 Answers
Search it from google search engine
Posted on Nov 06, 2010
  • Anonymous Nov 06, 2010
    hai and hellow and bye bye
With Print Shop 23.1-If I am adding text inside a text box, say font 60 and I complete the line and press "Enter" to start a new line, the font # changes back to what it was previously. Then I have to
When using text boxes I typically type the entire box in the preset font/size and then double click the text or select all, and choose my fonts ,sizes, spacing, etc. afterwards. Typically I use text boxes for smaller font items as I find the headline feature to be the most useful for larger size text. also under the text tab , after you double click your text box, you can select a paragraph style which has presets up to 143. I apologize that I didn't really answer your question, but maybe this will you get you by until you do, that is if you haven't already figured it out.
Oct 18, 2011 | Broderbund The Print Shop 23 Deluxe
P Touch 1880 indicates MAX font size, but prints smaller sized label. If I print one word at a time, it prints in MAX size. If I print two or more words, it prints smaller font. Weird, new problem.
Sounds like you may have a maximum length set that keeps you from printing over a certain length of label and it is adjusting your font size to fit that length. You may need a manual to figure out how to reset the length.
Jan 14, 2011 | Brother P-Touch 1180 Label Printer
How do I change the font size on a Dymo Letra Tag?
For the Dymo LetraTag Plus LT-100T, Personal Label Maker (SKU: 1733013)
Before trying to change the FONT you must make sure that the labelmaker is configured to print only 1 line of text. You cannot sellect to print larger fonts when label maker is configured for multi-lines. In order to make sure you are printing only 1 line do the following
1)While pressing down on the Shift key (may be show by an up arrow on some machines), press the Del/Clear key. This will clear all text and reset the label maker to print on 1 line.
You must also make sure that there are no other print options enabled, such as: italic, bold, vertical, underline, mirrored-print, outline, etc; these will all prevent you from changing the font. Also ensure that the take will accomodate the font.
My response will depond on the exact model you have...
To set the font size
1) Press the FORMAT key.
2) Use the up or down arrows keys to select the Size and press OK
3) Use the up or down arrow keys to selected the desired font size then press OK
To set the font
1)Press FORMAT
2)Use the up or down arrow key to select the font style and press OK.
If this does not work, please include the exact model/name.
Sep 23, 2010 | Office Equipment & Supplies
P-Touch Label Maker: How to get rid of "Text Too High! 1 Block" error message?
You may get this error after installing new tape which is small in width. If you reduce font size, so it will fit on new tape, the error message goes away and your P-Touch will print your label.
Sep 17, 2010 | Office Equipment & Supplies
I just changed the tape and the printer is printing small font
okay when you first start the machine up it tells you what sizes its going to print in you can change that by using F=1 orF+2 font type and font size hope this helps
Feb 03, 2010 | Brother PT-1000 Thermal Label Printer
Changing font size
I just wasted 20 minutes to get the font size changed. Press Code and then the & you keep pushing the & and it will toggle through the numbers 1-5 (5 being largest)
Dec 21, 2008 | Brother BRTPT65 PT-65 Label Maker Printer
ERROR appears and won't print
What size tape are you using in the machine?  Some of the fonts won't work if you are using 1/4" tape.  It will say ERROR if you're asking it to print a larger size. This won't be a problem for you if you switch to 1/2" tape, or just use the two smallest font sizes.
Hope that helps!
Nov 17, 2008 | Brother P-Touch 1180 Label Printer
Doesn't print anything
My P-touch has the same issue. There is a U-shaped spring wire that pushes one of the rubber wheels so it presses the tape against the element that "writes" on the tape. A small piece of plastic that holds the spring in place broke off so the spring can't do it's thing. CA glue (superglue) would not work, I am trying to find a parts source now, it is easy enough to replace.
Mike
Jun 15, 2008 | Brother PT-1750 Thermal Label Printer
Dymo lextra tag xr
I was able to find the following error codes, however I realize they are for the Lextra tag QX50. I was unable to find codes for the Xr, so I e-mailed Dymo and will post a comment on this as soon as they get back to me.
For now, here are the QX50 codes, just in case they help:
LetraTag QX50 Error Codes trnsp.gif Question An error is dispalyed on screen when I attempt to print a label with my LetraTag QX50. How can I resolve this?
trnsp.gif Answer Error
Solution
Error 1
(Tape jammed or low battery)
  • Replace the cassette
  • Replace batteries
Error 2
(Big Font cannot be selected with characters in memory)
  • Select another font size
  • Select Big Font before entering text
Error 3
(Big Font cannot be selected with: box, underline, 2 line, or lower case)
  • Select another style format
Error 4
(Memory buffer is full)
  • Delete some of the entered text
Error 5
(Text is bigger than defined length)
  • Specify a longer tape length
Error 6
(2 line cannot be selected with the format)
May 04, 2008 | Dymo LetraTAG Thermal Label Printer
CHR SIZE AUTO?
Press the Return button and the machine will automatically print the size the tape will allow! :) Title:
What does the error message "CHR SIZE AUTO?" mean? Description:This message appears when the selected character size is too large for the width of the tape cassette installed.
You have the following options:
  • Press the "Print" or "Return" key to allow the P-touch machine to automatically select the maximum character size that fits the tape width.
  • Press the "BS" key to clear the message, and then install a wider tape cassette.
  • Press the "BS" key to clear the message, and then select a smaller character size by following these steps:
    1. While holding the "Code" key, press the "Size" key. The display will show the current character size.
    2. Keep the "Code" key held, and press the "Size" key until the desired size is displayed.
      If you select "AUTO", the P-touch machine will automatically adjust the character size to the largest possible size.
    3. Release the "Code" to apply the setting.
If you have the correct size tape installed and still get the error message, please try removing the cassette from the machine and reinstalling it. Also, check that the tape cassette is seated firmly in the compartment.
Note
    The following table shows the maximum character size that can be used with each tape width.
    Tape Width Maximum Character Size 1/4" (6 mm) 12 points 3/8" (9 mm) 18 points 1/2" (12 mm) 24 points 3/4" (18 mm) 42 points
Related Models PT-1900
Feb 17, 2008 | Brother P-Touch 1900 Label Printer
Brother P-Touch PT-1830 Label Printer Logo
106 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
