Question about Hayward 116k HeatPro Heat Pump HP3100
I have a EUS PE 52A-102B-5 which was installed in 1995; and it has been working perfectly without any service until last winter season. PROBLEM (after not running for Summer season as I go North); Spa heat pump starts and runs about ten seconds and stops; continues doing such as long as powered "On". Last season it did the same but I wrapped on the internal piping/valve assembly, etc. with a small hammer and it cured the problem for the whole winter season. This year I tried same with no result. By the way, when I first turned it on a couple of days ago, the cycling "off" / "on" occurred a few times and then it ran for an hour or so just fine. Any suggestions? Bob Desrosiers
    Top Expert:
  • Hayward Master
  • 9,908 Answers
Check pressure switch
Posted on Oct 15, 2017
4 Suggested Answers
SOURCE:
  • 22 Answers
SOURCE: Proline 1.5 hp pump gets hot and trips breaker.
motor is locked up in the motor are two bearings they will rust if they are set up for a while.you can take the back off the motor and where the shaft goes thru the houseing take a pair of needle nose plires and try to free it up.
Posted on Jul 10, 2009
  • 198 Answers
SOURCE: Pump is running, no water returned via pool jets
yes---you need to have no air getting in the lines.
Posted on May 10, 2010
heatman101
  • 43501 Answers
SOURCE: I have a 4 year
I would suspect that the motor bearings are going bad....when starting cold they turn hard and kicks the overload....running for a few seconds provides a bit of heat and then they turn a bit easier, but they still turn hard enough that the motor will shut down after a long time... the motor will probably run longer on cooler days or when it is in the shade...
Bottom line is that the motor will need to be replaced....removing the motor from the pump can be a real bugger...and often the pump impeller is destroyed till you get it removed...causing you to need a new pump impeller anyway....
You may be better off buying a complete new unit...check it out first!
heatman101
Posted on Jun 20, 2011
I have a 2005 Buick terraza (similar to uplander/sv6/relay) and I find I go through a set of tires every season. It's ridiculous. My tires are balanced, my alignment has been checked again and again...
take you vehicle to a good service center. you may have a camber that is off or your frame may be bent. causing your thrust angle to be wrong trashing you tires. is it all 4 tires and is there a side that the tries wear on.
Aug 21, 2014 | Cars & Trucks
The automatic transmission of my mitsubishi mini pajero turbo 660 cc model 1995 works perfectly during the hot summers days, but as the winter approaches it stick to 3rd gear until the car warms up and...
sorry jhbkane. ur solution doesnt work..i hav change my this ECU several times but still it dont work in winters...
And alibaba69: i hear this taka taka sound n my pajero mini sometimes when the gear shifts..i have placed a new fuel pump but still its there...Wots this..?? any suggestion plx
Feb 12, 2013 | Cars & Trucks
Toro leaking gas through air filter
The inlet needle in the carb is leaking, it may be the activating arm has stuck, remove the float bowl and gently work the float up and down a few times, make sure the needle is moving. Failing that replace the needle valve.
Apr 13, 2012 | Toro Power Lawn Mower
Can i know life time of panasonic 102b video camera?
The life span of a video camera is relative to how often you use it and how you use it. The camera is mostly the video head. If the video heads are kept carefully by using quality tapes by renowned manufacturers the Camcorder lasts for very long. My on experience is that if your heads are cleaned properly without stressing them then you can go on for years. i have had my camera for a long time and it seems to perform perfectly well up to now.
Oct 15, 2011 | Video Cameras
Battery life poor
Check for cable corosion, and any bad ground or power on.
Dec 17, 2017 | Polar CS100
Is snow tire better than all season tire in winter?
Snow tires are better for Winter But, Change them back out for Spring or they will not last very long on Regular Asphalt. They are made from a Softer Rubber than all Season Tires. Please Rate My Response! Thanks!
Feb 03, 2009 | 2004 Chevrolet TrailBlazer
Hayward 116k HeatPro Heat Pump  HP3100 Logo
203 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
Craig Butler
Craig Butler
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
