Question about Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
My computer speakers don't work - they do if I plug them into external speakers.
    Scholar:
  • 74 Answers
The fact that it works fine with external speakers means that the soundcard works fine.
Make sure that volume isn't too low by holding the FN key and then tapping the F5 or F12 Key to reach a higher volume (depending on what the layout of your keyboard is)
If still does not make a difference, chances are that the internal speakers have developed a fault. You would need to get someone to open up the laptop and have a look. Would not suggest you do it yourself unless you have done before, as they components are more sensitive than a Windows XP one.
Hope that helps, Pls rate the solution
Posted on Nov 22, 2010
I don't have sound on my computer yet i have installed sound drivers and they are working well?
check in your control panel and go to systems.
Then go to hardware and under that go to Device Manager
In there see if there are any exclamation marks in your sound hardware,
conflicts and such.
If there are none then go to Sound Controls in Audio Devices and make sure the audio isn't muted in the windows program
Use this to do an audio test of your speakers.
If that isn't working but it should be check your wires to see if there is a break or if it is plugged into the the green colored jack for external speakers.
Jul 31, 2012 | Creative Labs Sound Blaster Live! 5.1...
After i plugged external speakers into my laptop, the laptops speakers stopped working. I've tried driver updates rollbacks re installs and pretty much everything else i can think of, being a mildly
The laptop speakers should only be cut out when the externals are plugged in. This is done by a little switch inside the jack. If it will not switch back and the external speakers still work fine then I would say that is definitely the problem. There is not much you can do if that is stuck. All the switch really looks like is a strip of metal that is like a spring. When you push the plug in it pushes this to the side and disconnects the internal speakers. The jack is mounted on the main board so you would have to locate the proper one and solder it on or replace the main board. Short of going that far I would see if inserting a jack a few times will get it to spring back. If there has been any spills on the laptop or it is gummed up inside you can use proper electronics connector cleaner. This is risky as it can damage the plastics but doesn't take much at all to work. I would look inside the plug and see if you can see debris or gunk. I'd also try knocking it. This is literally knocking around the switch like you are knocking on a door. You don't want to hit it really hard but just a few short sharp knocks will loosen things up with out causing damage. If you knock like the landlord looking for rent money then it might ;-]
Nov 22, 2011 | Sony Computers & Internet
I bought some surround sound speakers 3-5 years ago and they recently have not been working properly. First I have to make sure the external sound card is plugged into the computer so it will register it,...
first did all of these speakers work together at any stage
if not you will have to get yourself an external sound card possibly a usb portable/removable sound card
Dec 07, 2010 | Logitech X-530 Computer Speakers
Drivers missing
most computer speakers don t use a "Driver" they are typically controlled by the "Sound card" drivers. Typically there are three jacks that computer speakers fit into. look for a green receptacle to verify they are plugged into. Typically (pink = microphone) (blue = input) . Check your power input to the speakers, very common to become unplugged from the wall outlet. (however some speakers do not have external power source) verify , mute is not checked off. (speaker icon by the clock) check control panel , speaker settings. ...sometimes people inadvertently check off "digital output only" which effectively turns the speakers off.
Aug 25, 2010 | JBL (JBLONTOUR) Computer Speakers
There is no volume on the tv, the volume bar goes all the way to 99 but there is no sound, i plugged in external speakers it worked but the tv volume is not working. How do i fix this problem?
Go into your Audio menu on the TV and make sure the TV speaker are set to “ON”.
If the external speakers work when connected to the TV and the TV’s internal speakers don’t work when you remove the external speaker’s plug from the TV, then you will need to replace the main board.
The main board has all the function for the audio for the internal speakers. This was a known issue for some of the LG TV’s. So if you call LG about this issue, LG may fix it under a warranty.
Good luck.
May 21, 2010 | LG 26LG30 26 in. LCD TV
I need a driver for acer speaker
You don;t need drivers for external speakers. Just plug in.
Dec 21, 2009 | Acer Aopen MS698 Computer Speakers
Built in speakers not working
Are you using external speakers? or internal?
EXTERNAL SPEAKERS: If your are plugging speakers into your headphone jack and they dont play, but you plug headphones into the same port and they work fine.. then it is the external speakers.
INTERNAL SPEAKERS: But if you are using the speakers in the laptop, then your speakers are probably bad. Try some software settings, but probly just bad speakers. Could also be that the speaker cord inside the laptop came unplugged from the motherboard. In which case you would have to take the laptop apart and plug it back into the motherboard.
Good Luck.
Sep 08, 2009 | HP Compaq nx6115 Notebook
Plug in external speakers w/ volume very low in HP2009m screen
check if the external speakers u plugged in came with an internal amplifier, if not then u will have to use an external amplifier to get max output from your external speakers.
Sep 02, 2009 | Audio Players & Recorders
Nonworking speakers
For your monitor with built in speakers, there should be a cable usually the plug is green in color, coming from the monitor which needs to be plugged to the back of the computer for the speakers to work. If you don't see a cable, then there is a plug on the monitor where a cable would go.
Yes you can connect external speakers. They plug into the back of the computer. There are usually round ports on the back colored blue, pink, and green. Figure: http://www.ultimatepcrepair.com/files/bsound.jpg (sometimes there is more, depending on your computer) The speaker cable plugs into the Green color one.
If you need more help just comment.
Aug 14, 2008 | Proview PS 776 Monitor
Speaker Problem
Nothing is wrong. Most computers automatically turn off the internal seakers after the external seakers are connected. Go to cntrol pannel and see what you can do under audio options or some such equivelent. Check back with more problems,
hope this helped/helps.
Mar 10, 2008 | Audio Players & Recorders
Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
65 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
