Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
My craftsman lawn tractor will start but not move. Canyou please help!
Mycraftsman lawn tractor model no. 917.273140 motor will start and run will not move
Posted on Nov 20, 2010
    Problem Solver:
  • 3 Answers
Check your drive belt. It may be broken or fell off the pulley.
Posted on Nov 09, 2010
My lawnmower recently had a belt changeand a new battery and was working for about 15 minutes at the correct throttle location then died off. restarted it and now have to have the throttle all the way up...
You mentioned that you pushed the throttle all the way up. This position on Craftsman lawn tractors is usually the choke position. No power there. Just to aid starting only. As you move the throttle lever you will notice a notch. That is where the throttle should be after starting in order to mow.
If you still have difficulty, you can reply with a good description of what is going on and I will respond.
I hope this helps.
If this was really helpful, please rate.
Jul 13, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lawn tractor does not move repl. both belts pull
What brand of mower? You most likely have a broken return spring on the drive system.
Apr 11, 2011 | Craftsman 20 Hp 42" Deck Lawn Tractor
Ihave a craftsman 20 horsepower riding lawn mower. It starts fine but it barely moves. It stops moving. Seems to have no power, especially if on a slight slope. I had a new clutch installed, but still...
Either your drive belt is loose or your transmission is going bad.
I would have another mechanic, not the one who installed your "new clutch" take a look at it.
Sep 27, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
My riding mower start but it wont move
Is it a Hydro, or belt drive?
Is Hydro on bypass?
Is the belt off, or broken?
May 05, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
When the choke is fully up the, engine cuts out , canyou help me? can it be the carb. needs new parts? never had problems with this mower. tx. in advance guy
When the choke is full up you are flooding the engine, not allowing it to run. There should be a notch on the throttle control where you move it to after it starts. Moving the throttle control fully up helps get the engine started but you do not leave it there to run. Check the air filter as well it may be dirty.
Sep 26, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman LT1000 tractor not moving
hello otto i would check the belt that runs to the rearend but the brakes could be also froze up i would try to jack it up & see if it will move then go from there
Jun 08, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Loss of drive in a Craftsman Lawn tractor
I also have a Craftsman tractor with the same problem. Sears repairman said it needed a new transmission and it would cost $1,400 to install. A new one is about $1,000. Anyway, if you remove the battery and the battery tray under the seat it will expose the transmission fill hole (hex). I opened the top and it looked empty. I had a bottle of 90 weight gear oil in my shop and filled the transmission to the top. I have not had any problems with it since. $4.00 bottle of oil verses a new tractor is worth a try.
Mar 30, 2009 | Craftsman Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
481 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
john h
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
