Question about Dryers
Whirlpool Dryers Model LEQ9508LWD does not start problem I used to be able to start it by wegling conection of the dryer load door and dryer. now it stoped completly
  • 144 Answers
It sounds to me you could have a faulty door micro switch or the door is not aligned properly. When you open & close door the switch should operate so the drum stops when you take things out of dryer.
There will be a little plastic pillar on the door which presses the switch when door closed. Make sure the door isn't warped.
Pete
Posted on Nov 06, 2010
Kenmore dryer,, looking for adiagram for the belt on a kenmore dryer
Below are the belt diagrams for Kenmore dryers.
Figure 1. Whirlpool-made Kenmore dryers with removable back panel, filter on top, and model numbers starting with 110 or C110.
Figure 2. Whirlpool-made Kenmore dryers with non-removable back panel, filter below the door, and model numbers starting with 110 or C110.
Figure 3. Frigidaire-made Kenmore dryers (model numbers starting with 417).
Mar 01, 2011 | Kenmore Dryers
The model number of my Whirlpool dryer is LER4634JQ0. When I push the start button nothing happens. I have checked the fuses, the door latches and the plugs. I had been using the dryer on the day this...
Lift top up, it is hinged, and check if belt that is supposed to be around the drum and motor is broken. If it is broken it's a fairly easy fix.
Feb 23, 2011 | Whirlpool Dryers
Model #leq9508lwd dryer heat will not kick off!!!
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 04, 2010 | Whirlpool LEQ9857L Electric Dryer
My Whirlpool Estate: Model tedx640jq1, stopped working in the middle of a load and now will not start.
i would check the door switch, part #3406104 and the drum belt part #8066065. hope this helps.
Nov 13, 2009 | Whirlpool TEDX640PQ Dryer
Dryer ran fine, then when tried to dry another load, would not st
Mar 21, 2009 | Whirlpool Dryers
Whirlpool duet dryer lock is loose
You have to change the plastic catches there are 2 one on the top and one on the bottow of the door
Jan 14, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool dryer model LEQ8800JQ won't start when push start butto
I posted today (Jan 2, 2009) that I had same problem. Handyman tested for blown thermal fuse, etc and everything was fine. He said I have to replace the timer switch .. well guess what - I fidgeted with the start button (on/off) hard a few times while simultaneously pressing & releasing door switch and it did the trick. In my case the problem was most likely with the start button. Dryer is working fine now!
Jan 02, 2009 | Whirlpool LEQ9858P Electric Dryer
Dryer will not start after bulb burned out.
moch, the fact that the light is staying on when the door is closed leads me to believe that the door switch is the culprit. If that switch is not made you will not start. See if the pin is broken off. Start there and let me know. Catriver.
Aug 10, 2008 | Whirlpool GEW9200L Electric Dryer
Whirlpool Model LG7681ZSN1
check the door switch if it is working then a broken belt can cause this problem let me know how you make out
Sep 13, 2007 | Whirlpool LGB6000KQ Gas Dryer
Dryers Logo
105 people viewed this question
Top Dryers Experts
