Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
How do you take off the front cover to get access to the inside of the washer?
    President:
  • 1,430 Answers
Tip
Manual Door Unlocking of Maytag Neptune Front Load Washers
Maytag Neptune Front-Load Washers are equipped with emergency access cord that can be used to unlock the door when the door lock mechanism fails to unlock it after a wash load is done. The emergency access cord is located under the top cover and can be accessed through the dispenser bezel. Make sure that power to the machine is disconnected prior to servicing to avoid the risk of electric shock.
Remove the four screws securing the dispenser bezel to the top cover then lift the bezel off to access the emergency access cord. Carefully pull the emergency access cord steadily then open the washer door.
The pulling of the emergency access cord overrides the wax motor and the sliding gear is pulled from right to left away from engagement with the rotating gear. It allows the rotating gear to release the wire loop of the door.
The failure of the door lock mechanism to unlock the door is due to a failed wax motor in the extended position. This requires the wax motor to be replaced. Access to the door lock mechanism for the wax motor replacement requires the removal of the front panel and lifting the top cover. Click here for the detailed front panel and top cover removal procedure.
on Apr 21, 2010 | Maytag Neptune MAH5500B Front Load Washer
Tip
Maytag Neptune Front-Load Washers Front Panel and Top Cover Removal
Most of the internal components of Maytag Neptune Front-Load Washers can be accessed with the removal of the front panel and lifting of the top cover. The top cover can only be lifted after the front panel is removed. Make sure that power to the machine is disconnected prior to servicing to avoid the risk of electric shock.
The first step is the removal of the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly. Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the machine.
The top cover is held on each side of the cabinet by hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top cover lip.
Remove the four screws securing the dispenser bezel to the top cover then lift the bezel off. Open the door then lift the front of the top cover and tilt it toward the rear of the machine.
The internal components of the machine can now be accessed. Reinstall the top cover and the front panel in reverse of the removal steps.
This procedure is also applicable to Maytag Square-Front (1998) and Sloped-Front (1999) Dryers (Maytag Neptune Dryers). The only difference is the dispenser bezel removal.
I have an Axxis+ washer/dryer. The washer is giving me an F:34 error, any ideas?
you can try this I had one of these the other day. On the bottom front of the washer you will find a round access cover, rotate it to the right to remove it, inside you will find a green cord to manually unluck the door, pull it down. Door should now be unlocked. Chances are the door won't unluck because the wash water is not draining from the washer due to a clogged drain pump. Right behind that round access cover is the water pump. Before you open the pump cleanout, soak up all the remaining water inside the wash basket of the machine, or use a wet dry vacuum to vacuum up the water. Have a shallow pan and lots of bath towels to catch the water when you open up the drain pump cleanout. Check the drain pump cleanout for lint, small socks, coins and whatever gets left in pockets of clothes.http://servicetechhelp.com/discus/messages/2801/65423.html?1241057606
May 03, 2010 | Bosch Axxis WFL 2060 Front Load Washer
How do i remove rubber seal on hotpoint washing machine for getting in to door lock
No need to remove seal.
Remove top cover, undo 2 screws securing door lock. and reach down inside the washer to access the door lock.. This is the easy to do it.
Feb 04, 2010 | Hotpoint Aquarius WD63 Front Load...
Were is the drain system manualy
To access thr pump and filter, remove lower rear cover of washer.
The pump and filter are located at the bottom rear right of washer.
To clean filter, remove large black hose onto drum, and clean filter inside hose.
Hope this helps.
Jan 15, 2010 | Hotpoint Aquarius WF000 Front Load Washer
How to remove back from machine
There is a small cover at bottom rear of washer, this is the only access into the washer from the rear.
Simply undo the pozidrive screws, and remove cover.
Any other access is from the top, or by removing the front panel assy.
Hope this helps.
Jan 04, 2010 | Hotpoint WMA58 Front Load Washer
Bosch Error Code 13 Washer won't drain
First, unplug your washer. After that find the little round plate below your drum opening on the exterior of the washer. It should have a small hole in it. Use something to gently push trough this hole and twist the cover off, Inside there you will find the drain access. Be careful, if there is water in your drum this will make a mess when you unscrew the drain access. Take the usual precautions and unscrew the drain access slowly until it is off. Remove any obstructions and replace access door and cover. Clean up any mess and plug back in your washer and try again. takes about thirty minutes to an hour depending on how much water is in the drum.
Apr 18, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
GE Spacemaker stackable washer/dryer
The front cover come off by removing two philips screws on the bottom of the panel. That will expose all the operating parts of the washer.
Sep 17, 2008 | GE WSM2700W Unitized Spacemaker Washer and...
How easy to access the 3 screws?
Underneath. Don't see original post here, but to replace a pump (actually, just the pump motor) on an LG front load washer: Drain water out of small hose inside recess and remove access door cover (at lower left of machine). Remove one phillips head screw and use a plastic putty knife or similar tool to push in on left or right side of recess to remove the plastic recess cup. Now remove the two other phillips head screws visible. Tilt machine back and access pump Assembly from under machine. There is a tab that you will have to work loose. Disconnect electrical wires from pump at disconnect plug. You probably want to remove the hoses going to and away from the pump (squeeze clamps). Pump motor is easy to change out now with three more phillips head screws.
Sep 02, 2008 | LG WM-2277HW Front Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
