Question about Hoover V1 SteamVac SpinScrub Vacuum
Will not **** up the water
Cleaner will spray out water but will not **** it up and return it to the empty tank-I have cleaned it thoroughly
    President:
  • 1,673 Answers
Make sure that the lid on the recovery tank is locked down all of the way around. Sometimes the back side isn't locked in. If the lid has a foam filter on it, make sure it has at least a 1/4 in. gap from the top of the filter to the top of the tank. There also is a filter from the bottom, it has a red frame, pull it out far enough to clean it. Also some of these had a duct that sits in front of the recovery tank, if not there, then no suction.
Posted on Jun 17, 2008
My Bissell wont spray water
Then check out the plumbing and mechanism responsible for the spraying of the water. Trace it out.
Aug 27, 2016 | Bissell 9500 ProHeat 2X CleanShot Upright...
Hoover SteamVac LS F5899-910
Did you try to clean first the unit..
Jun 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Water won't spray when I squeeze the trigger. How do I get it to spray the solution?
Hello, this is Ava with Think Crucial.
There are a number of reasons why your unit doesn't spray water. It could be that the !) water tank is empty which you can fill heavy duty bladder with hot tap water. 2) If Formula tank is empty, you can fill it with Bissell 2x formula for cleaning. 3) If tank may not be seated properly, turn the power off, remove and reseat the tank. 4) If pump may have lost prime, try to turn off and then turn on the unit, wait for one minute and depress trigger. If still nothing happens, I suggest you contact Bissell 1-800-237-7691 for further assistance.
I would like to let you know that you can order replacement parts for your vacuum needs. Please visit our website
http://www.thinkcrucial.com/search?type=product&q=bissell
As a special offer here is an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
Think Crucial Customer Care
Jun 10, 2016 | Bissell ProHeat Turbo Deep Cleaner Upright...
My formula tank is not emptying on my 8910 proheat eurka cleaner
Make sure it is on heavy traffic on the selector set. You may find it is on Clear water rinse. FYI you will find your machine will clean better and your carpet will be cleaner if you use a weed sprayer and mix your soapin it. Just spray it down fairly heavy and let it set for 10 minutes. Then just use straight water in both tanks and you will be amazed. It is like a lasagna dish if it soaks for a while it comes cleaner easier.
May 13, 2014 | Bissell 8910 ProHeat Clear View Upright...
Not spraying water and solution
Tanks may be empty or not properly seated.
-Fill up the bladder with hot water and the solution tank with proper cleaning liquid.
-Remove and reseat both tanks
Pump may dry, needed to prime.
-Turn "off" power wait for about minute turn "on" power and depress spray trigger.
Check and clean filter on the deck (under the clean water tank, a red slotted plastic screw)
If nothing works you have to open the deck cover and go into details: check the pump, its a 12V DC motor, the solenoid, its a valve which operates with 120V, the hoses for broken or pinched part, the diode bridge (creates about 12V DC for the pump if the vacuum motor is turned "on" and the secret fuse (3,15A under the heat-shrink series to the diode bridge, if this one goes, no power to the pump!)
Mar 09, 2014 | Bissell ProHeat Pet Upright Deep Cleaner,...
My bissell sprays solution and water but does not **** it back up. After the water and solution are gone the return tank is completely empty
1) check the tank is full of water
2)check gasket position,can be worn, or damaged fix it
3)check the belt worn for inoperable brushes.
4)check motor duct gasket, and test it. yif you notice suction in the duct, remove the tank, for assure is properly attached.
5)check the hose is attached properly at the back of the machine
6)check the lint screen in the water tank for trapped debris
7) remove any brushe from debris.
8) repair a tank debris.
God bless you
Jul 10, 2012 | Vacuums
Does not spray cleaner
It helps to always run hot water in the soap holding tank after you have cleaned the carpet to make sure the soap does not dry inside and clog. Make sure that the dirty tank water filter is clear of debris, I have noticed that if it is clogged it won't spray out solution. Another thing to try is, it usually will always spray out of handheld cleaning attatchment. steve
Jun 06, 2010 | Bissell 1699 ProHeat Clear View Upright...
Wont spray the cleaner n water out
check the dial setting. - presoak, off, cleaner, rinse
is cleaner bottle correctly inserted?
is clean water resevoir empty?
is dirty water resevoir full?
these items will prohibit the water/cleaner from coming out.
Mar 28, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Hoover V1 SteamVac SpinScrub Vacuum Logo
407 people viewed this question
Top Hoover Vacuums Experts
Roger Potts
Mike Cairns
Mike Cairns
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
