Question about Bosch Dishwashers
My bosch shx46ao5uc just quit working during the middle of a wash cycle. I checked the power and it still has 120vac power being supplied.
  • szudell Nov 06, 2010
    Daniel, it seems as if it has no power, it is completely dead but it does still have power being supplied.
    it seems as though it is completely dead. it does still have power being supplied though. The soultion you supplied does not do anything.
  • Bosch Master
  • 3,247 Answers
Getting 120vc power to the dishwasher may not mean the dishwasher is ok.
It is likely the on/off switch is open. Item 102 in this diagram.
Also check this site for circuit diagram.
Posted on Nov 07, 2010
  • 4,323 Answers
Hi
You can press and hold the Cancel-Drain or Cancel-Reset buttons for 15 seconds to reset the control. After this if you see the same issue then the control should be replaced. Please let me know if you need more help.
Daniel
Posted on Nov 06, 2010
  • Daniel Scott
    Daniel Scott Nov 07, 2010
    If the previous solution did not help then you'll have to replace the control.
    Daniel
The water supply line to my Bosch dishwasher (model # shx46a06uc/21) froze. We didn't realize this and tried to run the dishwasher. Now the line is unfrozen, but the dishwasher still won&#
Check for water supply to the valve. Check for 120vac at the valve during fill cycle. If you have both, the water inlet valve is bad, part number 00425458.
Jan 12, 2015 | Bosch Dishwashers
My whirlpool calypso washer just quit working no codes no power just dead. GVW9959KQ2
Won't Power Up
  • 120VAC electrical supply.
Check voltage supply to washer.
  • Open AC cord.
Check for voltage at the power cord connection to the line filter.
  • Line filter open.
Check voltage into and out of line filter.
  • Machine control board open.
With the washer off but connected to the AC outlet, measure the AC voltage between Pins 4 and 2 at connector P16.
Dec 23, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
My bosch shu43co5 made a burning smell and stop working in middal of a wash the breaker seems to be fine and trying the power button/ powerscub/ reg wash don't get any lights on. what is my next step in...
Welcome to FixYa.
**Before I begin I will inform you B/S/H/ ( Bosch Thermador, Gaggenau ) issued a recall on certain models between 1999 - 2006 depending on the serial number.** Here's the link so you can see for yourself.
http://microsites.boschappliances.com/safetyrecall/dishwasher/
Aside from that and based on your post "my bosch shu43co5 made a burning smell and stop working in middle of a wash the breaker seems to be fine" it may just be a loose/burnt connection in the dishwasher junction box.
**Now I would start by first shutting off the breaker...safety first**
Then removing the kick plate ( access panel at the bottom )...
...and checking the wiring at the junction box for the dishwasher 120vac supply line.
Remove the murret's and visually inspect the wire for "resistance burn" and strip the wires back and install new fastener's if necessary to repair.
i.e.
This is actually quite common to find a wire connector come loose due to improper fastening and once the unit is in use for a while the connections heat & cool, become loose from normal operating vibrations and burn up from all the added heat caused by "resistance".
Typically this will manifest in just the manner you've described.
Let me know what you find and I'll try to assist you further if necessary. I'd still suggest looking into the possible recall for your machine though.
Regards,
Macmarkus :)
Dec 20, 2010 | Bosch SHU43C05 Stainless Steel Built-in...
Bosch dw shu043 dishwasher stopped working in middle of cycle
Hi and welcome to Fixya. Based on your post, I would start by first shutting off the breaker. Then removing the kick plate ( access panel at the bottom ) and checking the wiring at the junction box for the dishwasher 120vac supply line. Remove the murret's and visually inspect the wire for "resistance burn" and strip the wires back and install new fastener's if necessary to repair. This is actually quite common to find a wire connector come loose due to improper fastening and once the unit is in use for a while the connections heat & cool, become loose from normal operating vibrations and burn up from all the added heat caused by "resistance". The end result is no power to the controls. Check it out and post back what you find. Thanks for visiting "fixya" and please take a moment to rate the solution/suggestion provided here for you. Good luck. Macmarkus :)
May 19, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
My Bosch SHU33A stopped working part way through the wash cycle. Soap dispensed but water didn't drain. The power button doesn't work now. I checked the electrical breaker and it is on. I am puzzled as to...
Hi, I would start by first shutting off the breaker. Then removing the kick plate ( access panel at the bottom ) and checking the wiring at the junction box for the dishwasher 120vac supply line. This is actually quite common to find a wire connector come loose due to improper fastening and once the unit is in use for a while the connections heat & cool, become loose from normal operating vibrations and burn up from all the added heat caused by "resistance". The end result is no power to the controls. Check it out and post back what you find. Thanks for visiting "fixya" and please take a moment to rate the solution/suggestion provided here for you. Good luck. Macmarkus :)
Apr 22, 2010 | Bosch 23 in. SHU33A Built-In Dishwasher
Washing machine quite during the middle of a cycle.It has no water,doesn't spin,doesn't make any noise at all.The dryer still works so im sure it getting power!Any help is very much appreciated
Check power to controls on washer first. If no power change sockets in wall duplex to rule out bad duplex . Timer would work in at least one cycle mode so we'll rule that out. Door safety switch would cause sudden stop of machine
Mar 09, 2010 | Washing Machines
My Bosch WFL 1220 MAXX F/L washing machine stops during a cycle
The diagnostics are finding a proble. Usually a time out on the fill or empty. Check water supply is clear and that the drain filter is clean
Dec 08, 2009 | Washing Machines
Bosch Dishwasher with very little water pressure or power
It all stems back to your incomming water supply. Either the sieve is dirt or the valve is blocked with sedementation. Some valves are servicable and some are not,if your valve has screws then its revicable. (low water pressure restricts movement on arms.)
Sep 18, 2009 | Bosch 24 in. SHX46B05 Stainless Steel...
Dishwasher quit during cycle.
Need a little more info.. anyway.. open dr will shut off dw...close dr.. push power button until power on... lights on, but nothing happen.. try holding down drain and one of wash cycle.. repeat holding drain w/other buttons until you hear drain pump running.. make sure you hold both buttons for a few seconds.. if your drain pump works.. then, you might have a problem w/your wash motor or something is stuck in the impeller area.
Jan 13, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Water left after finishing wash
I have a Bosch Dishwasher and the E-Nr is SGS4362EU/03. The machine is approximately 4 years old, in good condition and has been working very well. Suddenly, there is water remaining after it completes a 50 degrees C wash cycle. This is also evident with the pre wash cycle and the 65 degrees wash cycle.
I have checked and cleaned the filters. I have loosened the internal pump white cover (Torx T 20 screw) and checked for any physical blockage - none. I have also checked for any drainage hose kinks - none.
I have tried a series of empty washes and the machine drains the water during the wash cycles. The dishes are also have a dull colour and show show signs of not being properly rinsed during the wash cycle.
Please assist.
Reagrds,
Brian
Dec 27, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Dishwashers Logo
111 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
