Question about Solis Master 5000 Espresso Machine
After moving my machine from MD to WI (it was shipped laying on its side) the machine grinds and makes all the usual noises, but instead of dispensing coffee, water pours out of the milk frother.
  • 1,089 Answers
Hi
If you packed it on it steam valve side you bent the valve shaft and its holding the needle open. Your going to have to remove the shaft and replace it with a new one.
Posted on Nov 13, 2010
XL7 has a clicking scraping noise on drivers side in reverse only. Have checked brakes and they look ok. When I put on jacks with the hub off and turn by hand I can still hear the clicking grinding
Where is the noise? Front or back? At the brake or differential? Usually grinding and clicking is the rear brake drums. Brake shoes/hardware. Year, make, and model?
Jan 26, 2015 | Suzuki XL7 Cars & Trucks
Put a game disc into ps3 grinding noise wont show game icon
Make sure that you do not have the PS3 on it's side. Lay it flat. Insert a MOVIE DVD first and see if it will recognize the disc.
If you continue to hear a grinding sound when the ps3 is laying down that could only mean one thing, you need a replacement drive.
Dont forget to Always update your Playstation to the newest firmware.
Dec 24, 2013 | Sony Playstation 3 (PS3) Console
Error message with grinding noise as driver cycles
Make sure the little spring loaded side fingers that grab and hold the cart onto the printhead are not broken. With the unit off, slowly move the carriage all the way left then right to check for a good belt and free movement. Take the carts out and tilt the printer back and forth to see if something has broken off inside, check to make sure nothing has fallen into the paper rollers from behind.
Jun 06, 2010 | Alps MD 2010 Thermal Printer
Kenmore Elite 137889, grinding noise
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the tub.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
The drum bearing is replaced by accessing the bottom side of the washer, and is a not a simple repair.
May 05, 2009 | Kenmore 13789 / 13782 Dishwasher
Incanto Sirius - grinds but cannot hear coffee getting ground
The chute is clogged or the grind is too fine on the machine. To clean chute remove the brew unit and check to the right, clean chute.
Mar 12, 2009 | Saeco 00034 Incanto Sirius Super Automatic...
Ginding noise during agitation
From the GE site.....
Front load washers and some compact model washers do not come with a shipping rod. According to the Installation Instructions for these machines there are 4 bolts, 4 yellow plastic spacers, and 4 metal "p" clamps that need to be saved and reinstalled before moving the washer to prevent any damage to the machine.
Jan 31, 2009 | GE Profile WPSR3120WWW
My washing machine won't agitate and it's making a grinding noise
if its direct drive ( no belts ) there is a plastic coupler that joins the motor to the transmission that shears off when the machine has been overloaded. lay machine on its side look from underneath and look for small plastic pieces on the floor and if so you need to replace the coupler this has happen to us alot of times and we have fixed it ourselves . hope this helps
Jan 01, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Paper Jam...grinding noise
The print head lock is probably not retracting. Look for the white plastic block that pokes through from the paper feed side just in front of the head. Push it in with your finger and move the head to the middle by hand. Now turn the machine on. Then turn it off using the correct method. Then turn it on once more. If it starts grinding again, you screwed the feed mechanism when tugged out the jammed paper (probably pulled it backward through the feed instead of making it go forward and out the correct exit). If this is the case, you may as well bin it. If it in warranty, you can try to get a claim for repair.
Jun 15, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Makes grinding noises, refuses to scan; WinXP
take a look on the underside of the scanner. there may be a switch that goes from lock to unlock. try to move it to lock and back into unlock. this lock is usually used to lock the bar from moving during shipping. if this got moved back to lock or bumped while you had it turned over, the scanner will not allow the bar to move.. try this first.
Aug 16, 2007 | HP ScanJet 6200C Flatbed Scanner
Grind is too coarse and "pucks" are wet and fall apart.
You say " I am getting a weak brew because of not being able to adust the grind to more coarse with the adjustment knob in the bean hopper" By making it more coarse you are making it weaker. Unless you just wrote it wrong. To make it stronger you should lower the grinder number to a smaller number. Usually about 4-6. Be sure you have the grinder grinding when you move it to a lower number. The pump noise could be that in shipping your pump came loose from it's mount. Nothing you can do without sending it to a Authorized Saeco Repair shop.
Jun 04, 2007 | Saeco Vienna Espresso Machine
Solis Master 5000 Espresso Machine Logo
59 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
graybeard32301
Colin Stickland
Colin Stickland
AZBen
AZBen
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
