Question about MSI K9VGM-V Motherboard
Hi, i got a motherboard msi k9vgm, i wonder why every time i push the power button its only about 2 secs and it will shutdown. ive already test the avr, powersuply,memory, processor and video card all are in good conditions,and Ive already done doing reset the bios nor changing the bios battery.. anyone pls help me how to repair my motherboard thank you..
  • joecoolvette
    joecoolvette Nov 06, 2010
    How did you test the Power Supply? Do you know if whoever worked on the computer/motherboard that they observed Anti-Static Precautions? If the motherboard has been removed from the case, and reinstalled in another case, was it ensured that the Standoffs on the Support Plate were matched to the mounting holes in the motherboard? (Metal spacers, hex shaped, are Standoffs. Support Plate is the metal area under the motherboard in the computer case, that the motherboard attaches to) EVERY Standoff lined up with a mounting hole? If not, a metal standoff could short against exposed solder joints on the bottom of the motherboard. Post back in a Comment.
  • charmed_10cc Nov 06, 2010
    i've got 2 desktop pc in my room,,,the other one is my primary so i pullout the powersupply so i can test it to (mSI K9VGM board) still the same problem...2secs with power and it will automatically it will shutdown..ive already pull out the mother board to its casing and place it to my motherboards box...and try to troubleshoot it...try to look if my capacitors are blown up...and i find nothing?thank you
    Genius:
  • 1,672 Answers
try to get or borrow a working PSU(Power Supply Unit) and try to use it first!
Posted on Nov 06, 2010
  • Bayyagg
    Bayyagg Nov 06, 2010
    Try to look at your PROCESSOR, if you got another one, just to check on your board, if its going to power up!
    Either your processor conked out or its overheating, your heat might not be installed properly!
    try cleaning the PASTE between your heat sink and processor and put a NEW paste!
Hi Is there a PCI Express slot on the motherboard MSI K9VGM-V I see 2 PCI slots and another white slot above is this for a PCI Video card THANKS
On your MSI K9VGM-V, you do have a PCI-Express x16 slot, which is used for most video cards now days. You can see the full slot diagram on the picture below.
The one for the video card is labeled: PCI Express x16 Slot
Hope this helps. If it does, please accept and rate the solution! Contact me with any more questions you may have. Thanks for using FixYa!
May 24, 2011 | MSI K9VGM-V Motherboard
I have windows 7-64 biti end i need this drivers.thank you----my motherboard is---K9VGM-V
You need to go to MSI's website and get the drivers from their support link for that particular motherboard.
http://www.msi.com/product/mb/K9VGM-V.html#/?div=Download
May 08, 2011 | MSI K9VGM-V Motherboard
K9N6PGM2-V2 motherboard.. I power it on & the monitor doesn't come on..I have had it about 2 months & this is the first time I had a problem. I change out my dvd player & when I turn it back...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to boot
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Dec 05, 2010 | MSI K9VGM-V Motherboard
Msi k9vgm ms 7253 driver
Download here at msi:
http://www.msi.com/product/mb/K9VGM-V.html#/?div=Driver&os=XP%2032
Select your windows system.
Find the audio driver and download it.
Unzip the file before you install.
Good luck
Oct 01, 2010 | MSI K9VGM-V Motherboard
I need the mothert board diagram
Download the manual for your MSI K9VGM-V MB. Click on the link provided;
http://www.msi.com/index.php?func=searchresult&keywords=k9vgm-v&table=download
You will need Adobe Reader to view the manual. If you do not have Adobe you can download it at Adobe's web site;
http://www.adobe.com/products/reader/
Mother board layout is on page 1.
Cheers!
Mike
Sep 10, 2009 | MSI K9VGM-V Motherboard
No audio after installing 2*2GB
Your motherboard supports maximum 2GB RAM. So, the problem is due to the 4GB RAM.
Check your motherboard details here:
http://www.msi.com/index.php?func=prodmbspec&maincat_no=1&cat2_no=&cat3_no=&prod_no=260
Hope this solves the problem. Thanks.
Jul 22, 2009 | MSI K9VGM-V Motherboard
Win 98 on K9VGM-V
hi im josh in cebu phils.may i help you? friend if mainboard doesnt support the video. You just buy a new video card and install it sothat it can be used at the same time it will gve you better performance cause the video nw works its own.good luck
Feb 20, 2009 | MSI K9VGM-V Motherboard
Power lead
The Switch is non-powered except by the board.
Black should go to power or + side
It's like a wall switch for the light (power comes in on one side and out on the other) If it were a push in to a detent (like the Old 386's and 486's with AT power supply) to connect and a push in to release the detent it would make a difference. With these power buttons on the cases now, it doesn't.
Apr 19, 2008 | MSI K9VGM-V Motherboard
No video, no beep
hi h3rcu135,
the problem is not in ur motherboard& not ina ram the problem is that ur motherboard does not support 2gb ram.it will support 1gb of 667 or even more but not 2gb
regards
shailesh
Mar 10, 2008 | MSI K9VGM-V Motherboard
2 x 1gb memory on 1 board doesnt work
Dear H3rcu135,
is the chipset & frequancy of both RAM Module is same???
Check it maybe the Frequancy is mismatch.
Cheerup
MSI K9VGM-V Motherboard Logo
142 people viewed this question
Top MSI Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Terry Hair
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
