Question about Whirlpool Washing Machines
How do I connect the drain hose from my whirlpool washing machine to my duratub? The washing machine has a corrugated drain hose already attached.
  • 487 Answers
The drain hose needs to be attached appr. 32 inches above the floor and needs to have an airgap between the drain pie and the drain hose in order not to sifon the water out of the machine.
What you can do with the duratub is:
Hole in the side where the washer is. Get a drain pipe for your duratub with a side connector for dishwasher and/ or washer. make sure that the Ptrap is at least 5 inches below the connection point in order not to have the sifon effect
Posted on Jun 15, 2008
My lg front load washer posted this ER: check the drain and the hose. we checked all the drain. but the machine stopped when it was on SPINNING. the ER POSTING : CHECK THE DRAIN is back
Water comes out of the drum through a soft corrugated hose, into the filter, out of the filter through another soft corrugated hose into the pump and out of it through the hose that is put to the drain. Have you checked all of these pipes? Sometimes something small can get past the filter and get stuck in the pump. If it is all clear, then perhaps the pump is faulty.
Aug 03, 2015 | LG Washing Machines
My whirlpool duet front load has been leaking. It leaks only when doing a load of laundry. Leak is coming out the back and on the right side. Took the front bottom off to see if I can see anything and...
First, make sure that the washing machine is not too close to the wall behind it. This could crimp the drain hose & force water out at the connection behind the machine. This could also crack/split the washer machine's port (to which the drain hose attaches). Second, check the hose clamp for a secure hold at the washer machine's port, & check the drain hose for leaks & for insertion in the drain tube at the wall.
Feb 22, 2015 | Whirlpool Washing Machines
Error code e 18
E18 generally indicates a time out on the drainage. Check the pump filter (bottom right of base plinth), also check that the drain hose isn't blocked (particularly if it is connected directly to the u bend of the sink via a spigot). Take off the spigot from the u bend and then disconnect the spigot from the grey corrugated drain hose, check both parts are clear.Best of luck
Nov 26, 2011 | Bosch Washing Machines
My Maytag Neptune washing machine makes clothes smell moldy
The problem may be standing water in the discharge hose. If this is the case unplug the machine and remove the hose from the back of the machine, and water will poor out. If you smell mold from the hose, this could be the cause. Rinse the hose out thoroughly with bleach, if its a corrugated hose they are prone to standing water inside and you may want to replace it with a non- corrugated hose. I suggest you run the machine when hose is re- attached with only bleach a couple of times and leave the washer door ajar to completely dry the inside of the drum afterwards, too. I hope this helps you! Good luck!
Dec 29, 2009 | Washing Machines
Need 90" Drain Hose for GLET1041AS1 Stacked Washer/Dryer. Part Number on Hose is: 1314612 OEM 3
The part number of your original drain hose is 134049200. There is an 8 ft corrugated drain hose with a part number SSD8 and has a universal end which you can cut to fit, and is approximately 96 inches long. hope this helps.
Thanks
Oct 11, 2009 | Frigidaire GLET1031 Top Load Stacked...
Hose on whirlpool washing machine
To the pump at your drain line. up top.
Feb 14, 2009 | Washing Machines
Whirlpool Washer Won't Drain
Did you replace the timer motor? The little motor attached to the timer that moves it thru the cycles. Also, I would check to see if the water level switch might be stopping it after the wash/rinse cycle. I've attached a URL that will show you the various components. If you need more help, feel free to post.
http://www.appliance-parts-warehouse.com/whirlpool-parts/Whirlpool-Washing-Machine-Parts/Whirlpool-Parts-LLC7244BZ0.cfm
Nov 08, 2008 | Washing Machines
Washing Machines Logo
144 people viewed this question
Dan Webster
Dan Webster
Sal De
