Laars xl400 pool heater
Heat comes on for 15 seconds then shuts off
  • 1 more comment
  • clif-63 May 04, 2009
    I have the same problem. comes on... 15 seconds then goes offf...comes on..then off. then after 3rd cycle goes off completely
  • hal6 May 17, 2009
    Same here.  Please find a solution for us.
  • Lehavi May 23, 2009
    I have the same problem Anyone got a solution? Does anyone think its the flame sensor?
Posted on Jan 21, 2009
Laars N G pool heater keeps shutting off then restarts
check gas pressure and the size of your line if too small a line and too long a run from the meter it will run out of gas in line then line fills back up heater fires and drains line again
Jul 25, 2012 | Teledyne Laars Laars Lite2 Heater 175000...
Pool heater comes on for about 15 seconds and then kicks off. A minute later it will do the same thing. Already replace hot surface ignitor probably because of over use. What ca the problem be?
I run into similar problem. Generally means filter is dirty. Run filter on RINSE or BACKWASH for a few seconds then try again. I am sure this is the cause.
Jun 28, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
We have a laars lite 2, when we openned the pool
Thank you for posting your question here on Fixya.com.
It could be...does it open up at the point the heater shuts down? Check it with a DMM to see. It is more likely an issue with flame recognition off the pilot/ignitor. Check them for rust that would cause a faulty connection.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
May 30, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
I have a Jandy Laars LX Pool/Spa Heater...when I try to heat it cycles three times then tells me to call for service...I feel heat coming out of the vent. The pool/spa is connected to a AquaLinks system...
If the unit is lighting then shutting off then repeating it isn't rectifying, means not sensing the flame. May have a bad flame sensor or ignition control. I'm guessing your AGS is indicated on the GUI also.
Mar 05, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Swimming pool heater
try removing and cleaning flame sensor with fine steel wool.its located in lower end of burner box,usually opposite side of ignitor
Sep 02, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Laars Teledyne Pool heater flames on for 2 seconds, shuts off
pull out flame sensor and clean with sand paper or emmoring cloth then try again should work (small black wire with sensor sitting above burners)
May 05, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Heating & Cooling Logo
189 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
