Question about Samsung SyncMaster 753S 17" CRT Monitor
My samsung syncmaster 594mg monitor display (Brightness) flashing and goes to black
TombaLaBomba
SOURCE: Control Lock Problem w/ my Samsung SyncMaster 551v (black) monitor
with other SyncMasters pressing the "menu" button for at least 5 seconds helps ...
Posted on Apr 18, 2008
  • 7 Answers
SOURCE: flicker then display goes black
My samsung syncmaster 225bw when turned on would have the back light stay on for about one second, then go black, with or without the signal cable attached to the computer. After your screen goes black, shine a flash light on the screen to see if you can see any images
I repaired my monitor by replacing several bad electrolitic capacitors on the inverter board. These capacitors had broken bulging leaking vents on ther tops. There were two 820uf 25v and one 330uf 25v electrolitic capacitors that had failed. I ordered from www.digikey.com Panasonic FC series low impedance electrolitic capacitors, However, the 820uf was not curently stocked and had to be backordered, so I got one 1000uf and one 680uf to replace the two 820uf which were in parallel on the board. There were two 680uf 25v on my board which had not yet failed, so I also replaced them. On my monitor, the capacitors can not be longer than 20mm, due to space limitations. These electrolitic capacitors have a life time between 1000 to 5000 hours, so when you order get a few extra of the ones that went bad.
Posted on Jun 23, 2009
oldrogers
  • 53 Answers
SOURCE: Syncmaster 910t blinks image perfectly once and goes back to black
I've had same problem and I fixed it!
With good CCFLs, clean supplying voltages, all good capacitors and resoldered junctions, the backlight still turns on for fraction of second and goes off.
It is in the Power Supply / Inverter board. In the Inverter part there are two dual n/p-MOSFETS U3 and U4 (models STS7C4F30L, SO-8 packages). I've found they both have too high ON-Resistance (perhaps due to age and constant overheating). All you need to do is to replace them. I've checked many models and found closest by Rds and IDcont (continuous drain current) are IRF7389, you can find distributor by findchips.com, but I've bought them at newark.com, they're cheap.
The hardest thing was to unsolder old chips, they are glued to PCB and because of overheated material under them, the copper could easily go apart. Therefore, the best is using fine tips cutters, cut off all legs one by one and then take chip body off the PCB and take legs from pads by iron. That's all you need. After that my monitor started working as new even with old CCFLs. Good Luck!
Posted on Sep 09, 2009
  • 732 Answers
SOURCE: Samsung SyncMaster 940n monitor that turns on then goes black
rcpips, You may need to replace one or possibly 5 -8 aluminum can "electrolytic filter capacitors" on the "switch-mode-power-supply/CCFL inverter board. If, as you say "works for 5 or 6 seconds" then that means that fuse is good. Another thing you will need to inspect SMPS board for is "cold" "frosty looking" solder joints where the components (surface mount or through hole) are soldered to the copper circuit traces. May need large magnifying glass or low power inspection microscope to locate them. Resolder any that look bad or loose. Some solder joints have thinner than "hair" thermal fractures that can also cause YOUR TYPE OF SYMPTOM!! PARTS: digikey. mouser. newark. and possibly Radio Shack. If buying filter capacitors, make sure they are rated 105 deg C only!! NOT 85 deg C!!! If caps need to be replaced (swollen, leaky) be sure to tell us the brand name you find installed on your unit! CAPXON, ELITE, JUN-FU are just 3 that you don"t want to find in your unit. BAD news if you do!! If DIY suits you, remember to document with "close-up" digital stills your unit tear-down, so you can reassemble unit without any "extra" parts laying on kitchen table!! Filter capacitors are polarized. You put them in + to +, - to -!!! if you put them in backwards they go BOOOOMMM!!! Hope this helps a little. lmistyrel on aim or 12fixlouie at fixya.
Posted on Jan 30, 2010
Testimonial: "12fixlouie has been most helpful in helping me find a solution to my monitor problem."
SOURCE: samsung syncmaster 920wm after a few seconds from
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault and will need to be replace.
I advice you replace the picture board on the screen of your monitor to solve the problem of the blank screen.
Take care.
Posted on Jul 18, 2010
The samsung t240 syncmaster when switched on shows Samsung Logo then displays for 2 seconds then goes dark. I can barely see some settings to change but trying to change these has no effect. When I switch...
Is this a laptop?
This a common problem for monitors, especially on laptops. This cause by the inverter board. The inverter boosts voltage to light the screen. When goes bad they go bad they often work for a few seconds. If you look closely you can see the screen but the voltage is not there to get brightness.
Dec 06, 2017 | Samsung SyncMaster T240 Monitor
I have a samsung syncmaster 943NW which goes on for about 5 seconds and then just goes black. When restarting the screen it does the same again, goes on for about 5 seconds and then black. Is there...
I had the same problem with this monitor (Samsung 943nw)
When turned on it would only stay on for less then a full second.
When shining a light on the screen I could see what was on it, so it was just the backlight that was shutting down.
After I turned down the brightness of the monitor, the next time I powered on the screen the backlight stayed lit and it was back to normal.
Dec 11, 2010 | Samsung 943NW Monitor
Monitor will flash the display for a second then go black again.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Apr 12, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
I have two Samsung Syncmaster 2253LW monitors. One is about two years old. The other one is new. The older monitor seems to be darker than the new one. How can I restore the monitor to the original...
open the monitor look there is an eht a black big part has a preset rotate it with a screwdriver in on condition of monitor then you can regain the original brightness
Mar 21, 2010 | Samsung SyncMaster 2253LW Monitor
Samsung SyncMaster 174v will display image for 2 seconds then go black. When I turn monitor off and then on again, it displays image with normal brightness for 2 seconds and then goes black. When I plug...
Hi
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Your monitor power supply has several capacitors going bad. You’ll need to have these replaced by a reputable repair person or check my website www.micromendllc.com. Thanks
Mar 10, 2010 | Computers & Internet
Brightness indicator windows does not go away
Dear sir This is common problem observed in many monitors compaq,HP,HCL,IBM this is happens mainly in rainy season due to moisture,by this moisture monitor button circuit get rust inside and button pad remain pressed. so it shows a strip at the middle of monitor like contrast or brightness. So this is minor problem just replace the monitor display control button sensor or circuit.Temporarily you can warm up the monitor by hanging a bulb of 60 watt nearer your monitor to takeoff the moisture.(Dont hang the bulb too near to the monitor). It definitely solves your problem.
Have a Nice Day
Sep 17, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
The display menu keeps flashing and i can't get rid of it.
Bad control chip, mine has the same problem. If under warranty - send it in. I just tossed mine and bought a different LCD.
Nov 08, 2008 | Samsung SyncMaster 720N Monitor
Samsung SyncMaster 915N monitor
Go into advanced settings from the settings tab of "display properties" and select the "monitor" tab, from there, try changing the refresh rate. Toggle "hide modes that this monitor cannot display" if you do not see any other settings in the drop down other than the one that is already selected.
Jul 15, 2008 | Samsung SyncMaster 915N 19" Flat Panel LCD...
Samsung SyncMaster 753S 17" CRT Monitor Logo
472 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
ismael castillo
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
