Question about Olympus FE-170 Digital Camera
I have an olympus digital camera fe-170. when i turn on my camera, the lense come out and the LCD screen is black, when i try to turn it off, it doesnt turn off, but after like 10 seconds it turns off by itself. but when it turns off the lense dont go back in?! then when i try to turn it on, its the same thing. when i plug it into the computer, the lense go back in, but when i unplug it from the computer and try to turn it back on again...SAME PROBLEM. i did drop it before, but can i do anything about this situation? please try to describe in fulll detail IF you can!!
  • 20 Answers
The lens is bad, needs to be replaced. Maybe purchase camera on ebay with broken LCD but good lens. Replacement can be time extensive. Will need #00 or #000 phillips screwdriver and solder iron. Remove 6 exterior screws+2 inside battery door. Take off front panel, remove top screw holding back panel; remove back panel. Remove 2 screws(left side top & bottom)from LCD, unplug LCD by flipping hinge up on plastic connector, pull ribbon. Remove 6 screws along outer edge of electronic board + 2 screws behind lens. Unsolder 2 battery connectors near top right side(do not melt or burn ribbon in between them). Disconnect ribbons at top right and on left edge of board. Flip board over to the left side carefully as it's still connected by 4 thin wires. Remove 3 outer screws holding lens, remove lens. Replace with good lens. Assemble camera in reverse order.
Good luck and be CAREFUL!
Loren
Posted on Jun 22, 2008
My olympus fe-170 lcd screen won't show ANY pictures.
it would appear that the lcd screen has malfunctioned and would need repair.... you can try power cycle by taking batteries out and press and hold power button down for 10 secs, draining all power out of camera, then put the batteries back in and try again
Dec 16, 2008 | Olympus FE-170 Digital Camera
LCD FOR OLYMPUS FE-170 BROKEN CAN IT BE REPAIRED
my olympus FE-170 screen won't show any picture. All other things are fine and working the screen just won't show pictures taken or a picture i'm aout to take. the camera is about 2 years old i've had no problems with it till now. Can someone pleeeaaasssse tell me their is an easy solution to this.
Nov 23, 2008 | Olympus FE-170 Digital Camera
My camm!
I think thy will say you, replace lens unit. but lens is very expensive, so we can buy new one camera. I have the same problem, i found focusing lens wheel teeth slipping, no parts available, so i covered a gum coat on the teeth. but very difficultive
Jun 15, 2008 | Olympus FE-170 Digital Camera
Olympus FE-170 6.0 will not take pictures.
I had the same exact problem.The lens is not extending out fully or correctly, probably has broken or damaged gear or gears and needs to be replaced. Expensive repair done by Olympus. It is a very tricky and fragile repair on your own, requiring micro screwdrivers and soldering tool. I replaced my own lens but it was hard to find one.
Apr 28, 2008 | Olympus FE-170 Digital Camera
Broken Lcd panel
Broken LCD screen is quite easy to replace on the FE-170 and FE-210. I have purchased cameras with bad lens but good LCDs on ebay pretty cheaply( compared to having Olympus repair camera).
Mar 01, 2008 | Olympus FE-170 Digital Camera
FE 170 OLYMPUS digital camera
its fucked up olympus sux i bought a sony cybershot 4000000 times better than that trash fe-210.
i trashed it destroyed it mutilated it till it begged for mercy
Dec 02, 2007 | Olympus FE-210 Digital Camera
Olympus fe 170
Olympus customer support This camera has a major fault and will be replaced if a year or less old- a repair prince will be like a new camera all over
Aug 07, 2007 | Olympus FE-170 Digital Camera
Olympus FE-170 Digital Camera Logo
91 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
