If I start my computer it makes some noise and will not start
  • 2,567 Answers
What kind of noise? Beeps, grinding sounds, ... etc.?
Could you please specify?
Posted on Nov 06, 2010
Hp laptop hp 430
Maybe the cpu fan is fubar - check that out.
Mar 18, 2017 | Computers & Internet
Computer system starts to make some noise
Does it happen after prolonged use? If so, this is most likely the fan cooling off the hardware in side. Computers also make noises during normal function occasionally. If you could better decribe the noise, it would help in providing a more accurate solution.
Sep 21, 2013 | HP Computers & Internet
Clicking noises and no recognition on computer
The read mechanism is stuck that is it is unable to move to the next section on the magnetic platen disk inside the hard drive \
It has come to the end - of - Life and need replacement.
To recover your data before it completely dies is to put the drive into a usb case and connect it to the computer that has a large capacity drive and backup the drive contents. You will have reload Windows to the new drive.
Apr 06, 2010 | Western Digital My Book Essential Edition...
My computer is becoming really hot and noisy. After turning on the computer, everything is good (no noise). Once around 15 minutes passes by or I open up a lot of programs together, my computer starts...
Sounds like the fan is wearing out, as it heats up the fan needs to spin faster and if the bearings are wearing out it will start getting louder and it will also get hotter because the fan cannot keep up the heat being produced. You can replace the fan, most computer shops will carry replacements, also get a can of compressed air and give the inside of the computer a good cleaning. This will help keep things cooler as well. Also make sure that the air vents on the outside of the case are clear as well.
Jan 07, 2010 | Vantec Fan Vibration Dampener Noise...
ASUS Lap top computer, 2 months old' makes loud fan type noises at each start up.
Hi
Its normal for a laptop computer or a desktop computer to spin its fans at maximum speed during start up - its part of the power on self test.
If the fan is very loud like on this video the sound is very bad -
that would be a bad fan, constant bad noise. but if your fan only makes noise in start up, its normal.
your warranty should cover the replacement of the fan if its bad.
Oct 02, 2009 | ASUS Z71V Notebook Computer - 15.4"...
My ALTEC speakers make noise when they are idle.. I shut down my computer.. re-start it.. then the speakers are not making noise but after a few minutes the noise returns .
there may be some problems with the wiring. either change the whole wiring or try to keep the speaker volume at low when they r idle. it will certainly help .
Jun 18, 2009 | Harman Kardon HK595 Computer Speakers
Desktop computer makes a beeping noise on start
please check RAM or replace it
Mar 09, 2009 | Nokia 1100
I have a dv 2000 and when you turn it on it makes two load noises and it does not start up blank screen but the computer is running....
Noises usually come from moving parts; Fans, and Hard drives are the most likly. I would open the side of the computer and determine which part was making the noise.
Dec 08, 2008 | Computers & Internet
Computer making noise
Monitor clicks, pops, or makes other noises. Issue: Monitor clicks, pops, or makes other noises.
Cause: This issue could be caused by any of the below possibilities:
  1. Monitor degaussing.
  2. Monitor changing resolution.
  3. Monitor syncing with the video card.
  4. Monitor warming up.
Solution: Noise when turned on or off It is normal for standard computer CRT monitors to make a click, pop, crackle, hum, buzz, or other type of noises when they are first turned on or turned off.
Noise when monitor goes into standby mode When the monitor enters a "standby mode" or "power savings mode" this is similar to the monitor being turned off. It is completely normal for the monitor to make a noise when the monitor enters this mode.
Noise when opening Microsoft Windows or other operating system or when opening a game When a computer opens its operating system, for example, a computer opening Microsoft Windows or when a user runs a computer game it is very common that the monitor will need to switch its resolution of the operating system or game. When switching resolutions it is normal for the computer monitor to make some type of noise and/or for the computer monitor to flick or flash.
Noise during normal operation If the computer monitor click, pops, or flashes while it is being used this is not normal operation. It is very likely that the monitor may be failing or a component within the monitor has already failed and could also potentially be a fire hazard. We highly recommend that the monitor be repaired, replaced, and/or looked at by a qualified technician.
Additional information:
  • See document CH000302 for additional information and other noises that may come from
Jan 16, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
