Question about Danby DCD5505W Electric Dryer
My dryer will not do anything after I replaced my dryer belt. Is ther something I am or have over looked. please help
  • giantsphan56 Nov 06, 2010
    found the bproblem only after I requested your help, thats always the way right. the dryer is functioning well all seems good. thank you for your reply anyway.
    President:
  • 1,891 Answers
Most newer dryers use a belt sw and if belt is not the correct one then the belt sw is causing the problem . other problem may be in the wire connections. yu need to reck them as one may be loose or off. and the first thing to do is ck the power suppply . and make sure its ok .. hope these help mm feed back please ..
Posted on Nov 08, 2010
  • 10,319 Answers
Did you reconnect the door switch
Posted on Nov 06, 2010
Dryer makes a noiseand ther is a smell like somethings burning,drum doesnt spin
Sounds like a classic case of a bad drive motor.
I would unplug the dryer, remove the dryer belt and try to turn the motor by hand to see if it's tight or locked up.
Aug 02, 2011 | Frigidaire Dryers
WHIRLPOOL dryer model JLDE8300N1 WORKED FINE, NOW WHEN PUSH START BUTTON, JUST GET A HUM. I have reset the breakers in the house. plus removed the top of the dryer & back to see if anything looked...
Sounds like something not leting the motor turn. Perhaps something in the fan i've seen pencils
nails or almost anything . Check for frozen rollers or belt pully. Last check motor , the bearing may be bad. Sounds like may be motor. Hope this helps
Jul 18, 2011 | Dryers
I think a belt on my dryer blew because when I went to start a load (it was a large load my kids put in) a spark came from the bottom and a burning smell followed. Now the dryer does not turn at all. It...
It does not sound like the belt, more like the motor of something else electrical. Turn the machine on its side and check the belt and look at the electrical parts for anything that shows signs of burning or blackening. You can also remove the top to look there, there are some screws at the back that, when removed will allow you to slide the cover forwards.
Apr 26, 2011 | Maytag Neptune MDE5500AY Electric Dryer
The blower on my dryer needed to be replaced, I replaced it. Now the dryer gets hot very quickly, but is not tumbling. The belt looks worn but is still intact. I don't know anything about dryers! Do I...
If the drum was turning or if the blower caused it not to turn before you replaced the blower make sure the blower and the motor will turn maybe didn't get something back right. Did you clean all the lint or anything out of the blower housing and the vents. Recheck the idler pully and be sure the belt is threaded right. I have seen this happen and drum would't turn. If it's getting too hot sounds like the air is not getting pulled through the drum or the high limit is not shuting it down when it gets too hot . Check all thermastats and the high limit cut off. You can check them with a ohm meter. Check and see if you can turn the drum by hand.
Hope something here will help you.
Dec 05, 2010 | Maytag Dryers
Dryer was working and just quit is ther a reset button or something the model # is gler311a52
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 07, 2010 | Frigidaire GLGR104FS Dryer
I have a neptune dryer. It is making a rhythmic
I normally only comment on Electrical Dryers, but you problem sounds like something that is common to all dryers.
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine, You will probably have to remove the top of the machine first, then remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
Good Luck,
I hope this helps
Oct 15, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Belt replacement - possible missing part
There are some excellent exploded view illustrations you can use for a reference at searspartsdirect.com. Just type in your model number and look under the link on the following page. There is also a zoom feature so you can get closer views if needed.
There are also helpful dryer belt diagrams listed at repairclinic.com. Just click on the "Repair Help" link at the top of the page and look for the "Dryer Belt Diagram" link on the following page listed under "Special Features". The Fridgidaire diagrams are listed as C, B, and G. You will have to know the age of the appliance to make sure the diagram you are using is accurate. If you do not know the age, please post back with your SERIAL number and I can tell you how old it is. I hope you find this information helpful.
Oct 27, 2008 | Frigidaire FDE216RE Dryer
Replacing bryer belt
Please CLICK HERE this will fix your problem.All the instructions are given step by step with the diagrams.
Jul 03, 2008 | Danby DCD5505W Electric Dryer
Dryer drum does not turn
how about the idler pully that keeps the belt tight did you see it in there has to be there look if its is ther try to turn the drum by hand a foregin object could be jaming the tub im here to help get back and let me know
Dec 29, 2007 | Dryers
Danby DCD5505W Electric Dryer Logo
32 people viewed this question
Top Danby Dryers Experts
Tim Whalen
SHARCNET-USA
SHARCNET-USA
Are you a Danby Dryer Expert? Answer questions, earn points and help others
