Question about Radio Shack Pro-82 Scanner
Pro-82 scanner hi i have a pro-82 scanner and i just wont pick up any signals any more not even the weather channel signals whats wrong with it
  • Anonymous Sep 15, 2008
    i am no longer receiving signals as well, i do have squelch & it's working & it's turned down so there's no static..it used to work..could it be set to a wrong channel??
  • WadeWard408 Oct 22, 2008
    I was able to use it a week ago Friday and then nothing i like to listen to the Butler County, Ohio, Warren County, and Hamilton County Ohio Sheriff's Office on 154.800 and i can't here anything now not even Fire Dept. What could be the problem? I want to be able to listen to it again
    thanks,
    wadeward
    New Friend:
Having the same problem although I did reset everything it still scans and scans. Cannot seem to find any other channels to possibly connect. Possibly all are blocked ..
Posted on Jan 15, 2013
    Problem Solver:
  • 12 Answers
Go to cityfreq.com and see if the frequencies in your area have changed. you might even need a new anteanna radio shack should have a really good one for 20 buck. a little longer than the original but good
Posted on Feb 06, 2009
  • darldlc
    darldlc Jan 15, 2013
    cityfreq.com is only the USA. Tried to find a Canada site but cannot.
My Radio Shack Pro-82 Scanner is not working at all.i turned it on and it wont even scan. i cant even hear the squelch. and the only time it picks up something is when its on the air setting it picks up...
Ok I have had the same problem with the Pro 82 and the biggest problems I've found for it not to scan is Corrosion of the terminals not only outside but inside. Even on the keypad and pcb board. SOLUTION: Just take it all apart with a small philips pecision screwdriver and with a dry toothbrush scrape all the corrosion off the board. This always solves my problem and it should yours. Even if theres no corrosion visible on the terminals be assured there is still some inside keping this from functioning correctly. Shotgun420
Jul 30, 2011 | Radio Shack Pro-82 Scanner
I am scanning and can't pick up ANY signals how do i program my handheld radio shack 82 200 channels scanner
Hi my name is John. Turn the unit on, press PGM,enter the channel you want to store the frequency in (1-200), press PGM,use the number keys and DELAY/. to enter the frequency you want, including the decimal point. Press ENTER to store the frequency, and your done..Get your frequency,s here www.RadipReference.com ..or www.RadioFreq.com.. Hope this was helpful.....Rate this solution on the four thumbs-up....good luck.. John
Oct 11, 2010 | Radio Shack Pro-82 Scanner
My pro-82 scanner scans threw all channels but will not pick up any frequencies?
To verify that the scanner is working properly, program one or more of the weather frequencies(162.4, 162.425, 162.45, 162,475, 162.5, 162.525, 162.55, 161.65, 161.775, 163.275) into memory and then scan. NOTE: Not all frequencies are in use in all areas, so you may need to try several. If you receive the weather broadcasts, then you may need to adjust the squelch setting on your scanner to receive local signals. You also need to verify that the frequencies programmed into the scanner are valid, active frequencies in your area. For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
If the scanner fails to receive the weather broadcasts, you need to check the antenna connections inside the unit and/or have the scanner checked/repaired by a qualified technician.
Bill B
Jul 08, 2010 | Radio Shack Pro-82 Scanner
Scanner not receiving
Performing a RESET will not clear/erase frequencies or other data programmed into the scanner. If the RESET doesn't work though, you may need to INITIALIZE the scanner. That procedure will clear all programmed data and return the scanner to its "as new" state. Need the manual for your PRO-82? You canb download/print it here:
http://support.radioshack.com/support_electronics/doc69/69887.pdf
For a comprehensive database of active frequencies in your area, visit:
Bill B
Nov 02, 2009 | Radio Shack Pro-82 Scanner
I cant get it to pick up any channels
not a lot of info hear.try input a weather freq like 162.400 MHz if your hear that the scanner ok the freq. are just not txing or wrong
Jul 10, 2009 | Radio Shack Pro-82 Scanner
HOPKINSVILLE KY. POLICE DEPT. CHANGED TO A
Unfortuantly the pro-82 is not a trunked scanner, it's only a vhf/uhf scanner and cannot pickup trunked systems. You need to replace it with atleast a pro-95 to pick up trunked systems. If you need your manual for the pro-82 follow this link.
http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/2000315_PM_EN.pdf
Feb 19, 2009 | Radio Shack Pro-82 Scanner
Wtf
hold down the light key/ lock key on the bottom left hand coner and it will unlock the unit
Jan 04, 2009 | Radio Shack Pro-82 Scanner
I have a radio shack weather alert pro 82
Tilt the scanner in a different direction while looking at the display. Do you see anything on the display when you look at it from a different angle? Sometimes manufacturers don't put the LCD display in correctly, and because LCD's have a really small viewing angle it can result in not seeing what is displayed.
Oct 19, 2008 | Radio Shack Pro-82 Scanner
Radio Shack Pro-82 Scanner Logo
272 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
