Question about Kodak Easyshare V1233 12.1MP Digital Camera with 3x Optical Zoom
When switching my camera on it just switches itself straight back off?
    President:
  • 2,185 Answers
Make sure you have installed freshly charged batteries on your Kodak Camera. If you already have but problem still goes on, then try to do a little fix.
With your camera turned OFF, hold the camera on your right hand with the lens facing the ground. Then hit the camera's base on your left palm as you push the button to turn on the camera. You might have to do this a few times. What happens is that there could be a grit of sand that got stuck between your lens' barrel and the camera's base, preventing the lens to retract freely. If the above solution does not work, you might want to apply a bit of force by twist-pushing the lens inside with your index finger while trying to turn on the camera. The idea here is to remove that grit out of the camera.
Please let me know how this goes. Thank you for using FixYa.
Posted on Nov 06, 2010
  • mikedeniro20 Jun 05, 2011
    That was a great tip , it works, thank you so much
    Problem Solver:
  • 13 Answers
On mine, you have to press the button (On the top) down hard, and I mean Real Hard, if you let go or stop holding it down (like you normally would) it just shuts off like holding down the power button on your computer, the lens doesn't go in but if you hold down one button and hold down the power button it turns off normally, also, it only runs on electric, PLEASE HELP ME!
Posted on Jun 20, 2011
LG TV KEEPS TURNING OFF
Kindly do not keep attempting to turn it on, as you are likely to spoil some other boards/parts/components of the TV. Look for any loose contacts in power out let, RC jack, cable and socket. In order to ensure, it is not caused by the input device, connect a DVD player
and see. Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, I suggest it is better to refer it to a qualified service technician, since the back cover has to be opened for investigation/rectification.
Aug 21, 2012 | LG 50PC1DR 50 in. Plasma HDTV
Sony dsc-H1 won't switch off of movie mode
When you switch the camera from mode to mode, does it make the click noise to signify that the camera recognized that it changed modes? If not it could be that the switch itself has become unlogged from the switch. I know I had a older camera had this happen before. Try pushing down hard on the toggle wheel and seeing if it will snap back into place. Otherwise the switch inside the camera itself is probably broken, and if this is the case cheapest thing you can do is have Sony do warranty work on the camera. http://www.sonystyle.com/webapp/wcs/stores/servlet/SYCustomerCare?storeId=10151&catalogId=10551&langId=-1 Click repair and service under Technical Support. This will get the process started on the warranty work.
Aug 25, 2007 | Sony Cyber-Shot DSC-H1 Digital Camera
My camera switches itself off straight after I have taken a picture, and the picture does not save. Any help would be much appreciated, Kirsty
Sounds like weak batteries. Possibly a bad battery. May look good till called on then voltage drops fast. Cam goes off, before saving image. Replace batteris.
Jan 17, 2011 | Hitachi i.mega HDC-401 Digital Camera
My camera turns immediately off when I turn it on!
I may be able to help with your Kodak EasyShare Z740 that turns itself off.
Try these steps to fix your camera.
I hope that helps.
_____________________________________________
Kodak EasyShare Z740 Turns Off Fix
Kodak EasyShare Z740 Manual Download
Apr 05, 2009 | Kodak EasyShare Z740 Digital Camera
Camera
Use your thumbs and gently yet firmly push the lens assembly back into the camera until you hear a confirmation "click"
Aug 01, 2008 | Kodak Easyshare M753 Digital Camera
Kodak easyshare c613
you need to clean your lens with a tissue sort of cloth, DO NOT GET IT WET! that will ruin your camera.
Jun 10, 2008 | Kodak EasyShare C613 Digital Camera
Our topload Kenmore Elite washer will not fill with water. It starts to agitate right away upon setting the dial
try switch in the load size?? sounds like your having a problem with the pressure/ water level switch. it must think its full of water already. you would need to pop open the control panel. either 2 screws located on back of console (while looking over the top of machine and straight down you should see 2 Phillips head screws in both corner of top screwing straight down. if not the 2 front end caps will pop of control panel to reveal the screws. undo the screws and tip the console back( its hinged), the far left is the pressure switch, it has a clear plastic tubing leading to it. remove the tube and try blowing through it(clear the line) try also blowing back into the switch itself you should hear it click. if after that it still doesnt work id say the switch is no good
Mar 14, 2008 | Washing Machines
Mid2020
if this is a desktop: Did you check the power supply? try to replace it with a new one
Laptop: Try to run the machine without the battery plugged in....straight with the adapter....If the laptop still restarts...it's a manufacturing defect which should be replaced by the OEM.
Jan 14, 2008 | Medion MD-40954 Notebook
Kodak Easyshare V1233 12.1MP Digital Camera with 3x Optical Zoom Logo
373 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
