Question about U-Line 75R Refrigerator
Door does not seal properly which causes inside to ice up. Can this be fixed. Can you purchase a new door?
  • 144 Answers
Check the door seal for splits or is it deforming. A door seal can be uasually obtained and easilly fitted. I would also check the door for alignment problems if so it could be the hinges,
regards
pete
Posted on Nov 06, 2010
Why is my freezer building up ice in the inside?
two possible reasons
i-- freezer door opened too often and held open for too long periods-- humidity from the air gets in and turns to ice
2 door seals leaking and letting in air and humidity-again turning the humidity to ice
fix --- only use a freezer to store items for future use --not every day use
have the door adjusted properly or replace the door seals
Sep 07, 2016 | Refrigerators
Icemaker keeps sending out cubes after let go of switch. Had to lock it off. Now inside of freezer is icing up.
Please check if the freezer door gasket is sealed properly.
By switch do you mean the lever on the front of the door.
Check also the small door where the ice cubes go threw. Make sure it is closed.
Jul 07, 2015 | Whirlpool 25.6 cu. ft. Side-by-Side...
There is ice forming on the inside back wall of the freezer. What does this mean? Would it cause the refrigerator alarm (beeping noise) to go off?
It usually means that your door is either not closing properly or the seal is deformed. Moist air is getting in and condenses on the coldest surface at the back of the freezer. Check that the freezer is not too full (stopping door from closing fully) and check the door-seal.
Sometimes it is caused by icing of the thermostat. Ice is a good thermal insulator so the thermostat does not switch and the freezer keeps running constantly. Make sure there is adequate air circulation and no ice around the thermostat.
Defrosting usually fixes either problem.
Oct 13, 2014 | Refrigerators
Fridge freezer door won'tstay closed
Faulty door seal.The seal that holds the door has a grip and a magnet on other side.May be that needs to be replaced.Or any fringe section tray is not completely fitted,to its end causing these.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 24, 2012 | Frigidaire Refrigerators
Their is frost and ice around the inside of the freezer, the rubber seal around the freezer door is split and broken could this be the cause of the frost and ice?
Being brief yes it is the cause of the frost. Door seals are not that expensive and in a matter of months the energy consumed to keep a unit cold can cost more than the cost of the door seal. (not labor... )
However.... if your unit is not defrosting properly you would have ice build up on the back wall / access panel of the unit.
If your ice build up is mainly on the cabinet face and wall.... the door seal is for sure causing the problem.
If you respond with a make AND complete model number I will do my best to locate a replacement part for you.
Thanks for choosing FixYa,
Kelly
Aug 05, 2011 | Refrigerators
Freezer frosts up to the point of not being able to open the door without ice falling on the floor. Can this be fixed?
Yes it can be fixed, This can be as simple as replacing the door seals if bad to replacing the defrost board.If the seals are good and the doors close and seal as they should then the defrost is not working properly.
Aug 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
ICE DOOR SEAL IS LOOSE AND NOT SEALING CAUSING FROST BUILDUP
This is the step you will use to repair your ice door seal that is loose.
There are screws under the fold of the freezer door gasket that holds the brace for the gasket in place. Lift the rubber gasket to expose the screw head, one section at a time. Just loosen the screw, and do not take it completely out.
As you loosen the screws, one section at a time, carefully remove the old gasket. At the same time, fit the new gasket into the groove. Make sure your new gasket is lined up properly.
Continue around the freezer door, unloosening the screw, taking out the old gasket and fitting the new one in.
Tighten the screws into place. This may have to be done once the entire gasket is fitted into place.
Check the seal by closing the door. You should have a nice, tight seal.
Good luck.
  • Step 4 Tighten the screws into place. This may have to be done once the entire gasket is fitted into place.
  • Read more: How to Fix a Freezer Door Seal | eHow.co.uk http://www.ehow.co.uk/how_4855248_fix-freezer-door-seal.html#ixzz0rY7rn3O8
  • Step 3 Continue around the freezer door, unloosening the screw, taking out the old gasket and fitting the new one in.
  • Read more: How to Fix a Freezer Door Seal | eHow.co.uk http://www.ehow.co.uk/how_4855248_fix-freezer-door-seal.html#ixzz0rY7gYaZ2
  • Step 2 As you loosen the screws, one section at a time, carefully remove the old gasket. At the same time, fit the new gasket into the groove. Make sure your new gasket is lined up properly.
  • Step 5 fix-freezer-door-seal-1.5-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep5 span.image a:first').attr('href','http://i.ehow.com/images/a04/k5/eg/fix-freezer-door-seal-1.5-800X800.jpg'); }); Keep the gasket clean to last longer. Check the seal by closing the door. You should have a nice, tight seal.
  • Read more: How to Fix a Freezer Door Seal | eHow.co.uk http://www.ehow.co.uk/how_4855248_fix-freezer-door-seal.html#ixzz0rY7JfY8i
    Jun 22, 2010 | Refrigerators
    Ice crystals forming on inside front freezer panel
    Very possible the door seal is not properly sealed. Warm inflowing air onto a cold coil will cause ice build up at the lid.
    Oct 08, 2009 | Kenmore 22.7 cu. ft. / 643 liter Chest...
    Door doesn't close properly, leaks water
    If the door seals are still pliable and intact there are two possible causes.
    1/ The upper door hinge on the top of freezer unit has two adjusting screws under a plastic cover/cap which allows the upper hinge to be set forward or back altering/adjusting the spacing of the door seal to the freezer body. Moving the hinge outward at the top will cause the door to seal tighter at the bottom and lessen escaping cold air and condensation to form (water droplets). Adjust carefully so as not to create a weak seal (air gap) along other sealing edges of the door frame.
    2/ Many United Refrigeration Commercial Freezers are manual defrosting. Moisture from inside the freezer can condense between the inner molded door panel (door shelves) and the exterior metal door. Usually ice buildup will occur in this space, but when defrosting or during high ambient temps the ice will melt and drip out along the bottom door edge/seal. Screws alomg the door frame (hidden by the door seal) hold the seal in place and also the inner molded door panel. The inner panel can be removed to replace the seal or to remove the ice buildup.
    Jun 04, 2009 | Freezers
    Ice build up
    Check that the door is closing properly otherwise the freezer will be working overtime to cool and ice will form. If the door seal is good, it is possible that the thermostat needs to be checked.
    Oct 02, 2008 | Refrigerators
    U-Line 75R Refrigerator Logo
    193 people viewed this question
    Top U-Line Refrigerators Experts
    mike cooper
    Dale Copeland
    Dale Copeland
    Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
