Question about LG DLE2532W Electric Dryer
Hello. I am trying to replace an ignighter in my DLG2532W dryer, how do I get to it?
Posted on Nov 07, 2010
My Maytag Gas Dryer makes a loud buzzing noise when the ignighter and flame come on
thats a good sign the valves that those coils you replaced sit on are getting bad and you will sooner or later need a brand new gas valve
Oct 13, 2012 | Maytag Dryers
Whirlpool Model LGN2000KQ0 ignighter glows, flame turns on for a few minutes then it goes out and the ignighter never glows again nor does the flame return
The problem is the dryer coils have failed. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a link that should help troubleshooting a gas dryer
Sep 25, 2010 | Whirlpool GGQ8831L Gas Dryer
Dryer won't dry
It could be several other things thermal fuse, thermal cut out, hi limit thermostat, dryer coils, heat sensor. All of these parts are inexpensive and easy to test and replace.There is a video at http://appliancehelponline.com/gdryertroublevideo.html his will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Jun 08, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer won't heat up. Replaced ignighter, still
I would suspect faulty gas valve coils. These electrical coils are right above the gas valves and when energized these solenoids open the gas valves to permit gas flow to the burner. It's recommended that if any are suspected of being faulty that both (all) be replaced at the same time. Really sorry for your trouble and I hope this helped. Best wishes.
Sep 11, 2009 | Kenmore Elite HE4 Electric Dryer
I need thermostats for LG Gas Dryer DLG2532W in houston TX
Hi, you can order your replacement thermostat parts at the link below.
CLICK HERE
May 21, 2009 | LG Dryers
Dryer Ignitor turns on then back off with no flames afterwards
the government mandated that gas appliances start using electronic ignighters because pilot lights would keep blowing gas even after they blew out now the way they work is calibrated on how much amps the glow bar draws the rest of the amps go to the safety valve to open it when the glow bar is drawing enough amps to be hot enough to ignite the gas now what this means is even though the glow bar glows it can still not be hot enough to ig night the gas so the safety valves don't get the right amps to the solenoids to open so you could have a weak ignighter or bad solenoids on the safety valves now i would lean toward the solenoids but i would buy both and first replace the solenoids then the ignighter if the solenoids work take the ignighter back
May 22, 2008 | Kenmore 74602 Gas Dryer
Dryer Ignitor
yes its right on the money it takes about 30 seconds for the ignighter to reach enough tempeture to open the safety valve this assures that the ignighter is hot enough to instantly ignite the gas before the safety valve will release it
Jan 30, 2008 | Dryers
HOW TO INSTALL THE BELT ONTO A LG DRYER MODEL DLG2532w
Connect Gas Supply Pipe
(Gas Dryer ONLY)
For further assistance, refer to section on Gas
Requirements.
1. Make certain your dryer is equipped for use with the
type of gas in your laundry room. Dryer is equipped at
the factory for Natural Gas with a 3/8” N.P.T. gas
connection.
2. Remove the shipping cap from the gas connection at
the rear of the dryer. Make sure you do not damage the
pipe thread when removing the cap.
3. Connect to gas supply pipe using a new flexible
stainless steel connector.
4. Tighten all connections securely. Turn on gas and
check all pipe connections (internal & external) for
gas leaks with a non-corrosive leak detection fluid.
5. For L.P. (Liquefied Petroleum) gas connection, refer
to section on Gas Requirements.
Oct 15, 2007 | Kenmore 63932 Electric Dryer
LG DLE2532W Electric Dryer Logo
266 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
