Question about LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive
My Lacie d2 Quadra V2 is not recognized by windows, only frequently when i restart windows. I'm using the e-sata connection to my PC. Could there be a driver problem?
4 Suggested Answers
  • 77 Answers
SOURCE: LaCie d2 Quadra drive... not showing up on PC after working on a MAC
You need to make sure the drive is formatted for the PC. The Mac will read and write to a FAT32 partition, but the PC cannot see a Mac formatted drive as you have seen.
The only problem is that there is a 32Gb limit per partition for FAT32 drives.
It's not ideal but it's the best you can do easily.
Posted on Jan 13, 2008
  • 242 Answers
SOURCE: How to format the LaCie 500GB d2 Quadra for Windows XP??
This way it should work...
Connect your drive to the computer...
Go to: Start > Control Panel > Administrative Tools > Computer management.
A new window will appear...
Select Storage > Disk management on the left of the window.
Now you will see the different drives that are connected or part of your system.
One of the drives listed there is your LaCie, i think you'll recognize it by name...
Right-click on it, and select 'format'
In the new window, select the new volume label (as you like it), the file system (use NTFS), and set allocation unit size to default.
Make sure 'Perform a quick format' is not checked...
Then click OK. Your drive will be formatted now... Don't interrupt the process
Posted on Mar 31, 2008
SOURCE: deference Lacie d2 Quadra1TB/Lacie big disk ?
It's all about the interfaces.
The Quadra has four interfaces: • eSATA • FW 400 • FW 800 • USB 2.0
The triple has all but the eSATA interface listed above.
For doing video work you want a big drive with a fast interface. If you have eSATA available then that's the fastest. If you don't then you're just as well off to go with the triple interface. The FW 800 would be the next fastest, then the USB 2.0, then the FW 400.
Because of the way that data is transferred I believe that when doing video work you would be best served by the FW 400 instead of the USB 2.0 even though the USB is faster I don't believe it is a full duplex communication so the FW 400 is actually better for video.
Posted on Apr 06, 2009
My Macbook Pro running Mountain Lion does not recognise My Lacie D2 Quadra V2 (301442a) after upgrade from Snow leopard
Here's a good start.
Plug your Lacie drive into someone else Mac or PC using MacDrive Pro and see if it shows up.
Dec 02, 2017 | Computers & Internet
My Lacie Hard Drive only shows 9.99 mb capacity. and its a 2TB LaCie d2 Quadra v2.1 7200RPM U. It was just repaired by Lacie. Where's all the storage?
Please explain what you mean? When you plug in the drive it recognizes the drive but the size is showing to be extremely small?
Please let me know so I can help further.
Thanks!
EJ
Aug 05, 2011 | LaCie 2TB d2 Quadra Hard Disk v21
When i connect my Lacie to my Pc i see the icon but when i want to click on it there is nothing in it even if 500 giga is used i can not find any of my files that were stored on it. When i want to...
Remove the hard drive from the lacie box and plug it in directly to your computer to see if the drive is now recognized. If it is the issue is with the lacie box electronics. If still not recognized with a direct connection to computer, see if the bios sees it. If not, the logic board on hard drive is fubar and you have a serious recovery problem.
Sep 22, 2017 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
My lacie d2 quadra 500 gb hard drive does not mount in my computer when turned on
I can offer some simple advice based on windows PC's for these types of hard drives and that is contained here
http://www.fixya.com/support/r4247716-usb_device
It assumes USB type connection but I have also had firewire and e-sata issues with the cables supplied so tend to buy the ones that have the lock on them as these tend to be a little better
Bob
Oct 14, 2010 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Will not mount on a Mac Book Pro 17"
try to connect lacie to windows base computer if it work, there a problem, with your mac book check if device manager recognize lacie drive if not check for the fire wire port.
Apr 10, 2010 | LaCie 1TB D2 HD Quadra FireWire 400 Hard...
LaCie d2 200GB on my Pc (windows xp) via USB 2.0 doesn't show
the situation here is ahppening to all external sata or Esata drives what happens is the external closure has a usb controller when this dies the drive doesn ot spin up or does not reconise simple solution buy a external drive encloser and transfer the drive to it and that will work. thanks and please rate.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Nov 24, 2009 | LaCie d2 (300769) 200 GB Hard Drive
I need to be able to use this hard drive on my pc
DataViz makes a product called MacDrive7 that can be installed on a Windows PC that will enable it to use pretty much any kind of device that has been formatted for a Mac. The other option would be to format the drive for a PC since a Mac can utilize PC formatted disks, but you will lose options like forks, etc that are Mac-specific.
Jun 01, 2009 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
LaCie 2d 500GB isnt recognized
Has the drive been formatted? Before using a hdd it has to be formatted. In Windows XP you have choices of FAT 32 or NTFS format. Hope this helps.
Dec 17, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Mar 31, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Jan 13, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive Logo
680 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
